Radio is disabled. Turn ON radio to enable CleanAir functionality
Eric
I got this message on my outdoor AP 1562i. I don't know how I can fix it.
Helppppppp!
BR
Pls check the radio status of the AP. As message said, since radio is down, not able to run clean air
Rasika
Rasika
I don't know why radio was down in some AP and up in others. It's true that when you change manually the status to up, it works better.
APs status goes down because of PoE. When I set power inline to 30000mW, some APs don't work.
I changed to power inline auto.
Thanks you
Eric
Please check POE in the switch, the ap needs:
  Universal Power of Ethernet (UPoE), 802.3at
When aps dont have enough POE they will disable radios.
www.cisco.com/c/en/us/products/collateral/wireless/aironet-1560-series/datasheet-c78-737416.html
