TSP 11.5(1.2) Compatibility with CUCM 11.5.1.12900-21
Apr 20th, 2017
Hi Guys ,
I would like to know the TSP 11.5(1.2)  Compatibility with CUCM 11.5.1.12900-21 . We are upgrading CUCM from 11.5.1.11900-26 to 11.5.1.12900-21 .
Please advise asap with Compatibility link.
Shadi Shami Fri, 04/21/2017 - 01:35
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, April 2015
Hi Waqas,
CUCM11.5(1)SU1 (i.e. 11.5.1.11900-26) comes with TSP version 11.5.1.2-0, while 11.5(1)SU2 comes with TSP version 11.5.1.4-0. so after upgrading to SU2 you need to upgrade the TSP plugin in order to avoid any issue.
P.S. having different TSP/ CUCM versions may work, but will not be fully be supported.
plugin details can be found in readme files for each CUCM release:
11.5(1)SU1: http://www.cisco.com/web/software/282074295/134530/cucm-readme-1151su1-R...
11.5(1)SU2: http://www.cisco.com/web/software/282074295/136664/cucm-readme-1151su2.pdf
Thank you,
Shadi
