04-19-2017 03:26 AM - edited 07-05-2021 06:53 AM
I have configured one of my 1700 AP in stand alone mode with one SSID but we are able to see two SSIDs.
Ex: I have created "wireless-network" SSID but "wireless-network_1" SSID also broadcasting by the same AP.
Kindly help us to resolve the issie.
Thanks and regards,
Ashok.
04-19-2017 03:42 AM
Hello S.ashok,
This is how SSIDs are working on an autonomous AP.
First, you create your SSID :
Example :
conf t
dot11 ssid wireless-network
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 0 welcome
And then you link this SSID to the dot11radios 0 and 1 :
conf t
interface dot11Radio 0
encryption mode ciphers aes-ccm
interface dot11Radio 1
Run the command "show run" and check if on your dot1radios you have your SSID "wireless-network_1".
From there, you can go in the dot11radios and put a "no ssid wireless-network_1"
Cheers,
Alex-
04-19-2017 04:07 AM
Thank you for your reply.
It seams it is already there. Please find radios configuration as below.
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm tkip
antenna gain 0
stbc
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
antenna gain 0
peakdetect
dfs band 3 block
stbc
channel dfs
station-role root
bridge-group 1
Thanks and regards,
Ashok
04-19-2017 04:16 AM
Showing two SSIDs as below
wireless-network
wireless-network 2
But I have configured only one which is first one.
Thanks and regards,
Ashok
04-19-2017 04:19 AM
I have tried to remove second one from radio but showing "unknown ssid" as it is not appearing.
Thanks and regards,
Ashok.
04-20-2017 04:52 AM
Hello Ashok,
If you try to disable the SSID from the interface dot11radio 1, the SSID "wireless-network_1" is still broadcasted ?
Alex-
