Brackets for ASA 5555X
Is it possible to mount the ASA 5555X with brackets to a rack (ASA-BRACKETS) ?
Documentation says that ASA5555X comes with slide rails,
Marvin Rhoads
It's possible but not recommended. The 5555-X is a bit heavier (16.82 or 18.86 lbs depending on single or dual power supply) and mounting it only with the front brackets isn't a recommended long term solution. If I have to use a 2-post rack then I get a mounting shelf for additional support.
Depending on your rack construction, even the smaller units like the 5525-X (15.92 lbs) can be pretty dubiously supported using just the brackets or "ears" at the front.
Reference:
http://www.cisco.com/c/en/us/td/docs/security/asa/hw/maintenance/5500xguide/5500xhw/asa_install.html#78744
Marvin Rhoads
Reference:
You could weld it on, but more than likely your rack is aluminum and that starts another conversation.
