ospf route summarisation : Cannot summarize
jordan-jj
I have  ospf summarisation as below
Router 0 can still view all the routes in router 2 even after summarised at router 0
Jon Marshall
You presumably mean router 1 can still view all the loopback routes on router 2 ?
If so it because you have the wrong subnet mask in your area range command and are therefore not matching any of the loopback networks.
Jon
the mask for the area range is incorrect. You need to use a /19 mask to summarize the three networks:
area 1 range 192.168.0.0 255.255.224.0
Hi Jordan
I agree with Jon and Georg, your configuration on Router0 should be:
router ospf 100
network 10.10.10.0 0.0.0.255 area 0
network 30.30.30.0 0.0.0.255 area 1
Router 1 should be the summarized network like an Inter Area network.
O IA  192.168.0.0/19 [110/21] via 10.10.10.1, 00:00:02, FastEthernet0/1
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
