742 Brasilian Portugue Locale - CME
Apr 19th, 2017
Helo,
I config CME and 7942 SCCP phones with Brasilian Portuguese locale, but the menu of Directories the title and the itens 4 to end are in Russian. Its happens only in this menu. I tried to reinstall the locale, put as System Locale, put as User-defined, but the same problem.
The configuration are:
tftp-server flash:apps42.9-4-2ES26.sbn
tftp-server flash:cnu42.9-4-2ES26.sbn
tftp-server flash:cvm42sccp.9-4-2ES26.sbn
tftp-server flash:dsp42.9-4-2ES26.sbn
tftp-server flash:jar42sccp.9-4-2ES26.sbn
tftp-server flash:SCCP42.9-4-2SR3-1S.loads
tftp-server flash:term42.default.loads
tftp-server flash:/its/CME-locale-pt_BR-Portuguese-11.6.11.6.tar.cfg
telephony-service
 cnf-file location flash:
 cnf-file perphone
 user-locale 1 U1 load CME-locale-pt_BR-Portuguese-11.6.11.6.tar
 network-locale U1
 load 7942 SCCP42.9-4-2SR3-1S.loads
ephone-template  1
 user-locale 1
 softkeys idle  Cfwdall Newcall Pickup Redial
 softkeys seized  Endcall Redial Cfwdall Pickup Meetme
 softkeys connected  Confrn Endcall Hold Park Trnsfer
ephone  1
 lpcor type local
 lpcor incoming Externa
 description 2100
 mac-address XXXX.XXXX.XXXX
 ephone-template 1
 type 7942
 button  1:1
