04-26-2017 10:46 PM - edited 03-12-2019 02:16 AM
Is it possible to restore a working configuration from an ASA5520 to a ASA5510
04-27-2017 12:21 AM
Not directly - you would have to modify it to account for the different interface names. (By default 5510 does not have any Gigabit Ethernet interfaces, Security Plus license converts 2 Fast Ethernet interfaces to Gigabit)
Software version and licensing (if using any non-default licensed features like HA, AnyConnect SSL VPN, contexts, etc.) would also need to match. You would need to have any files (like ASDM binary, AnyConnect images etc.) and certificates' private keys on the 5510 as well.
04-27-2017 01:16 AM
Thank you so much sir for the prompt response. i will work on it and update you.
