04-25-2017 02:51 AM
Hi Engieer,
I have two ASA 5500 devices,and setup a VPN tunnel between J(192.168.0.x) to K(192.168.1.x) sucessfully.
I can make a static NAT just like a pravite IP to a public IP at J site. As following:
static (inside,outside) tcp A.B.C.D 1433 192.168.0.10 1433 netmask 255.255.255.255
Qustion:
Can I make a static NAT at J site through VPN tunnel?Can I access it from outside?
As following:
static (inside,outside) tcp A.B.C.D 1433 192.168.1.10 1433 netmask 255.255.255.255
Please, thanks in advance!
04-25-2017 04:59 AM
That is not gonna work, you are doing a static NAT with private IP address 192.168.1.10 on a public P address that is on an ASA that has no IP address in the 192.168.1.0 range, so even though you might be able to statically NAT that, the packet will never get routed back to that ASA from K.
I hope that makes sense.
Please rate if useful.
04-25-2017 07:41 AM
Hi Dennis,
Thanks for your reply. Can I add many route rule to forword outside trafic to the server in site K? Is it possible ?
04-26-2017 02:18 AM
It doesn't matter what you are doing, changing a static NAT with private IP address on a public P address or private ip address on a private ip address, it will work, NAT - it's not changing private IP address on a public P address, it's changing one ip address to other ip address, doesn't matter what kind of ip address is it
Hope its helpfull
