NAT and ACL configuration
Apr 25th, 2017
It's been a while since the last time I worked on a router config. I'm having issues giving the inside network access to the internet via the GigabitEthernet0/0/0 interface. In the end I would like to have a redundant route to go out the GigabitEthernet0/0/1 interface but I will work on that once get the traffic flowing out of the primary network. Below is the start of my config. Can someone tell me what I am missing? Is my NAT or ACL wrong? Thanks in advanced.
Current configuration : 1745 bytes
! Last configuration change at 17:17:30 UTC Tue Apr 25 2017
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging buffered
enable password <Removed>
no aaa new-model!
subscriber templating
license udi pid ISR4331/K9 sn FDO20450SH5
username <Removed> privilege 15 password <Removed>
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description Primary Network
ip address <IP Removed>
ip nat outside
ip nat allow-static-host
negotiation auto
interface GigabitEthernet0/0/1
description Secondary Network
ip address <IP removed>
ip nat outside
negotiation auto
interface GigabitEthernet0/0/2
description To ASA Port 0
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip access-group 100 in
ip access-group 100 out
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 204.148.103.197
ip route 0.0.0.0 0.0.0.0 70.107.239.1 10
access-list 100 permit ip any any
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password <Removed>
login
end
Overall Rating: 4.3 (6 ratings)
singhkulbir29881 Thu, 04/27/2017 - 01:29
  • Bronze, 100 points or more
You have missed the nat statement. Please add the following Nat statement:-
ip nat inside source list 100 interface gig0/0/0 overload
snoto1974 Thu, 04/27/2017 - 06:21
Thanks. I want to use gig0/0/1 as the backup. Do I need the same command for the gig0/0/1 interface? I already added the weighed route for this interface.
singhkulbir29881 Thu, 04/27/2017 - 06:38
Yes, but you need to setup ip sla as well to track the route and need to add some additional commands as well to achieve the failover/redundancy.
ip route 4.2.2.2 255.255.255.255 204.148.103.197
ip sla 1
icmp-echo 4.2.2.2 source-ip < GigabitEthernet0/0/0 interface IP >
frequency 15
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
delay down 45 up 15
no ip route 0.0.0.0 0.0.0.0 204.148.103.197
ip route 0.0.0.0 0.0.0.0 204.148.103.197 track 1
route-map PRIMARY permit 10
match ip address 100
match interface GigabitEthernet0/0/0
route-map SECONDARY permit 10
match interface GigabitEthernet0/0/1
no ip nat inside source list 100 interface gig0/0/0 overload
no ip nat inside source list 100 interface gig0/0/1 overload
ip nat inside source route-map PRIMARY  interface GigabitEthernet0/0/0 overload
ip nat inside source route-map SECONDARY  interface GigabitEthernet0/0/1 overload
event manager applet NAT-TRACK
event syslog pattern "TRACKING-5-STATE"
action 0.1 cli command "enable"
action 0.2 wait 3
action 0.3 cli command "clear ip nat translation *"
action 0.4 syslog msg "NAT translation cleared after track state change"
If this is helpful please rate this or marked as an answered if you get solution to this. :-)
snoto1974 Wed, 05/03/2017 - 14:39
I added everything to the config but when I add the following command I can no longer reach (ping, SSH) the public interface.
If I console into the router I'm able to ping public IP addresses. The good thing is, the NAT appears to be working.
Any ideas on why I cannot reach the public IP of the router? I've had Cisco TAC look at the config and they can't find anything wrong with the config.
snoto1974 Wed, 05/03/2017 - 14:45
Here is the latest config.
Current configuration : 2443 bytes
version 15.5
hostname CokeTSRouter
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging buffered
no aaa new-model
redundancy
mode none
delay down 45 up 15
ip address <Removed> 255.255.255.252
ip nat outside
negotiation auto
ip address <Removed> 255.255.255.0
ip nat outside
negotiation auto
ip nat inside
negotiation auto
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
ip http server
ip sla 1
icmp-echo 4.2.2.2 source-ip 204.148.103.198
frequency 15
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password <Removed>
login
action 0.2 wait 3
end
singhkulbir29881 Wed, 05/03/2017 - 15:10
Please add the primary route with track. Like the following
You can reach the primary (ping,ssh) but when primary goes down then you can reach to backup. Only one at a time (which is acting as primary)as many of the provider will not allow the traffic coming from the subnet that does not belong to them.
Please rate if this is helpful.
snoto1974 Wed, 05/03/2017 - 15:51
Sorry I originally have that route in the config but when it didn't work I took it out during troubleshooting and I forgot put it back.
Anyway, I added the route with track and I am still having the same issue.
singhkulbir29881 Thu, 05/04/2017 - 00:06
Run the icmp debugs and check that traffic is hitting the router or not
"debug ip icmp"
snoto1974 Thu, 05/04/2017 - 07:29
I already had icmp debugging on and my pings are not generating any logs.
A traceroute never makes it to router gateway 70.107.239.1
1 <1 ms <1 ms <1 ms 172.19.7.2
2 <1 ms <1 ms <1 ms 43.147.144.20
3 * * * Request timed out.
4 1 ms 1 ms 1 ms 12.166.247.1
5 5 ms 4 ms 4 ms 12.88.84.9
6 8 ms 6 ms 5 ms cr81.brhal.ip.att.net [12.123.22.14]
7 6 ms 5 ms 5 ms 12.122.29.53
8 4 ms 5 ms 3 ms 0.ae10.br3.atl4.alter.net [204.255.168.253]
9 * * * Request timed out.
10 23 ms 25 ms 23 ms a4-0-0-1737.ny325-dsl-rtr14.verizon-gni.net [130.81.9.182]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
snoto1974 Thu, 05/04/2017 - 10:25
I think I may have figured it out. I removed the "any any" acl and replaced it with a specific ACL. I can now reach the outside interface of the router. I still have some more testing but so it looks to be working. Thank you so much for all your help.
singhkulbir29881 Thu, 05/04/2017 - 23:04
Great. Please rate or marked your question as answered.
snoto1974 Fri, 05/05/2017 - 05:37
Well I spoke to soon. I have access to the outside interface but I broke the NAT. I will continue to work on it today.
singhkulbir29881 Fri, 05/05/2017 - 05:42
Hi snoto,
This is because same access list 100 is used in NAT as well. So keep access-list 100 as the same (access-list 100 permit ip any any) and use another access-list like 101 for interface ACL.
snoto1974 Thu, 05/04/2017 - 07:02
Below is the output of the show ip route command. The primary line is currently disconnected.
Gateway of last resort is 70.107.239.1 to network 0.0.0.0
S* 0.0.0.0/0 [10/0] via 70.107.239.1
70.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 70.107.239.0/24 is directly connected, GigabitEthernet0/0/1
L 70.107.239.211/32 is directly connected, GigabitEthernet0/0/1
Vipin Sharma Fri, 05/19/2017 - 06:49
Hi singh,
This post is very helpful. Thanks for sharing your knowledge.
