Conversation between CCME with internal extensions
jchevalon
I have 2 new links to set up to the DRC and Conakry with a CCME
I have configured but I have errors, here are debugs and config.
No calls possible...
Do you have an idea?
I had already had problems for a connection on this post: https://supportforums.cisco.com/discussion/13202881/conversation-between-2-ccme-internal-extensions
But I have the impression that it is not the same problem
Thanks in advance
9 Replies 9
Manish Gogna
From the running config of the CME that you shared there are 3 VoIP dial peers which can send the call out to another IP destination, the possible called number patterns are
destination-pattern 237.....
destination-pattern 224.....
destination-pattern 243....
Are you dialing these patterns from the IP phones registered on this CME?
if yes and the call still fails then please share complete "debug ccsip messags" and "debug voice ccapi inout" for a test call that fails. The debugs would be required from both CME's.
Manish
Thanks Manish,
Yes, i dial these patterns from the IP phones registered on this CME.
I try to make a "debug voice ccapi inout" tomorrow and come back
237 works for information.
In the first debug attached i can see the extension 60 dialing 22401204 and it matches outgoing dial-peer 20 where the translation profile call-conakry strips the 224 and forwards just 01204. When you make this test do you see the call reaching the other CME?  I would suggest not stripping the 224 digits on this CME, but let it be routed on the target CME and do the translation there as per the dialplan and test.
Manish
Hi Manish,
Thanks again
I confessed that my level cme is not very high ...
Indeed it tries to connect to the remote CME but does not transmit the correct number.
My translation rule should be able to transfer the complete number.
Do you see how I could change it by chance?
thanks a lot
If you have the complete extension configured on the target CME then just remove the translation profile call-conakry from dial-peer 20 and test.
dial-peer voice 20 voip
no translation profile call-conakry
Manish
- Do rate helpful posts -
Hi Manish,
I have try with no success, I get logs as soon as possible
Here is "debug voice ccapi inout"  and "debug ccsip messages" tests for Conakry with your last recommandation.
Thanks in advance ;)
Hi Manish,
Here is "debug voice ccapi inout"  and "debug ccsip messages" tests for Conakry and RDC
thanks in advance for your help
Hi, do you have an idea for me ;)
