04-21-2017 06:52 AM - edited 03-01-2019 08:32 AM
Hello every body ...
I need to deploy the Best practices for the links (PO) connectivity between
Two VSS (4500) and Two Nexus (9300) ,
Q1:We will create one PO for all the 4 links between VSS & NK,, OR for Each Nexus will create on PO OR the each Nexus switch will has two PO
to connect one link from VSS-1 and second link from VSS-2 ----> Kindly see the attached file plz.
Q2: Witch better to use L2 or L3
- All L3 Vlan interface on VSS.
05-02-2017 01:38 PM
One spanned port-channel between the VSS and vPC.
Nazim
05-07-2017 04:27 AM
Thanks dear Nazim for your response,,
it will be like this:
VSS:
# interface Port-channel 100
switchport mod trunk
spanning port type network
# interface range ten 1/1/1-2 , ten 2/1/1-2
channel-group 100 mode on
N9K-1:
# interface Ethernet 1/1-2
N9K-2:
