Enable gigabit ethernet interfaces on WS-X45-Sup8L-e module
bvanovereem
I have 10 new 4506E chassis with WS-X45-SUP8L-E sup module that I need to configure. I do not have 10GB to my Distribution yet. What command do I use to enable the sup's interface to recognize GB instead of 10gb? The sup6 or sup7 command "hw-module uplink gigabitethernet" does not work on the Sup8. My Fw/OS is: 15.1(1r)SG6 / 03.08.03.E
Sw1#sho int status
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/1                        notconnect   1            full   auto No XCVR
Te1/2                        notconnect   1            full   auto No XCVR
Te1/3                        notconnect   1            full   auto No XCVR
Te1/4                        notconnect   1            full   auto No XCVR
Sw1(config)#hw-module ?
  beacon  Apply hw-module command to beacon LED
  module  Individual module in the system
  module  Specify a linecard slot for the hw-module command
  slot    Specify a linecard slot for the hw-module command
  system  Specify the system parameter
Reza Sharifi
The ports on sup-8 are 1/10. Once you insert a 1Gig SFPs into the port, it should recognized it without needing to use any command.
