04-19-2017 05:58 AM - edited 03-01-2019 01:09 PM
Hey all,
Any input would be appreciated with this one. I'm wondering if it's just a major hardware failure that is causing the Bios to not finish post or if its possibly a firmware bug.
Please see the attached.
Thank you for your time!
04-19-2017 06:03 AM
What model of server is this? What firmware version is it running? Was it working before and just stopped booting or has this never worked as expected?
Need a little bit more information on the setup to determine one way or another if its hardware failure.
Wes
04-19-2017 06:25 AM
Its a UCS Mini with 2 x 6324s running 3.1.1g firmware packs. The blades are B200-M4 with 2690 V3s.
The blades worked before in lab but are having issues after being sent to the DC.
04-19-2017 06:29 AM
If you go to the general tab on the server, under Actions, there should be a "POST results" button that could provide further information.
Is the behavior consistent after decommissioning and re-acking the server? Is this the only server having the problem?
You should be able to launch the KVM and see if any outputs are displayed. Otherwise, I would suggest opening a TAC case for further investigation.
Wes
