05-10-2017 11:22 AM
I am trying to configure a snmp group that would allow snmpset command against the ifAdminStatus OID. If i configure a user on snmp group/role network-admin i can use the snmpset to up/down a interface. How would i create a custom role that only allow snmpset aganist ifAdminStatus OID?
Solved! Go to Solution.
05-11-2017 07:48 AM
You can automate that with EEM script.
05-10-2017 01:24 PM
On good ole Cisco routers you can do the "snmp-server view" command and restrict all kinds of OID's. This aint gonna happen on the NX-OS.
So tell us the "why", you want to do the snmpset for ifAdminStatus. I am trying to think of other solutions if that may help
05-11-2017 06:10 AM
i wanted a way for the user to down/up a interface using a script they can run.
05-11-2017 07:48 AM
07-21-2017 10:20 AM
As we all know the SNMP view is not available in NX-OS, however if you want to create a group to specify a single OID you can configure a RBAC, see documentation below :
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/CLIConfigurationGuide/sec_rbac.html#71793
Example:
role name Allow_OID
rule 1 permit read feature snmp
rule 2 permit write feature snmp
rule 3 deny read oid 1.3.6.1.2.1.2.2.1.7 (ifAdminStatus )
Then just assign an user to the new group created.
Hope it helps.
Claudio G
