CVP Sig Disgit
Anil Sharma
Can anyone explain what is the use of Sig Digit in CVP
Anoop Krishnan
Hello Anil,
If you need to segregate calls by ingress gateway, this can be accomplished by CVP sig-digit feature, a special prefix that is assigned in ingress gateway. When CVP receives agent label from ICM, CVP sig-digit (a special prefix) will be prefix'ed with this digit, so CUSP can differentiate calls, and send to different SIP trunk of CUCM.
Solution Using Significant Digits / Preprend Digits feature in CVP Call Server
1. Call comes from INGRESS Site A with DID Number 19777
2. Dial-peer is matched , the 19777 is transformed to the following scheme :CodeA+Internal Project Number , i.e : 11118001
3. Call is sent to the CVP Call Server
4. CVP Call server will Capture the 1st 4 Digits and recognize them as Site Code
5. RouteRequest is sent the ICM using the VRU PG which will start the ICM Script with SendToVRU Node .
6. ICM Return the Network VRU Label which is 8111111111
7. CVP Call Server will add the Site Code again to the Label before making any decision which will be : CodeA+VRU Label , i.e : 11118111111111
8. CVP Checks the Static Routes configured and sends the Call to the corresponding VXML GW : 11118111
9. The VXML GW will accept the call coming from 111181T and start the BootStrap service .
10. Now the RTP is between the INGRESS and VXML ( the Welcome Message )
11. Invoking the QueueToSkillgroup Node to pick an available agent eventually .
12. When Agent is available , the ICM Returns the Agent Extension ( Label ) to the CVP Call Server via the CVP PG ( RC ) , for example : 4004
13. The CVP adds the Site Code to the Extension before checking the Static Routes , so the label will be : CodeA+Extension , i.e : 11114004
14. The CVP Static Routes has the following route to the Call Manager to pick the right Agent : CodeA+Extension , i.e : 11114004
15. Now the CVP Sends the Call to the Call Manager via the SIP Trunk .
16. We Add a translation route inside the Call Manager to remove the Site Code from the Incoming Called Number , like the following :
1111.! => Discard Predot .
17. Call is delivered to the Agent
Anoop
Anoop Krishnan
Hello Anil,
Anoop
