IP Phone 7821 - Problems to transfer calls
fernandodonadio
Hi, guys,
I have 7821 IP Phones, registered on CUCM 9.1 using a Cisco 2921 as Voice Gateway and I'm facing problems to transfer calls.
When making a call transfer between internal extensions, it works perfectly.
For example, ext 8741 calls to 8742, then 8742 transfers to 8743.
But when a call comes from an external number (PSTN), I can´t transfer it.
Ex: +55 11 999164584 calls to 8741, then 8741 tries to transfer to 8742,  +55 11 999164584 hears 8742, but 8742 don´t.
Thanks in advance!!
Rajan
In the given scenario
What happens when +55 11 999164584 calls 8742 directly ?  are they able to hear each other.
Rajan
7 Replies 7
Rajan
Rajan
Hi, Rajan!!
They're able to hear each other.
The problem occurs just when the call is transfered.
Hi Fernando,
In that case, check the region settings configured for the two phones to see whether any difference and try to collect packet captures from the phone where the user is unable to hear to check. Also check whether the subnet the phones are in are allowed RTP communication to the IP address of the PSTN network both ways.
Rajan
Rajan,
Both phones are using the same region settings.
Since the extension is allowed to receive calls coming from PSTN, it means the RTP communication is allowed, doesn't it?
hello rajan
thanks for replying :)
my issue not about hearing its about dialing when i dial any number its not complete the dialing and its back by its self to main display (display name i mean normal )  some times happen with me and come back again by it self ?
maybe sim card or coverage network issue?
dunt know
amr alrazzaz
User Access Verification
Password:
Password:
Router>en
Password:
Router#show run\
% Invalid input detected at '^' marker.
Router#show run
Building configuration...
Current configuration : 12299 bytes
! Last configuration change at 08:02:16 UTC Sun Jun 4 2017
version 15.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password cisco1
no aaa new-model
ip dhcp relay information trust-all
ip dhcp pool voice
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
option 150 ip 192.168.2.207
dns-server 8.8.8.8 8.8.4.4
ip dhcp global-options
dns-server 163.121.128.134 163.121.128.135
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
registrar server
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.10-1-1-9.loads
timezone 25
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0000212587445943
network-locale GB
voice register dn 1
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
name Ahmos Elquadi
label Ahmos Elquadi
mwi
voice register dn 8
number 103
name Sherif Ehab
label Sherif Ehab
mwi
voice register dn 9
number 104
name Khaled Elgarhy
label Khaled Elgarhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Amr Ismail
label Amr Ismail
mwi
voice register dn 12
number 108
name Mohamed Abdella
no-reg
label Mohamed Abdella
mwi
voice register dn 13
number 109
name Sales 1
label Sales 1
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Meeting Room B
label Meeting Room B
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Finance
label Finance
mwi
voice register dn 19
number 113
name Marketing
label Marketing
mwi
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
username romani password cisco
codec g711ulaw
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
username cisco password 0 cish:
username romani secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
redundancy
process-max-time 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.2.207 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.1.207 255.255.255.0
ip nat outside
ip rip advertise 100
ip rip receive version 2
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.2.0
ip default-gateway 192.168.2.207
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:
ip dns view default
dns forwarder 8.8.8.8
ip dns server
ip nat inside source list 150 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
snmp-server community public RO
tftp-server flash:kern78xx.10-1-1-9.sbn
tftp-server flash:rootfs78xx.10-1-1-9.sbn
tftp-server flash:sboot78xx.10-1-1-9.sbn
tftp-server flash:sip78xx.10-1-1-9.loads
tftp-server flash:rootf2
access-list 150 permit ip any any
control-plane
voice-port 0/0/0
trunk-group Mobile
connection plar opx 100
description Configured by 2911 4 FXO-0/0/0-Custom
caller-id enable
voice-port 0/0/1
trunk-group Mobile
description Configured by 2911 4 FXO-0/0/1-Custom
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
corlist outgoing mobile-long
description **shortcut No**
destination-pattern 91[16789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
dial-peer voice 2000 voip
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
destination-pattern 902.......T
forward-digits 8
prefix 02
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 5 pots
trunkgroup long
trunkgroup Mobile
description **10th of Ramadan**
destination-pattern 9015.T
prefix 015
dial-peer voice 6 pots
trunkgroup long
description **Kaluobia**
prefix 013
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 22 pots
service stcapp
port 0/0/2
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
ip source-address 192.168.2.207 port 2000
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
max-conferences 8 gain -6
web admin system name romani password cisco
web admin customer name romani1 password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Jeries Alghwaly
name Mr. Jeries Alghwaly
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 5
line con 0
password xxxx
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password xxx
login
transport input none
scheduler allocate 20000 1000
end
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
Router#
amr alrazzaz
this is my router 2911 config , should i do any additional config ?
amr alrazzaz
