CUAC 10.5.1 Physical to VM migration
vijit kumawat
Has anyone used Vmware P2V converter ?
I planning to migrate CUAC 10.5.1 from a physical box to a VM, wanted to confirm if there are any risk in using vmware P2V converter to migrate CUAC.
Please let me know if it is safe.
Thanks in advance
Manish Gogna
Hi Vijit,
As per the following link
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-software-requirements.html#converter
VMware vCenter Converter
P2V tools are not supported. To migrate from bare-metal servers (e.g. Cisco 7800 Series Media Convergence Server) to UC on UCS, the supported procedure is:
  • upgrade to 8.x software version on the bare-metal server
  • take a software backup
  • fresh install 8.x software on VMware / UC on UCS
  • restore from backup
Manish
- Do rate helpful posts -
Joe Price
Attendant Console you would be fine.  You will have to rehost the license.  I've done this before.  Its not technically supported but its not a big deal and you can always go back to using the physical if something does happen.
