I want to need a firewall which must have to the following criteria.
1. Firewall performance (Large packets) 19.5 Gbps with multiprotocol performance of 9.6 Gbps
2. IPS and App visibility combine performance should be 5.5 Gbps
3. Firewall should support maximum 1,750,000 concurrent connections
4.Firewall should support maximum 115,000 new connections per second
5.Should deliver VPN throughput of 2.8 Gbps
6.Firewall should support upto 240 virtual context/firewall
7.VPN supporting 10000 IPSec / SSL VPN peers
8.Next Gen FW feature should be included.
Please suggest me
Shuvo
