DCNM Session Expires
kaklein
Is there a way to keep my DCNM session from expiring and forcing me to log back in.  Makes it difficult to manage a network when your session expires.
Manish Gogna
You can try the following:
1. From the DCNM WebUI, Admin --> Server Properties. Search for 'timeout' and set the time for 3600 seconds. This page should be tied to the server.properties file. You might want to double check that the file has been updated after a reboot.
2. Next, change the <Session-timeout>x<session-timeout> parameter in the file, $INSTALLDIR\dcm\jboss-4.2.2.GA\server\fm\deploy\jboss-web.deployer\conf\web.xml This one can be set to 60 minutes , server reboot.
Manish
- Do rate helpful posts -
Thanks Manish,  but I'm not finding the web.xml file for dcm
Can you check  Sessiontimeout in web.xml under the following path
[DCNM_HOME]/jboss*/server/fm/deploy/jboss-web.deployer/conf
Manish
