How to allow Only https to communicate with the Office web server
Hi All,
I have a ASA 5505 Firewall Installed in our network. On our office network there is a SQL Server running that communicates with our website for live data.
I need only https communication to occur between the webserver and our internal server.
at present I have 2 rules applied as below/attached.
xx.xx.xx.40 is the leased line.
The problem with the present setting is that there are failed login attempts to SQL Server hence I need to secure it.
Thank you
The highlighted line allows SQL from the whole internet to your internal server which is always a bad idea (same for line 10). This line should be removed. And if the webserver only needs HTTPS, then also the line 8 can be removed.
