What Software to use? Upgrade Unity Connection 8.x to 11.x
Answered Question
Apr 20th, 2017
I am planning an upgrade from CUC 8.6 to 11.5.  When going through the PUT file process, I have a few options for download:
UCXN11-VER-UPG-K9.iso
UCSInstall_UCOS_11.5.1.12900-21-sgn.iso
Bootable_UCINSTALL_UCOS_11.5.1.12900-21.sgn.iso
Which one will have the proper COP files needed for the upgrade?  I assume the UPG file?  Thanks
Correct Answer by Aman Soi about 2 months 4 days ago
[+5] to Rob .
I suppose u have already ordered through PUT and u have got the options to download through e-delivery.
With UCS Install iso , u can do the upgrade.
regds,
aman
Correct Answer by Rob Huffman about 2 months 4 days ago
Hi there,
I would order both;
As it's always nice to have a "bootable" version of the current products just in case a "rebuild" is ever necessary (YIKES!!)
Cheers!
Rob
Overall Rating: 5 (5 ratings)
Correct Answer
Rob Huffman Thu, 04/20/2017 - 08:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
I would order both;
Cheers!
Rob
hauchinango Thu, 04/20/2017 - 09:44
Thanks Rob.
So, the UCSInstall will also allow for an upgrade as well as a fresh install?
Correct Answer
Aman Soi Thu, 04/20/2017 - 09:54
  • Purple, 4500 points or more
    2017 IP Telephony
[+5] to Rob .
regds,
aman
hauchinango Thu, 04/20/2017 - 09:57
Thanks and ***** to Rob and Aman for the quick assist.
Rob Huffman Thu, 04/20/2017 - 09:58
  • Hall of Fame,
    Founding Member
Hi there,
You are most welcome!
Yes, but from what I understand,with newer 11.x versions you need to remove the word "bootable" from the filename when using it for upgrades.
Cheers!
Rob
EDIT: +5 to my buddy Aman for his great input here as well!
Jaime Valencia Thu, 04/20/2017 - 12:03
  • Cisco Employee,
  • Hall of Fame,
    2011
No need for that, I actually use a bootable image in my upgrade video and that created confusion as the name when you see it in the upgrade procedure in the GUI shows without "bootable".
The system will automatically recognize the file and use it, without having to rename the file or anything else.
