05-08-2017 08:23 AM - edited 03-17-2019 10:16 AM
Dear All,
I am unable to view licenses usage in ELM. It says ELM is operating in demo mode.
I would like to know how many licenses are remaining, so that I could plan accordingly.
See attached image.
Thanks in advance
Syed
Solved! Go to Solution.
05-08-2017 08:26 PM
Hi Syed,
You are seeing the license usage of IP phones which u have added in Call Manager and same is in DEMO .
You can see "Installed" figures in attached snapshot as 0
Did u ever generate the licenses on your own or got from licensing@cisco.com and uploaded in ELM?
If not, u need to do that .Once done, Demo will disappear.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116130-config-cucm-elm-00.html
regds,
aman
05-08-2017 08:36 AM
Hi Syed,
Have you tried rebooting ELM as yet?
JB
05-08-2017 08:47 AM
Hi Syed,
I do not find any "Product Instance" created in ELM. Can u create and upload the new lic file?
regds,
aman
05-08-2017 09:44 AM
Hi Aman,
I am new ELM, could you help with this, please?
@JB: I have restarted ELM but no luck.
For your information ELM is not used so far.
05-08-2017 10:09 AM
Hi Syed,
You need to create a Product Instance first in ELM and do the synchronisation.
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-license-manager/200224-Troubleshoot-Common-Issues-in-ELM-PLM.html
regds,
aman
05-08-2017 11:46 AM
Aman,
As guided, I have added product instance.
But I am still see the operating in demo mode warning.
Also, under license usage status shows demo, what does that mean?
I am not able to make out how many licenses are remaining to use.
It shows unused minus (-).. See attached image.
Could you help me understand this, please?
05-08-2017 12:45 PM
There are no License Installed in CUCM.
LogIn in CUCM and Check Under Services> Licensing Menu for Usage.
05-08-2017 12:57 PM
Hi Haris,
i am seeing all the licenses info in CUCM as attached.
i have added 250 phones yesterday.
Where do I find exact license usage?
05-08-2017 08:26 PM
Hi Syed,
regds,
aman
05-08-2017 08:57 AM
Hi JB,
No, not yet.
Does it impact cucm if I restart ELM through GUI?
05-08-2017 09:31 AM
Hi Syed,
No it would not,
JB
05-09-2017 12:03 AM
No, I did not generate any.
However, you have answered my question, thank you so much for your time.
Thank you, JB & Haris
05-09-2017 12:09 AM
Hi Syed,
Happy to help, you can get more information regarding general troubleshooting steps for ELM from link below.
JB
05-09-2017 01:40 AM
So, until new license is not uploaded I cannot find the remaining licenses info?
There must be provision for this, isn't there?
05-09-2017 01:52 AM
Licensing team should always have that information with them, send an email to licensing@cisco.com to get the details.
(Rate if it helps)
JB
