API REST FXOS chassis 9300 or 4100 Firepower
Answered Question
May 3rd, 2017
I was reading the below documentation about API REST of chassis (FXOS):
https://developer.cisco.com/site/ssp/firepower/
But I haven't found more information (only it is mentioned at http://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/fxos211/cli...) about FXOS API REST.
I have two pairs of 4100 Firepower and two pairs of 9300 Firepower, and they are connected to FMC 4000. I was trying to configure both pairs from API FXOS but I couldn't authenticate to FXOS API. FMC REST API is working and I can make GET, POST, etc.
Any idea about more information about FXOS API?
My request via POSTMAN is:
POST https://<Firepower Chassis_chassis_fqdn>[:management_port]/api/login
with HTTP Headers
Content-type HTTP set to application/json
USERNAME = <name of the user>
PASSWORD = <url_encoded_password>
Output is:
ERROR 400 with Payload
"error-code": "551",
"error-description": "Authentication failed",
"error-nr": "unidentified-fail"
Thank you in advance.
Correct Answer by Veronika Klauzova about 4 weeks 1 day ago
So what output you see after using adjusted command which I have shared? Sill same error 552 as before?
Full command to be used:
curl -X POST -v -k -H "Authorization: Basic YWRtaW46VmtsYXV6b3YxMjM=" https://192.168.0.38/api/login --insecure -H "USERNAME=admin" -H "\
> Authorization:Basic YWRtaW46VmtsYXV6b3YxMjM=
> USERNAME:admin
> PASSWORD:Admin12345
> //Content-Type:application/x-www-form-urlencoded\
Just keep in mind to change IP address 192.168.0.38 to your IP address of Firepower Chassis Manager / FXOS manager along with proper credentials, rest of the command attributes you can keep as above.
Overall Rating: 5 (1 ratings)
neipatel Wed, 05/03/2017 - 08:10
  • Cisco Employee,
josemaria.perez,
Have you tried using basic authorization rather than directly adding the fields to the header? This will ensure that the encoding is done properly and should return a token back in the header for use in all subsequent requests.
JOSE MARIA PERE... Thu, 05/04/2017 - 08:56
Hi neipatel:
Thanks for your helping. For example, If I make a curl to FMC 4000 to request the token, basic auth works but I have tried it for this case and I have the same output error. I have checked from Postman and CLI.
$ curl -k --user username:password https://<Firepower Chassis_chassis_fqdn>/api/login
Cache-Control: no-store, must-revalidate
Content-type: application/json
{"error-code": "552", "error-description": "Authorization required", "error-nr": "service-unavailable"}
Anybody know that it is working this API? FMC API is OK.
Veronika Klauzova Tue, 05/16/2017 - 13:27
  • Cisco Employee,
What FCM/FXOS version are you using?
I have tried now on FXOS 2.1.1.77 and it is working fine, here is syntax as an example that you can use:
$ curl -X POST -v -k -H "Authorization: Basic YWRtaW46VmtsYXV6b3YxMjM=" https://192.168.0.38/api/login --insecure -H "USERNAME=admin" -H "\
> USERNAME:admin
> PASSWORD:Admin12345
* Trying 192.168.0.38...
* Connected to192.168.0.38 (192.168.0.38) port 443 (#0)
* TLS 1.2 connection using TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
* Server certificate: FPR4100
> POST /api/login HTTP/1.1
> Host:192.168.0.38
> User-Agent: curl/7.43.0
> Accept: */*
> USERNAME:admin
> PASSWORD:Admin12345
< HTTP/1.1 200 OK
< Date: Tue, 16 May 2017 20:22:41 GMT
< Server: Apache/2.4.16 (Unix) CiscoSSL/1.0.2j.6.0.269-fips
< Set-Cookie: SSA_C=2e85c9ea-9997-40d5-9f61-5805170417f9; Path=/; secure; Version=1
< Set-Cookie: SSA_T="1494966162/ea1cc996-7eff-4ba5-b95f-409fcfa34d5d"; httponly; Path=/; secure; Version=1
< Set-Cookie: SSA_U=admin; httponly; Path=/; secure; Version=1
< X-Frame-Options: SAMEORIGIN
< Cache-Control: no-cache, no-store
< Pragma: no-cache
< Transfer-Encoding: chunked
< Content-Type: application/json
{"token": "1494966162/ea1cc996-7eff-4ba5-b95f-409fcfa34d5d", "refreshPeriod": "600"}
* Connection #0 to host192.168.0.38 left intact
Enjoy,
Veronika
JOSE MARIA PERE... Thu, 05/25/2017 - 03:55
Hi Veronika,
Thank you very much for your helping. The version of FXOS is 2.1.1.64 and FMC is 6.2.0. I have tried but it doesn't work for 4100 chassis. I will update firmware and FXOS next week and I will retry to connect to API.
All the best.
Correct Answer
Veronika Klauzova Thu, 05/25/2017 - 05:31
  • Cisco Employee,
> USERNAME:admin
> PASSWORD:Admin12345
JOSE MARIA PERE... Thu, 05/25/2017 - 08:37
Hi Veronika:
Now, it is working. I have the same output and I have the token :) . I think that my error was to encode my password wrong for the basic authentication.
It is working at 4100 and 9300 series.
Also, I have modified your POST request. I have deleted two headers, modified Content-Type to application/json (documentation from CISCO say: "All REST API clients must send an HTTP Accept Header that is set to application/json" from https://developer.cisco.com/site/ssp/firepower/) and curl command should be:
curl -X POST -v -k https://yourFXOS_IP/api/login --insecure -H "\
USERNAME:admin
PASSWORD:admin12345
//Content-Type:application/json\
For me, it is working.
Veronika Klauzova Thu, 05/25/2017 - 08:39
  • Cisco Employee,
You're welcome, you saved some time with upgrade that was not necessary. Glad that it works now.
By the way thanks for sharing Cisco recommendations and relevant doc.
