connection vpn problem
tom.vanwinkel
I have setup a tunnel vpn from my RV320 to a barracuda F400.
That works well. I can connect to my work with that tunnel config. Rdp, shares everything works.
Today I've setup vpn cisco client (built in on mac) setup VPN server on my rv320.
I have a connection and can ping my nas at home. 192.168.0.100
But I can't ping my work servers via the client vpn.
Can anybody help me out?
how is the VPN server on the RV320 coonfigured ? Have you tried Easy VPN (as described in the link below) ?
https://www.broadbandbuyer.com/features/2457-how-to-set-up-an-employee-to-work-from-home/
Easy vpn is working
If it was'nt I could not connect to my nas.
Perhaps it is an ip range issue?
Network of my work is 10.1.1.0
Home network is 192.168.0.0
and thanks for your reply
Tom
Perhaps did could help?
####sysconfig####
[VERSION]
VERSION=71
MODEL=RV320
SSL=0
IPSEC=0
PPTP=0
PLATFORMCODE=RV0XX
VENDORCODE=ls
SERIALNO=NKS210100CA
SIZE=0
NUM_LAN=4
NUM_WAN=2
NUM_DMZ=0
NUM_USB=2
SWITCH_TYPE=320
WAN5_DMZ=0
SPF_NUMBER=1
MINOR_TYPE=0
LEDTYPE=3
UI_NUM_LAN=4
UI_NUM_WAN=2
SUM=YES
[SYSTEM]
HOSTNAME=router02af00
DOMAINNAME=router02af00.com
DOMAINCHANGE=0
USERNAME=cisco
PASSWD=3be7688cbf528ad5047322ab2c2c8fce
PD_LENGTH=8
PD_CLASS=3
PD_DIFFERENT=0
PD_USERNAME=cisco
PD_STR_METER_SHOW=checked
PD_AGING_TIME=180
PD_AGING_DATE=0
PD_IDLE_TIMEOUT=10
CONFIG_TIME_STAMP=1494667977
GUEST_ENABLE=NO
GUSERNAME=guest
GPASSWD=guest
LOGOUT=0
LAN=192.168.0.1
LANMASK=255.255.255.0
LANMAC=2C331102AF00
LANINTERFACE=eth0
BRINTERFACE=br0
NTPSTATUS=NO
TIMEZONE=Brussels
TIMEENABLED=YES
DAYLIGHTSAVING=YES
DAYLIGHTSAVING_MODE=0
DAYLIGHTSTARTDATE=06:25:12:00
DAYLIGHTENDDATE=12:25:12:00
DAYLIGHTSTARTDATE_RECUR=06:2:2:12:00
DAYLIGHTENDDATE_RECUR=12:3:3:12:00
DAYLIGHT_SAVING_OFFSET=0
NTPSERVER=time.nist.gov
QBUTTON=NO
MULTIWANMODE=1
QTYPE=1
IPBASE=0
SBASE=0
SBFLUSH=0
LANGUAGE=ENGLISH
WAN_NUMBER=0
IMAGESIZE=0
IPTYPE=0
V6LAN=fc00::1
V6PREFIX=7
PPPDMODE=100
CONFIG_TIME_STAMP=0
FIRSTLOGIN=0
SHOWSTARTPAGE=0
VPN_MAXNUM=50
NATACC=1
PROCESS=0
FL=0
UPLOAD_STATUS=0
[WAN1]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMASK=255.255.255.0
WANMAC=2C331102AF01
WANINTERFACE=eth1
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=2C331102AF01
WANCONNECTION=0
DMZHOST=0.0.1.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
INTERNALLANIP1=0.0.0.0:0
INTERNALLANIP2=0.0.0.0:0
INTERNALLANIP3=0.0.0.0:0
INTERNALLANIP4=0.0.0.0:0
INTERNALLANIP5=0.0.0.0:0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
USERSPECIALDNS_V6=NO
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4=192.88.99.1
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6IN4_REMOTE_V4=0.0.0.0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
ALIAS=0
[WAN2]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=2C331102AF02
WANINTERFACE=eth2
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=2C331102AF02
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
ALIAS=0
[WAN3]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222211
WANINTERFACE=eth3
AUTOMTU=1
MTU=1492
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=0
WANCONNECTION=2
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
ALIAS=0
[WAN4]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth4
AUTOMTU=1
MTU=1492
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=0
WANCONNECTION=2
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
ALIAS=0
[WAN5]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth5
AUTOMTU=YES
MTU=1500
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=0
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
[WAN6]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth6
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=0
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
[WAN7]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth7
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=0
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
[WAN8]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth8
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
PPTPSERVER=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
USERPPPOEDNS=NO
PPPOEDNS1=0.0.0.0
PPPOEDNS2=0.0.0.0
PPPOEDNS3=0.0.0.0
PPPOEDNS4=0.0.0.0
MACCLONE=0
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
[WAN9]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth9
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
MACCLONE=0
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
[WAN10]
WANTYPE=WAN
OLDWANTYPE=WAN
WAN=0.0.0.0
WANMAC=000EA0222222
WANINTERFACE=eth10
AUTOMTU=1
MTU=1500
GATEWAY=0.0.0.0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
MACCLONE=0
WANCONNECTION=0
DMZHOST=0.0.0.0
UPSTREAMBW=10000
DOWNSTREAMBW=10000
DMZTYPE=SUBNET
RANGE=0.0.0.0:0
INTERFACE=0
WAN_V6=::
PREFIXLENGTH=64
AUTOMTU_V6=1
MTU_V6=1500
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
WANCONNECTION_V6=0
DMZTYPE_V6=SUBNET
DMZ_RANGE_START=::
DMZ_RANGE_END=::
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
PPPOE_SHARE=0
DHCPPD=YES
DHCPPD_TYPE=3
REMOTE_V4_MASK=0
REMOTE_V6=::
6IN4_V6=::
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
6RD_MODE=0
[USB1]
INTERFACE=ppp3000
SYSTEMPROVIDER=
LINKSTATUS=0
CONNECTIONTYPE=1
UPSTREAMBW=256
DOWNSTREAMBW=2048
MTU=1500
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
[USB2]
INTERFACE=ppp3001
SYSTEMPROVIDER=
LINKSTATUS=0
CONNECTIONTYPE=1
UPSTREAMBW=256
DOWNSTREAMBW=2048
MTU=1500
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
[SMARTLINK]
PRIMARY=WAN1
[ISP1]
WAN=81.82.215.225
WANMASK=255.255.192.0
MTU=1500
GATEWAY=81.82.192.1
DNS1=195.130.131.3
DNS2=195.130.130.3
DNS3=0.0.0.0
INTERFACE=eth1
STATE=1
NSDOK=1
LINKUP=0
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth1
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP2]
WAN=0.0.0.0
WANMASK=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth2
STATE=0
NSDOK=0
LINKUP=0
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth2
STATE_V6=0
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP3]
WAN=0.0.0.0
WANMASK=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth3
STATE=0
NSDOK=0
LINKUP=0
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth3
STATE_V6=0
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP4]
WAN=0.0.0.0
WANMASK=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth4
STATE=0
NSDOK=0
LINKUP=0
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth4
STATE_V6=0
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP5]
WAN=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth5
STATE=1
NSDOK=1
LINKUP=1
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth5
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP6]
WAN=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth6
STATE=1
NSDOK=1
LINKUP=1
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth6
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP7]
WAN=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth7
STATE=1
NSDOK=1
LINKUP=1
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth7
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP8]
WAN=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth8
STATE=1
NSDOK=1
LINKUP=1
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth8
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP9]
WAN=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth8
STATE=1
NSDOK=1
LINKUP=1
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth9
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ISP10]
WAN=0.0.0.0
MTU=1500
GATEWAY=0.0.0.0
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
INTERFACE=eth8
STATE=1
NSDOK=1
LINKUP=1
COD_WAN=0.0.0.0
COD_WANMASK=0.0.0.0
COD_GATEWAY=0.0.0.0
PID=0
WAN_V6=::
GATEWAY_V6=::
DNS1_V6=::
DNS2_V6=::
INTERFACE_V6=eth10
STATE_V6=1
LANPREFIX_V6=::
LANPREFIXLEN_V6=64
REMOTE_V4_MASK=0
6RD_PREFIX=32
6RD_V4=0.0.0.0
6RD_V6=::
DHCP_GATEWAY_V6=::
RA_GATEWAY_V6=::
[ROUTER1]
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
ROUTERIP1=0.0.0.0-0.0.0.0
ROUTERIP2=0.0.0.0-0.0.0.0
ROUTERIP3=0.0.0.0-0.0.0.0
ROUTERIP4=0.0.0.0-0.0.0.0
ROUTERIP5=0.0.0.0-0.0.0.0
ROUTERIP6=0.0.0.0-0.0.0.0
LANALIAS=0
DMZALIAS=0
[ROUTER2]
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[ROUTER3]
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[ROUTER4]
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[ROUTER5]
INTERFACE=WAN1
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[ROUTER6]
INTERFACE=WAN1
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[ROUTER7]
INTERFACE=WAN1
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[ROUTER8]
INTERFACE=WAN1
GATEWAY1=0.0.0.0
GATEWAY2=0.0.0.0
GATEWAY3=0.0.0.0
[DHCP]
SERVER=YES
GATEWAY=192.168.0.1
MASK=255.255.255.0
TIMEOUT=86400
WINSERVER=0.0.0.0
WINSERVER2=0.0.0.0
RANGE=192.168.0.100:192.168.0.149
DNS1=0.0.0.0
DNS2=0.0.0.0
STYPE=1
PERPAGENUM=5
[DHCP_V6]
SERVER=1
GATEWAY=fc00::1
TIMEOUT=86400
RANGE_START=fc00::100
RANGE_END=fc00::17f
DNS1=::
DNS2=::
NUMBER=0
PERPAGENUM=5
PERPAGENUM2=5
[DHCP_SUBNET1]
ENABLED=YES
SERVERIP=192.168.0.1
MASK=255.255.255.0
MATCH_CRITERIA=1
MAC_NUMBER=0
VLAN_NUMBER=0
[DHCP_SUBNET2]
ENABLED=NO
SERVERIP=192.168.2.1
MASK=255.255.255.0
RANGE=192.168.2.100:192.168.2.149
MATCH_CRITERIA=1
MAC_NUMBER=0
VLAN_NUMBER=0
[DHCP_SUBNET3]
ENABLED=NO
SERVERIP=192.168.3.1
MASK=255.255.255.0
RANGE=192.168.3.100:192.168.3.149
MATCH_CRITERIA=1
MAC_NUMBER=0
VLAN_NUMBER=0
[DHCP_SUBNET4]
ENABLED=NO
SERVERIP=192.168.4.1
MASK=255.255.255.0
RANGE=192.168.4.100:192.168.4.149
MATCH_CRITERIA=1
MAC_NUMBER=0
VLAN_NUMBER=0
[DHCP1]
CLIENT=YES
[DHCP2]
CLIENT=YES
[DHCP3]
CLIENT=YES
[DHCP4]
CLIENT=YES
[PPPOE1]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
UNNUMBERED_WAN=0.0.0.0
UNNUMBERED_WANMASK=0.0.0.0
UNNUMBERED_SRANGE=0.0.0.0:0.0.0.0
UNNUMBERED_ERANGE=0.0.0.0:0.0.0.0
[PPPOE2]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[PPPOE3]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[PPPOE4]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[PPPOE5]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[PPPOE6]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[PPPOE7]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[PPPOE8]
STATUS=NO
USERNAME=
PASSWORD=
SERVICE=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
LASTPEERMAC=
LASTSESSION=
ECHOPERIOD=30
ECHOTIMES=5
[USBPPP1]
WAN=0.0.0.0
WANMAC=
WANMASK=0.0.0.0
GATEWAY=0.0.0.0
NETWORKSTATUS=
APN=
DIALNUMBER=*99#
USERNAME=
PASSWORD=
BACKUP=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
AUTOMTU=YES
MTU=1500
AUTOUDATE=NO
UPDATEPERIOD=30
PINCODEPROTECT=NO
PINCODE=
PUKCODE=
ERRORTIME=0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
CHARGTYPE=0
BASICTRAFFICKBYTE=
BASICTRAFFICDOLLAR=
ABOVETRAFFICRATE=
TRAFFICDETECT=NO
TRAFFICTHRESHOLD=
BASICTIMEMINUTE=
BASICTIMEDOLLAR=
ABOVETIMERATE=
TIMEDETECT=NO
TIMETHRESHOLD=
USBSERIAL1=
USBSERIAL2=
USBSERIAL3=
USBSERIAL4=
TotalKBytes=0
TotalTimes=0
PreTotalKBytes=0
PreTotalTimes=0
FLUSHDETECT=YES
FlushDay=1
AlreadyFlush=NO
SERIALNO=99
STORAGE=
CONN_TYPE=0
PROVIDER_MODE=0
DO_3G_INITIAL=0
[USBPPP2]
WAN=0.0.0.0
WANMAC=
WANMASK=0.0.0.0
GATEWAY=0.0.0.0
NETWORKSTATUS=
APN=
DIALNUMBER=*99#
USERNAME=
PASSWORD=
BACKUP=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
AUTOMTU=YES
MTU=1500
AUTOUDATE=NO
UPDATEPERIOD=30
PINCODEPROTECT=NO
PINCODE=
PUKCODE=
ERRORTIME=0
USERSPECIALDNS=NO
DNS1=0.0.0.0
DNS2=0.0.0.0
DNS3=0.0.0.0
CHARGTYPE=0
BASICTRAFFICKBYTE=
BASICTRAFFICDOLLAR=
ABOVETRAFFICRATE=
TRAFFICDETECT=NO
TRAFFICTHRESHOLD=
BASICTIMEMINUTE=
BASICTIMEDOLLAR=
ABOVETIMERATE=
TIMEDETECT=NO
TIMETHRESHOLD=
USBSERIAL1=
USBSERIAL2=
USBSERIAL3=
USBSERIAL4=
TotalKBytes=0
TotalTimes=0
PreTotalKBytes=0
PreTotalTimes=0
FLUSHDETECT=YES
FlushDay=1
AlreadyFlush=NO
SERIALNO=99
STORAGE=
CONN_TYPE=0
PROVIDER_MODE=0
DO_3G_INITIAL=
[QOS]
NUMBER=0
[QOS_EXCEPT]
NUMBER=0
[QOS_DISPLAY_EXCEPT]
NUMBER=0
[RC_LIST]
DOWN_RATE=10
UP_RATE=10
NUMBER=0
[RC_DISPLAY_LIST]
NUMBER=0
PERPAGENUM=5
[PR_LIST]
NUMBER=0
[PR_DISPLAY_LIST]
NUMBER=0
PERPAGENUM=5
[WAN1_RC_LIST]
NUMBER=0
[WAN1_PR_LIST]
NUMBER=0
[WAN2_RC_LIST]
NUMBER=0
[WAN2_PR_LIST]
NUMBER=0
[WAN3_RC_LIST]
NUMBER=0
[WAN3_PR_LIST]
NUMBER=0
[WAN4_RC_LIST]
NUMBER=0
[WAN4_PR_LIST]
NUMBER=0
[WAN5_RC_LIST]
NUMBER=0
[WAN5_PR_LIST]
NUMBER=0
[WAN6_RC_LIST]
NUMBER=0
[WAN6_PR_LIST]
NUMBER=0
[WAN7_RC_LIST]
NUMBER=0
[WAN7_PR_LIST]
NUMBER=0
[WAN8_RC_LIST]
NUMBER=0
[WAN8_PR_LIST]
NUMBER=0
[USB1_RC_LIST]
NUMBER=0
[USB2_RC_LIST]
NUMBER=0
[USB1_PR_LIST]
NUMBER=0
[USB2_PR_LIST]
NUMBER=0
[APPLICATION_LIST]
ID="ID=1&PR=6&ST=80&EN=80&GO=160&GU=2&PO=1&NA=Web"
ID="ID=2&PR=6&ST=25&EN=25&GO=80&GU=2&PO=1&NA=Email(SMTP)"
ID="ID=3&PR=6&ST=110&EN=110&GO=160&GU=2&PO=1&NA=Email(POP3)"
ID="ID=4&PR=6&ST=20&EN=21&GO=80&GU=2&PO=1&NA=FTP"
ID="ID=5&PR=6&ST=0&EN=0&GO=33&GU=2&PO=1&NA=Skype"
ID="ID=6&PR=6&ST=5000&EN=5101&GO=240&GU=2&PO=1&NA=Yahoo Messenger"
ID="ID=7&PR=17&ST=500&EN=500&GO=40&GU=2&PO=1&NA=IPsec VPN"
ID="ID=8&PR=6&ST=22&EN=22&GO=80&GU=2&PO=1&NA=SSH"
ID="ID=9&PR=6&ST=5190&EN=5190&GO=33&GU=2&PO=1&NA=AIM"
ID="ID=10&PR=6&ST=6665&EN=6669&GO=33&GU=2&PO=1&NA=IRC"
ID="ID=11&PR=17&ST=4000&EN=4000&GO=33&GU=2&PO=1&NA=ICQ"
ID="ID=12&PR=6&ST=5500&EN=5503&GO=33&GU=2&PO=1&NA=Hotline"
ID="ID=13&PR=6&ST=443&EN=443&GO=80&GU=2&PO=1&NA=HTTPs"
ID="ID=14&PR=6&ST=23&EN=23&GO=8&GU=2&PO=1&NA=Telnet"
ID="ID=15&PR=6&ST=119&EN=119&GO=40&GU=2&PO=1&NA=News"
ID="ID=16&PR=17&ST=53&EN=53&GO=1&GU=2&PO=1&NA=DNS"
ID="ID=17&PR=6&ST=161&EN=161&GO=4&GU=2&PO=1&NA=SNMP"
ID="ID=18&PR=6&ST=1755&EN=1755&PR2=17&ST2=1755&EN2=1755&PR3=6&ST3=544&EN3=544&PR4=6&ST4=544&EN4=544&GO=300&PO=4&GU=2&NA=Window Media Player"
ID="ID=19&PR=6&ST=137&EN=139&PR2=6&ST2=445&EN2=445&GO=80&GU=2&PO=2&NA=Netbios"
COUNTER=19
NUMBER=19
[PORT_FORWARDING]
ID="IP=192.168.0.100&WAN=0&ENABLED=1&TCP=444:444&ID=22&PROTOCOL=6&START=444&END=444&NAME=RemoteSyno"
ID="IP=192.168.0.100&WAN=0&ENABLED=1&TCP=5001:5001&ID=23&PROTOCOL=6&START=5001&END=5001&NAME=Synofiles"
ID="IP=192.168.0.100&WAN=0&ENABLED=1&TCP=5000:5000&ID=24&PROTOCOL=6&START=5000&END=5000&NAME=WebDacv"
ID="IP=192.168.0.100&WAN=0&ENABLED=1&UDP=1194:1194&ID=25&PROTOCOL=17&START=1194&END=1194&NAME=OpenVpn"
NUMBER=4
PERPAGENUM=5
[PORT_FORWARDING_CHANGE_PORT]
PORT=443
[PORT_FWD_LIST]
NUMBER=0
[SERVICE_PORT]
ID="ID=1&PROTOCOL=0&START=1&END=65535&NAME=All Traffic"
ID="ID=2&PROTOCOL=17&START=53&END=53&NAME=DNS"
ID="ID=3&PROTOCOL=6&START=21&END=21&NAME=FTP"
ID="ID=4&PROTOCOL=6&START=80&END=80&NAME=HTTP"
ID="ID=5&PROTOCOL=6&START=8080&END=8080&NAME=HTTP Secondary"
ID="ID=6&PROTOCOL=6&START=443&END=443&NAME=HTTPS"
ID="ID=7&PROTOCOL=6&START=8443&END=8443&NAME=HTTPS Secondary"
ID="ID=8&PROTOCOL=17&START=69&END=69&NAME=TFTP"
ID="ID=9&PROTOCOL=6&START=143&END=143&NAME=IMAP"
ID="ID=10&PROTOCOL=6&START=119&END=119&NAME=NNTP"
ID="ID=11&PROTOCOL=6&START=110&END=110&NAME=POP3"
ID="ID=12&PROTOCOL=17&START=161&END=161&NAME=SNMP"
ID="ID=13&PROTOCOL=6&START=25&END=25&NAME=SMTP"
ID="ID=14&PROTOCOL=6&START=23&END=23&NAME=TELNET"
ID="ID=15&PROTOCOL=6&START=8023&END=8023&NAME=TELNET Secondary"
ID="ID=16&PROTOCOL=6&START=992&END=992&NAME=TELNET SSL"
ID="ID=17&PROTOCOL=17&START=67&END=67&NAME=DHCP"
ID="ID=18&PROTOCOL=17&START=1701&END=1701&NAME=L2TP"
ID="ID=19&PROTOCOL=6&START=1723&END=1723&NAME=PPTP"
ID="ID=20&PROTOCOL=17&START=500&END=500&NAME=IPSec"
ID="ID=21&PROTOCOL=1&START=0&END=0&NAME=Ping"
ID="ID=22&PROTOCOL=6&START=444&END=444&NAME=RemoteSyno"
ID="ID=23&PROTOCOL=6&START=5001&END=5001&NAME=Synofiles"
ID="ID=24&PROTOCOL=6&START=5000&END=5000&NAME=WebDacv"
ID="ID=25&PROTOCOL=17&START=1194&END=1194&NAME=OpenVpn"
COUNTER=21
NUMBER=25
PERPAGENUM=5
[SINGLE_SERVICE_PORT]
NUMBER=0
MAX_ID=22
[GROUP_SERVICE_PORT]
NUMBER=0
NUMBER=0
[DEST_IPGROUP]
NUMBER=0
[IPGROUP_BEF_LIST]
NUMBER=0
[IP_LIST]
NUMBER=0
[REMOTEIPGROUP_LIST]
NUMBER=0
[REMOTEIP_LIST]
NUMBER=0
[SESSION_LIST]
NUMBER=0
[QOS_SERVICE_PORT]
ID="ID=21&PROTOCOL=50&START=0&END=0&NAME=ESP"
ID="ID=22&PROTOCOL=47&START=0&END=0&NAME=GRE"
ID="ID=23&PROTOCOL=0&START=0&END=0&NAME=All IP Traffic"
COUNTER=23
NUMBER=23
[PORT_TRIGGERING]
NUMBER=0
PERPAGENUM=5
[SERVICE_LIST]
NUMBER=0
[UPNP_FORWARDING]
ID="ID=2&IP=&ENABLED=0&UDP=53:53&PROTOCOL=17&START=53&END=53&NAME=DNS"
ID="ID=3&IP=&ENABLED=0&TCP=21:21&PROTOCOL=6&START=21&END=21&NAME=FTP"
ID="ID=4&IP=&ENABLED=0&TCP=80:80&PROTOCOL=6&START=80&END=80&NAME=HTTP"
ID="ID=5&IP=&ENABLED=0&TCP=8080:8080&PROTOCOL=6&START=8080&END=8080&NAME=HTTP Secondary"
ID="ID=6&IP=&ENABLED=0&TCP=443:443&PROTOCOL=6&START=443&END=443&NAME=HTTPS"
ID="ID=7&IP=&ENABLED=0&TCP=8443:8443&PROTOCOL=6&START=8443&END=8443&NAME=HTTPS Secondary"
ID="ID=8&IP=&ENABLED=0&UDP=69:69&PROTOCOL=17&START=69&END=69&NAME=TFTP"
ID="ID=9&IP=&ENABLED=0&TCP=143:143&PROTOCOL=6&START=143&END=143&NAME=IMAP"
ID="ID=10&IP=&ENABLED=0&TCP=119:119&PROTOCOL=6&START=119&END=119&NAME=NNTP"
ID="ID=11&IP=&ENABLED=0&TCP=110:110&PROTOCOL=6&START=110&END=110&NAME=POP3"
ID="ID=12&IP=&ENABLED=0&UDP=161:161&PROTOCOL=17&START=161&END=161&NAME=SNMP"
ID="ID=13&IP=&ENABLED=0&TCP=25:25&PROTOCOL=6&START=25&END=25&NAME=SMTP"
ID="ID=14&IP=&ENABLED=0&TCP=23:23&PROTOCOL=6&START=23&END=23&NAME=TELNET"
ID="ID=15&IP=&ENABLED=0&TCP=8023:8023&PROTOCOL=6&START=8023&END=8023&NAME=TELNET Secondary"
ID="ID=16&IP=&ENABLED=0&TCP=992:992&PROTOCOL=6&START=992&END=992&NAME=TELNET SSL"
ID="ID=17&IP=&ENABLED=0&UDP=67:67&PROTOCOL=17&START=67&END=67&NAME=DHCP"
ID="ID=18&IP=&ENABLED=0&UDP=1701:1701&PROTOCOL=17&START=1701&END=1701&NAME=L2TP"
ID="ID=19&IP=&ENABLED=0&TCP=1723:1723&PROTOCOL=6&START=1723&END=1723&NAME=PPTP"
ID="ID=20&IP=&ENABLED=0&UDP=500:500&PROTOCOL=17&START=500&END=500&NAME=IPSec"
NUMBER=19
PERPAGENUM=5
PERPAGENUMAUTO=5
[UPNP_SERVICE_PORT]
COUNTER=20
NUMBER=19
PERPAGENUM=5
[HOST_LIST]
[SESSION_ENHANCE]
NUMBER=0
TEST=
[ACCESS_LIST]
NUMBER=0
PERPAGE=1
FWRULEEDITNO=0
FWRULECOUNT=0
FWLINEPERPAGE=5
FWTPAGE=1
FWCURRPAGE=1
DELETEFWRULE=0
[ACCESS_RULE]
NUMBER=0
[ACCESS_WAN]
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=WAN2&STYPE=1&FSRC=0.0.0.0&TSRC=255.255.255.255&DTYPE=1&FDEST=0.0.0.0&TDEST=255.255.255.255&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=WAN1&STYPE=1&FSRC=0.0.0.0&TSRC=255.255.255.255&DTYPE=1&FDEST=0.0.0.0&TDEST=255.255.255.255&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=USB2&STYPE=1&FSRC=0.0.0.0&TSRC=255.255.255.255&DTYPE=1&FDEST=0.0.0.0&TDEST=255.255.255.255&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=USB1&STYPE=1&FSRC=0.0.0.0&TSRC=255.255.255.255&DTYPE=1&FDEST=0.0.0.0&TDEST=255.255.255.255&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=YES&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=LAN&STYPE=1&FSRC=0.0.0.0&TSRC=255.255.255.255&DTYPE=1&FDEST=0.0.0.0&TDEST=255.255.255.255&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
NUMBER=5
[ACCESS_DMZ]
NUMBER=2
[ACCESS_LIST_V6]
NUMBER=0
PERPAGE=1
FWRULEEDITNO=0
FWRULECOUNT=0
FWLINEPERPAGE=5
FWTPAGE=1
FWCURRPAGE=1
DELETEFWRULE=0
[ACCESS_RULE_V6]
NUMBER=0
[ACCESS_WAN_V6]
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=WAN2&STYPE=1&SRC=::&SRC_LN=0&DTYPE=1&DEST=::&DEST_LN=0&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=WAN1&STYPE=1&SRC=::&SRC_LN=0&DTYPE=1&DEST=::&DEST_LN=0&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=USB2&STYPE=1&SRC=::&SRC_LN=0&DTYPE=1&DEST=::&DEST_LN=0&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=NO&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=USB1&STYPE=1&SRC=::&SRC_LN=0&DTYPE=1&DEST=::&DEST_LN=0&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
ID="ACTION=YES&NAME=Default&ID=1&PROTOCOL=ALL&SDPORT=1&EDPORT=65535&LOG=NO&IF=LAN&STYPE=1&SRC=::&SRC_LN=0&DTYPE=1&DEST=::&DEST_LN=0&TIMECON=NO&START=&STOP=&DAYS=&DALL=&EN=YES"
NUMBER=5
[ACCESS_DMZ_V6]
NUMBER=0
DefaultFlag=0
[STATIC_IP]
ID="IP=192.168.0.100&MAC=00:11:32:16:8b:2a&NAME=Synology&Enable=1"
NUMBER=1
BLOCK_MAC_WRONG_IP=NO
BLOCK_MAC_NOT_LIST=NO
PERPAGENUM=5
[STATIC_ROUTE]
NUMBER=0
PERPAGENUM=5
[STATIC_ROUTE_V6]
NUMBER=0
PERPAGENUM=5
[IP_FILTER]
[PORT_FILTER]
[MAC_FILTER]
[REDIRECT]
[URL_BLOCKING]
[CONTENT_FILTER]
FILTER_TYPE=1
TIMEON=NO
TIMESTART=00:01
TIMESTOP=23:59
DAYS=
DAYALL=NO
BLK_JAVA=NO
BLK_ACTIVE=NO
BLK_COOKIE=NO
BLK_PROXY=NO
[ALLOW_DOMAIN]
ENABLED=NO
NUMBER=0
PERPAGENUM=5
[ALLOW_DOMAIN_EXP_IP]
NUMBER=0
[ALLOW_DOMAIN_EXP_GROUP]
NUMBER=0
[FORBIDDEN_DOMAIN]
ENABLED=NO
NUMBER=0
PERPAGENUM=5
[KEYWORD_BLOCK]
ENABLED=NO
NUMBER=0
PERPAGENUM=5
[TRUST_DOMAIN]
ENABLED=NO
NUMBER=0
PERPAGENUM=5
[121NAT]
ENABLED=NO
NUMBER=0
PERPAGENUM=5
[MULTI21NAT]
ENABLED=NO
NUMBER=0
[FIREWALL]
FIREON=YES
FIREON_TMP=YES
MULTICASTING=NO
REMOTE_ADMIN=YES
REMOTE_PORT=443
HTTPS_ENABLE=YES
SSLVPN=YES
SIP_ALG=NO
MALFORMED_PACKET=YES
BLOCK_WAN_REQUEST=NO
PING_FROM_OUTSIDE=NO
SPOODED_PACKET=YES
REMOTE_UPGRADE=YES
IPSEC_PASS_THRU=YES
PPTP_PASS_THRU=YES
L2TP_PASS_THRU=YES
DOS=YES
SPI=YES
ARP_SPOOF_PROTECT=NO
ARPNUM=5
EZPortNo=0
BLOCK_JAVA=NO
BLOCK_COOKIE=NO
BLOCK_ACTIVEX=NO
BLOCK_PROXY=NO
BLOCK_MSN=NO
BLOCK_SKYPE=NO
BLOCK_QQ=NO
BLOCK_BT=NO
BLOCK_EMULE=NO
BLOCK_XUNLEI=NO
BLOCK_YHOMSG=NO
BLOCK_FEIXIN=NO
BLOCK_FEIDIAN=NO
BLOCK_YOUKU=NO
BLOCK_KU6=NO
BLOCK_SOHU=NO
BLOCK_PPSTREAM=NO
BLOCK_PPLIVE=NO
BLOCK_KUGOO=NO
EXCEPTION_IP1_ENABLED=NO
EXCEPTION_IP2_ENABLED=NO
EXCEPTION_IP3_ENABLED=NO
EXCEPTION_IP4_ENABLED=NO
EXCEPTION_IP5_ENABLED=NO
EXCEPTION_IP1=0.0.0.0:0.0.0.0
EXCEPTION_IP2=0.0.0.0:0.0.0.0
EXCEPTION_IP3=0.0.0.0:0.0.0.0
EXCEPTION_IP4=0.0.0.0:0.0.0.0
EXCEPTION_IP5=0.0.0.0:0.0.0.0
TRAFFIC_CNT_ENABLED=NO
TRAFFIC_CNT_PERIOD=3
SIP_EXTRA_ALG=NO
VIDEO_QOS=0
HTTP_QOS=0
LOCAL_ADMIN=NO
REMOTE_HTTPS_PORT=443
LOCAL_PORT=80
LOCAL_HTTPS_PORT=443
OLD_PORT=443
LOCAL_OLD_PORT=80
SDBR_STATUS=1101
SSH_ENABLE=YES
REMOTE_SSH_ENABLE=NO
[SKYPE_DST_EXP]
NUMBER=0
[PPTP1]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP2]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP3]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP4]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP5]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP6]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP7]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP8]
STATUS=NO
LOCALIP=
SUBNETMASK=
REMOTEIP=
USERNAME=
PASSWORD=
CONNECTONDEM=NO
KEEPALIVE=YES
MAXIDLE=5
REDIALPERIOD=30
MTU=1500
IPUP=NO
ECHOPERIOD=
ECHOTIMES=
[PPTP_TRUNKING]
REMOTEIP=
USERNAME=
PASSWORD=
REDIALPERIOD=30
MTU=1460
IPUP=NO
ENABLE=0
WAN_INF=
PPP_INF=
PID=0
PPP_IP=0.0.0.0
PPP_GATEWAY=0.0.0.0
[PPTP_TRUNKING_P_T]
BINDPORT=1
ALL_SIZE=2
GAME_SIZE=50
SDEFINED_SIZE=0
ALL_0_FROMPORT=0
ALL_0_TOPORT=65535
ALL_0_PROTOCOL=TCP
ALL_1_FROMPORT=0
ALL_1_TOPORT=65535
ALL_1_PROTOCOL=UDP
GAME_0_FROMPORT=3724
GAME_0_TOPORT=3724
GAME_0_PROTOCOL=TCP
GAME_1_FROMPORT=15850
GAME_1_TOPORT=15851
GAME_1_PROTOCOL=UDP
GAME_2_FROMPORT=15779
GAME_2_TOPORT=15779
GAME_2_PROTOCOL=TCP
GAME_3_FROMPORT=9801
GAME_3_TOPORT=9801
GAME_3_PROTOCOL=TCP
GAME_4_FROMPORT=25510
GAME_4_TOPORT=25511
GAME_4_PROTOCOL=TCP
GAME_5_FROMPORT=5588
GAME_5_TOPORT=5588
GAME_5_PROTOCOL=TCP
GAME_6_FROMPORT=15000
GAME_6_TOPORT=15010
GAME_6_PROTOCOL=TCP
GAME_7_FROMPORT=5622
GAME_7_TOPORT=5622
GAME_7_PROTOCOL=TCP
GAME_8_FROMPORT=6661
GAME_8_TOPORT=6668
GAME_8_PROTOCOL=TCP
GAME_9_FROMPORT=29000
GAME_9_TOPORT=29000
GAME_9_PROTOCOL=TCP
GAME_10_FROMPORT=8888
GAME_10_TOPORT=8888
GAME_10_PROTOCOL=TCP
GAME_11_FROMPORT=9999
GAME_11_TOPORT=9999
GAME_11_PROTOCOL=TCP
GAME_12_FROMPORT=7880
GAME_12_TOPORT=7881
GAME_12_PROTOCOL=TCP
GAME_13_FROMPORT=7000
GAME_13_TOPORT=7300
GAME_13_PROTOCOL=TCP
GAME_14_FROMPORT=5050
GAME_14_TOPORT=5050
GAME_14_PROTOCOL=TCP
GAME_15_FROMPORT=6979
GAME_15_TOPORT=6979
GAME_15_PROTOCOL=TCP
GAME_16_FROMPORT=7252
GAME_16_TOPORT=7252
GAME_16_PROTOCOL=TCP
GAME_17_FROMPORT=8484
GAME_17_TOPORT=8484
GAME_17_PROTOCOL=TCP
GAME_18_FROMPORT=20388
GAME_18_TOPORT=20388
GAME_18_PROTOCOL=TCP
GAME_19_FROMPORT=39311
GAME_19_TOPORT=39311
GAME_19_PROTOCOL=TCP
GAME_20_FROMPORT=39311
GAME_20_TOPORT=39311
GAME_20_PROTOCOL=UDP
GAME_21_FROMPORT=8585
GAME_21_TOPORT=8585
GAME_21_PROTOCOL=TCP
GAME_22_FROMPORT=38888
GAME_22_TOPORT=38888
GAME_22_PROTOCOL=TCP
GAME_23_FROMPORT=13000
GAME_23_TOPORT=13001
GAME_23_PROTOCOL=TCP
GAME_24_FROMPORT=5816
GAME_24_TOPORT=5816
GAME_24_PROTOCOL=TCP
GAME_25_FROMPORT=16188
GAME_25_TOPORT=16188
GAME_25_PROTOCOL=TCP
GAME_26_FROMPORT=6299
GAME_26_TOPORT=6299
GAME_26_PROTOCOL=TCP
GAME_27_FROMPORT=7600
GAME_27_TOPORT=7900
GAME_27_PROTOCOL=TCP
GAME_28_FROMPORT=9010
GAME_28_TOPORT=9012
GAME_28_PROTOCOL=TCP
GAME_29_FROMPORT=11002
GAME_29_TOPORT=11008
GAME_29_PROTOCOL=TCP
GAME_30_FROMPORT=6020
GAME_30_TOPORT=6020
GAME_30_PROTOCOL=TCP
GAME_31_FROMPORT=10000
GAME_31_TOPORT=10011
GAME_31_PROTOCOL=TCP
GAME_32_FROMPORT=11000
GAME_32_TOPORT=11013
GAME_32_PROTOCOL=UDP
GAME_33_FROMPORT=8000
GAME_33_TOPORT=8004
GAME_33_PROTOCOL=TCP
GAME_34_FROMPORT=8000
GAME_34_TOPORT=8004
GAME_34_PROTOCOL=UDP
GAME_35_FROMPORT=11000
GAME_35_TOPORT=11000
GAME_35_PROTOCOL=TCP
GAME_36_FROMPORT=3077
GAME_36_TOPORT=3077
GAME_36_PROTOCOL=TCP
GAME_37_FROMPORT=6666
GAME_37_TOPORT=6666
GAME_37_PROTOCOL=TCP
GAME_38_FROMPORT=9022
GAME_38_TOPORT=9022
GAME_38_PROTOCOL=TCP
GAME_39_FROMPORT=4005
GAME_39_TOPORT=4005
GAME_39_PROTOCOL=TCP
GAME_40_FROMPORT=25510
GAME_40_TOPORT=25511
GAME_40_PROTOCOL=TCP
GAME_41_FROMPORT=7200
GAME_41_TOPORT=7200
GAME_41_PROTOCOL=TCP
GAME_42_FROMPORT=39288
GAME_42_TOPORT=39288
GAME_42_PROTOCOL=TCP
GAME_43_FROMPORT=54688
GAME_43_TOPORT=54688
GAME_43_PROTOCOL=TCP
GAME_44_FROMPORT=14100
GAME_44_TOPORT=14100
GAME_44_PROTOCOL=UDP
GAME_45_FROMPORT=7901
GAME_45_TOPORT=7901
GAME_45_PROTOCOL=TCP
GAME_46_FROMPORT=7303
GAME_46_TOPORT=7303
GAME_46_PROTOCOL=TCP
GAME_47_FROMPORT=6299
GAME_47_TOPORT=6299
GAME_47_PROTOCOL=TCP
GAME_48_FROMPORT=42001
GAME_48_TOPORT=42001
GAME_48_PROTOCOL=TCP
GAME_49_FROMPORT=13588
GAME_49_TOPORT=13588
GAME_49_PROTOCOL=TCP
[PPTP_TRUNKING_IP_T]
BINDNETWORK=1
ALL_SIZE=255
SDEFINED_SIZE=0
ALL_0_FROMIP=58.16.0.0
ALL_0_TOIP=58.16.255.255
ALL_0_PRIORITY=4000
ALL_1_FROMIP=58.17.0.0
ALL_1_TOIP=58.17.127.255
ALL_1_PRIORITY=4001
ALL_2_FROMIP=58.17.128.0
ALL_2_TOIP=58.17.255.255
ALL_2_PRIORITY=4002
ALL_3_FROMIP=58.18.0.0
ALL_3_TOIP=58.18.255.255
ALL_3_PRIORITY=4003
ALL_4_FROMIP=58.19.0.0
ALL_4_TOIP=58.19.255.255
ALL_4_PRIORITY=4004
ALL_5_FROMIP=58.20.0.0
ALL_5_TOIP=58.20.255.255
ALL_5_PRIORITY=4005
ALL_6_FROMIP=58.21.0.0
ALL_6_TOIP=58.21.255.255
ALL_6_PRIORITY=4006
ALL_7_FROMIP=58.22.0.0
ALL_7_TOIP=58.23.255.255
ALL_7_PRIORITY=4007
ALL_8_FROMIP=58.144.0.0
ALL_8_TOIP=58.144.255.255
ALL_8_PRIORITY=4008
ALL_9_FROMIP=58.240.0.0
ALL_9_TOIP=58.241.255.255
ALL_9_PRIORITY=4009
ALL_10_FROMIP=58.242.0.0
ALL_10_TOIP=58.243.255.255
ALL_10_PRIORITY=4010
ALL_11_FROMIP=58.244.0.0
ALL_11_TOIP=58.245.255.255
ALL_11_PRIORITY=4011
ALL_12_FROMIP=58.246.0.0
ALL_12_TOIP=58.247.255.255
ALL_12_PRIORITY=4012
ALL_13_FROMIP=58.248.0.0
ALL_13_TOIP=58.255.255.255
ALL_13_PRIORITY=4013
ALL_14_FROMIP=60.0.0.0
ALL_14_TOIP=60.7.255.255
ALL_14_PRIORITY=4014
ALL_15_FROMIP=60.8.0.0
ALL_15_TOIP=60.9.255.255
ALL_15_PRIORITY=4015
ALL_16_FROMIP=60.10.0.0
ALL_16_TOIP=60.10.255.255
ALL_16_PRIORITY=4016
ALL_17_FROMIP=60.11.0.0
ALL_17_TOIP=60.11.255.255
ALL_17_PRIORITY=4017
ALL_18_FROMIP=60.12.0.0
ALL_18_TOIP=60.12.255.255
ALL_18_PRIORITY=4018
ALL_19_FROMIP=60.13.0.0
ALL_19_TOIP=60.13.63.255
ALL_19_PRIORITY=4019
ALL_20_FROMIP=60.13.64.0
ALL_20_TOIP=60.13.127.255
ALL_20_PRIORITY=4020
ALL_21_FROMIP=60.13.128.0
ALL_21_TOIP=60.13.255.255
ALL_21_PRIORITY=4021
ALL_22_FROMIP=60.14.0.0
ALL_22_TOIP=60.15.255.255
ALL_22_PRIORITY=4022
ALL_23_FROMIP=60.16.0.0
ALL_23_TOIP=60.23.255.255
ALL_23_PRIORITY=4023
ALL_24_FROMIP=60.24.0.0
ALL_24_TOIP=60.27.255.255
ALL_24_PRIORITY=4024
ALL_25_FROMIP=60.28.0.0
ALL_25_TOIP=60.29.255.255
ALL_25_PRIORITY=4025
ALL_26_FROMIP=60.30.0.0
ALL_26_TOIP=60.30.255.255
ALL_26_PRIORITY=4026
ALL_27_FROMIP=60.31.0.0
ALL_27_TOIP=60.31.255.255
ALL_27_PRIORITY=4027
ALL_28_FROMIP=60.208.0.0
ALL_28_TOIP=60.215.255.255
ALL_28_PRIORITY=4028
ALL_29_FROMIP=60.216.0.0
ALL_29_TOIP=60.217.255.255
ALL_29_PRIORITY=4029
ALL_30_FROMIP=60.218.0.0
ALL_30_TOIP=60.219.255.255
ALL_30_PRIORITY=4030
ALL_31_FROMIP=60.220.0.0
ALL_31_TOIP=60.223.255.255
ALL_31_PRIORITY=4031
ALL_32_FROMIP=61.48.0.0
ALL_32_TOIP=61.51.255.255
ALL_32_PRIORITY=4032
ALL_33_FROMIP=61.52.0.0
ALL_33_TOIP=61.53.255.255
ALL_33_PRIORITY=4033
ALL_34_FROMIP=61.54.0.0
ALL_34_TOIP=61.54.255.255
ALL_34_PRIORITY=4034
ALL_35_FROMIP=61.55.0.0
ALL_35_TOIP=61.55.255.255
ALL_35_PRIORITY=4035
ALL_36_FROMIP=61.133.0.0
ALL_36_TOIP=61.133.127.255
ALL_36_PRIORITY=4036
ALL_37_FROMIP=61.134.96.0
ALL_37_TOIP=61.134.127.255
ALL_37_PRIORITY=4037
ALL_38_FROMIP=61.134.128.0
ALL_38_TOIP=61.134.191.255
ALL_38_PRIORITY=4038
ALL_39_FROMIP=61.134.192.0
ALL_39_TOIP=61.134.255.255
ALL_39_PRIORITY=4039
ALL_40_FROMIP=61.135.0.0
ALL_40_TOIP=61.135.255.255
ALL_40_PRIORITY=4040
ALL_41_FROMIP=61.136.0.0
ALL_41_TOIP=61.136.63.255
ALL_41_PRIORITY=4041
ALL_42_FROMIP=61.136.64.0
ALL_42_TOIP=61.136.127.255
ALL_42_PRIORITY=4042
ALL_43_FROMIP=61.137.128.0
ALL_43_TOIP=61.137.255.255
ALL_43_PRIORITY=4043
ALL_44_FROMIP=61.138.0.0
ALL_44_TOIP=61.138.63.255
ALL_44_PRIORITY=4044
ALL_45_FROMIP=61.138.64.0
ALL_45_TOIP=61.138.127.255
ALL_45_PRIORITY=4045
ALL_46_FROMIP=61.138.128.0
ALL_46_TOIP=61.138.191.255
ALL_46_PRIORITY=4046
ALL_47_FROMIP=61.139.128.0
ALL_47_TOIP=61.139.191.255
ALL_47_PRIORITY=4047
ALL_48_FROMIP=61.148.0.0
ALL_48_TOIP=61.149.255.255
ALL_48_PRIORITY=4048
ALL_49_FROMIP=61.156.0.0
ALL_49_TOIP=61.156.255.255
ALL_49_PRIORITY=4049
ALL_50_FROMIP=61.158.128.0
ALL_50_TOIP=61.158.255.255
ALL_50_PRIORITY=4050
ALL_51_FROMIP=61.159.0.0
ALL_51_TOIP=61.159.63.255
ALL_51_PRIORITY=4051
ALL_52_FROMIP=61.161.0.0
ALL_52_TOIP=61.161.63.255
ALL_52_PRIORITY=4052
ALL_53_FROMIP=61.161.128.0
ALL_53_TOIP=61.161.255.255
ALL_53_PRIORITY=4053
ALL_54_FROMIP=61.162.0.0
ALL_54_TOIP=61.162.255.255
ALL_54_PRIORITY=4054
ALL_55_FROMIP=61.163.0.0
ALL_55_TOIP=61.163.255.255
ALL_55_PRIORITY=4055
ALL_56_FROMIP=61.167.0.0
ALL_56_TOIP=61.167.255.255
ALL_56_PRIORITY=4056
ALL_57_FROMIP=61.168.0.0
ALL_57_TOIP=61.168.255.255
ALL_57_PRIORITY=4057
ALL_58_FROMIP=61.176.0.0
ALL_58_TOIP=61.176.255.255
ALL_58_PRIORITY=4058
ALL_59_FROMIP=61.179.0.0
ALL_59_TOIP=61.179.255.255
ALL_59_PRIORITY=4059
ALL_60_FROMIP=61.180.128.0
ALL_60_TOIP=61.180.255.255
ALL_60_PRIORITY=4060
ALL_61_FROMIP=61.181.0.0
ALL_61_TOIP=61.181.255.255
ALL_61_PRIORITY=4061
ALL_62_FROMIP=61.182.0.0
ALL_62_TOIP=61.182.255.255
ALL_62_PRIORITY=4062
ALL_63_FROMIP=61.189.0.0
ALL_63_TOIP=61.189.127.255
ALL_63_PRIORITY=4063
ALL_64_FROMIP=116.116.0.0
ALL_64_TOIP=116.117.255.255
ALL_64_PRIORITY=4064
ALL_65_FROMIP=117.8.0.0
ALL_65_TOIP=117.15.255.255
ALL_65_PRIORITY=4065
ALL_66_FROMIP=118.72.0.0
ALL_66_TOIP=118.79.255.255
ALL_66_PRIORITY=4066
ALL_67_FROMIP=118.80.0.0
ALL_67_TOIP=118.81.255.255
ALL_67_PRIORITY=4067
ALL_68_FROMIP=121.16.0.0
ALL_68_TOIP=121.23.255.255
ALL_68_PRIORITY=4068
ALL_69_FROMIP=121.24.0.0
ALL_69_TOIP=121.27.255.255
ALL_69_PRIORITY=4069
ALL_70_FROMIP=121.28.0.0
ALL_70_TOIP=121.29.255.255
ALL_70_PRIORITY=4070
ALL_71_FROMIP=121.30.0.0
ALL_71_TOIP=121.30.255.255
ALL_71_PRIORITY=4071
ALL_72_FROMIP=121.31.0.0
ALL_72_TOIP=121.31.255.255
ALL_72_PRIORITY=4072
ALL_73_FROMIP=122.96.0.0
ALL_73_TOIP=122.97.255.255
ALL_73_PRIORITY=4073
ALL_74_FROMIP=122.136.0.0
ALL_74_TOIP=122.143.255.255
ALL_74_PRIORITY=4074
ALL_75_FROMIP=122.156.0.0
ALL_75_TOIP=122.159.255.255
ALL_75_PRIORITY=4075
ALL_76_FROMIP=122.192.0.0
ALL_76_TOIP=122.195.255.255
ALL_76_PRIORITY=4076
ALL_77_FROMIP=123.4.0.0
ALL_77_TOIP=123.7.255.255
ALL_77_PRIORITY=4077
ALL_78_FROMIP=123.8.0.0
ALL_78_TOIP=123.15.255.255
ALL_78_PRIORITY=4078
ALL_79_FROMIP=123.99.128.0
ALL_79_TOIP=123.99.255.255
ALL_79_PRIORITY=4079
ALL_80_FROMIP=123.128.0.0
ALL_80_TOIP=123.135.255.255
ALL_80_PRIORITY=4080
ALL_81_FROMIP=123.138.0.0
ALL_81_TOIP=123.139.255.255
ALL_81_PRIORITY=4081
ALL_82_FROMIP=123.144.0.0
ALL_82_TOIP=123.147.255.255
ALL_82_PRIORITY=4082
ALL_83_FROMIP=123.152.0.0
ALL_83_TOIP=123.159.255.255
ALL_83_PRIORITY=4083
ALL_84_FROMIP=123.188.0.0
ALL_84_TOIP=123.191.255.255
ALL_84_PRIORITY=4084
ALL_85_FROMIP=123.232.0.0
ALL_85_TOIP=123.235.255.255
ALL_85_PRIORITY=4085
ALL_86_FROMIP=124.64.0.0
ALL_86_TOIP=124.65.255.255
ALL_86_PRIORITY=4086
ALL_87_FROMIP=124.66.0.0
ALL_87_TOIP=124.66.127.255
ALL_87_PRIORITY=4087
ALL_88_FROMIP=124.67.0.0
ALL_88_TOIP=124.67.255.255
ALL_88_PRIORITY=4088
ALL_89_FROMIP=124.88.0.0
ALL_89_TOIP=124.88.255.255
ALL_89_PRIORITY=4089
ALL_90_FROMIP=124.89.0.0
ALL_90_TOIP=124.89.127.255
ALL_90_PRIORITY=4090
ALL_91_FROMIP=124.89.128.0
ALL_91_TOIP=124.89.255.255
ALL_91_PRIORITY=4091
ALL_92_FROMIP=124.90.0.0
ALL_92_TOIP=124.91.255.255
ALL_92_PRIORITY=4092
ALL_93_FROMIP=124.92.0.0
ALL_93_TOIP=124.95.255.255
ALL_93_PRIORITY=4093
ALL_94_FROMIP=124.128.0.0
ALL_94_TOIP=124.135.255.255
ALL_94_PRIORITY=4094
ALL_95_FROMIP=124.160.0.0
ALL_95_TOIP=124.160.255.255
ALL_95_PRIORITY=4095
ALL_96_FROMIP=124.161.0.0
ALL_96_TOIP=124.161.255.255
ALL_96_PRIORITY=4096
ALL_97_FROMIP=124.162.0.0
ALL_97_TOIP=124.162.255.255
ALL_97_PRIORITY=4097
ALL_98_FROMIP=124.163.0.0
ALL_98_TOIP=124.163.255.255
ALL_98_PRIORITY=4098
ALL_99_FROMIP=124.164.0.0
ALL_99_TOIP=124.167.255.255
ALL_99_PRIORITY=4099
ALL_100_FROMIP=125.32.0.0
ALL_100_TOIP=125.32.255.255
ALL_100_PRIORITY=4100
ALL_101_FROMIP=125.33.0.0
ALL_101_TOIP=125.33.255.255
ALL_101_PRIORITY=441
ALL_102_FROMIP=125.34.0.0
ALL_102_TOIP=125.34.255.255
ALL_102_PRIORITY=442
ALL_103_FROMIP=125.35.0.0
ALL_103_TOIP=125.35.127.255
ALL_103_PRIORITY=4103
ALL_104_FROMIP=125.35.128.0
ALL_104_TOIP=125.35.255.255
ALL_104_PRIORITY=4104
ALL_105_FROMIP=125.36.0.0
ALL_105_TOIP=125.39.255.255
ALL_105_PRIORITY=4105
ALL_106_FROMIP=125.40.0.0
ALL_106_TOIP=125.47.255.255
ALL_106_PRIORITY=4106
ALL_107_FROMIP=125.211.0.0
ALL_107_TOIP=125.211.255.255
ALL_107_PRIORITY=4107
ALL_108_FROMIP=202.38.143.0
ALL_108_TOIP=202.38.143.255
ALL_108_PRIORITY=4108
ALL_109_FROMIP=202.96.0.0
ALL_109_TOIP=202.96.63.255
ALL_109_PRIORITY=4109
ALL_110_FROMIP=202.96.64.0
ALL_110_TOIP=202.96.71.255
ALL_110_PRIORITY=4110
ALL_111_FROMIP=202.96.72.0
ALL_111_TOIP=202.96.79.255
ALL_111_PRIORITY=4111
ALL_112_FROMIP=202.96.80.0
ALL_112_TOIP=202.96.95.255
ALL_112_PRIORITY=4112
ALL_113_FROMIP=202.97.128.0
ALL_113_TOIP=202.97.191.255
ALL_113_PRIORITY=4113
ALL_114_FROMIP=202.97.192.0
ALL_114_TOIP=202.97.255.255
ALL_114_PRIORITY=4114
ALL_115_FROMIP=202.98.0.0
ALL_115_TOIP=202.98.31.255
ALL_115_PRIORITY=4115
ALL_116_FROMIP=202.99.0.0
ALL_116_TOIP=202.99.63.255
ALL_116_PRIORITY=4116
ALL_117_FROMIP=202.99.64.0
ALL_117_TOIP=202.99.95.255
ALL_117_PRIORITY=4117
ALL_118_FROMIP=202.99.96.0
ALL_118_TOIP=202.99.103.255
ALL_118_PRIORITY=4118
ALL_119_FROMIP=202.99.104.0
ALL_119_TOIP=202.99.111.255
ALL_119_PRIORITY=4119
ALL_120_FROMIP=202.99.112.0
ALL_120_TOIP=202.99.127.255
ALL_120_PRIORITY=4120
ALL_121_FROMIP=202.99.128.0
ALL_121_TOIP=202.99.159.255
ALL_121_PRIORITY=4121
ALL_122_FROMIP=202.99.160.0
ALL_122_TOIP=202.99.167.255
ALL_122_PRIORITY=4122
ALL_123_FROMIP=202.99.168.0
ALL_123_TOIP=202.99.175.255
ALL_123_PRIORITY=4123
ALL_124_FROMIP=202.99.176.0
ALL_124_TOIP=202.99.191.255
ALL_124_PRIORITY=4124
ALL_125_FROMIP=202.99.208.0
ALL_125_TOIP=202.99.223.255
ALL_125_PRIORITY=4125
ALL_126_FROMIP=202.99.224.0
ALL_126_TOIP=202.99.231.255
ALL_126_PRIORITY=4126
ALL_127_FROMIP=202.99.232.0
ALL_127_TOIP=202.99.239.255
ALL_127_PRIORITY=4127
ALL_128_FROMIP=202.99.240.0
ALL_128_TOIP=202.99.255.255
ALL_128_PRIORITY=4128
ALL_129_FROMIP=202.42.128.0
ALL_129_TOIP=202.42.135.255
ALL_129_PRIORITY=4129
ALL_130_FROMIP=202.42.136.0
ALL_130_TOIP=202.42.143.255
ALL_130_PRIORITY=4130
ALL_131_FROMIP=202.42.144.0
ALL_131_TOIP=202.42.159.255
ALL_131_PRIORITY=4131
ALL_132_FROMIP=202.42.224.0
ALL_132_TOIP=202.42.231.255
ALL_132_PRIORITY=4132
ALL_133_FROMIP=202.42.232.0
ALL_133_TOIP=202.42.239.255
ALL_133_PRIORITY=4133
ALL_134_FROMIP=202.42.240.0
ALL_134_TOIP=202.42.255.255
ALL_134_PRIORITY=4134
ALL_135_FROMIP=202.42.160.0
ALL_135_TOIP=202.42.191.255
ALL_135_PRIORITY=4135
ALL_136_FROMIP=202.106.0.0
ALL_136_TOIP=202.106.255.255
ALL_136_PRIORITY=4136
ALL_137_FROMIP=202.107.0.0
ALL_137_TOIP=202.107.127.255
ALL_137_PRIORITY=4137
ALL_138_FROMIP=202.108.0.0
ALL_138_TOIP=202.108.255.255
ALL_138_PRIORITY=4138
ALL_139_FROMIP=202.110.0.0
ALL_139_TOIP=202.110.63.255
ALL_139_PRIORITY=4139
ALL_140_FROMIP=202.110.64.0
ALL_140_TOIP=202.110.127.255
ALL_140_PRIORITY=4140
ALL_141_FROMIP=202.110.192.0
ALL_141_TOIP=202.110.255.255
ALL_141_PRIORITY=4141
ALL_142_FROMIP=202.111.128.0
ALL_142_TOIP=202.111.159.255
ALL_142_PRIORITY=4142
ALL_143_FROMIP=202.127.194.0
ALL_143_TOIP=202.127.195.255
ALL_143_PRIORITY=4143
ALL_144_FROMIP=202.130.224.0
ALL_144_TOIP=202.130.255.255
ALL_144_PRIORITY=4144
ALL_145_FROMIP=203.93.8.0
ALL_145_TOIP=203.93.8.255
ALL_145_PRIORITY=4145
ALL_146_FROMIP=203.93.192.0
ALL_146_TOIP=203.93.255.255
ALL_146_PRIORITY=4146
ALL_147_FROMIP=203.135.160.0
ALL_147_TOIP=203.135.175.255
ALL_147_PRIORITY=4147
ALL_148_FROMIP=210.13.128.0
ALL_148_TOIP=210.13.255.255
ALL_148_PRIORITY=4148
ALL_149_FROMIP=210.14.160.0
ALL_149_TOIP=210.14.191.255
ALL_149_PRIORITY=4149
ALL_150_FROMIP=210.14.192.0
ALL_150_TOIP=210.14.223.255
ALL_150_PRIORITY=4150
ALL_151_FROMIP=210.15.32.0
ALL_151_TOIP=210.15.63.255
ALL_151_PRIORITY=4151
ALL_152_FROMIP=210.15.96.0
ALL_152_TOIP=210.15.127.255
ALL_152_PRIORITY=4152
ALL_153_FROMIP=210.15.128.0
ALL_153_TOIP=210.15.191.255
ALL_153_PRIORITY=4153
ALL_154_FROMIP=210.21.0.0
ALL_154_TOIP=210.21.255.255
ALL_154_PRIORITY=4154
ALL_155_FROMIP=210.22.0.0
ALL_155_TOIP=210.22.255.255
ALL_155_PRIORITY=4155
ALL_156_FROMIP=210.51.0.0
ALL_156_TOIP=210.51.255.255
ALL_156_PRIORITY=4156
ALL_157_FROMIP=210.52.0.0
ALL_157_TOIP=210.52.255.255
ALL_157_PRIORITY=4157
ALL_158_FROMIP=210.53.0.0
ALL_158_TOIP=210.53.127.255
ALL_158_PRIORITY=4158
ALL_159_FROMIP=210.53.128.0
ALL_159_TOIP=210.53.255.255
ALL_159_PRIORITY=4159
ALL_160_FROMIP=210.56.192.0
ALL_160_TOIP=210.56.223.255
ALL_160_PRIORITY=4160
ALL_161_FROMIP=210.74.96.0
ALL_161_TOIP=210.74.127.255
ALL_161_PRIORITY=4161
ALL_162_FROMIP=210.74.128.0
ALL_162_TOIP=210.74.159.255
ALL_162_PRIORITY=4162
ALL_163_FROMIP=210.82.0.0
ALL_163_TOIP=210.83.255.255
ALL_163_PRIORITY=4163
ALL_164_FROMIP=211.144.0.0
ALL_164_TOIP=211.145.255.255
ALL_164_PRIORITY=4164
ALL_165_FROMIP=218.7.0.0
ALL_165_TOIP=218.7.255.255
ALL_165_PRIORITY=4165
ALL_166_FROMIP=218.8.0.0
ALL_166_TOIP=218.9.255.255
ALL_166_PRIORITY=4166
ALL_167_FROMIP=218.10.0.0
ALL_167_TOIP=218.10.255.255
ALL_167_PRIORITY=4167
ALL_168_FROMIP=218.11.0.0
ALL_168_TOIP=218.11.255.255
ALL_168_PRIORITY=4168
ALL_169_FROMIP=218.12.0.0
ALL_169_TOIP=218.12.255.255
ALL_169_PRIORITY=4169
ALL_170_FROMIP=218.21.128.0
ALL_170_TOIP=218.21.255.255
ALL_170_PRIORITY=4170
ALL_171_FROMIP=218.24.0.0
ALL_171_TOIP=218.25.255.255
ALL_171_PRIORITY=4171
ALL_172_FROMIP=218.26.0.0
ALL_172_TOIP=218.26.255.255
ALL_172_PRIORITY=4172
ALL_173_FROMIP=218.27.0.0
ALL_173_TOIP=218.27.255.255
ALL_173_PRIORITY=4173
ALL_174_FROMIP=218.28.0.0
ALL_174_TOIP=218.29.255.255
ALL_174_PRIORITY=4174
ALL_175_FROMIP=218.56.0.0
ALL_175_TOIP=218.59.255.255
ALL_175_PRIORITY=4175
ALL_176_FROMIP=218.60.0.0
ALL_176_TOIP=218.61.255.255
ALL_176_PRIORITY=4176
ALL_177_FROMIP=218.62.0.0
ALL_177_TOIP=218.62.127.255
ALL_177_PRIORITY=4177
ALL_178_FROMIP=218.67.128.0
ALL_178_TOIP=218.67.255.255
ALL_178_PRIORITY=4178
ALL_179_FROMIP=218.68.0.0
ALL_179_TOIP=218.69.255.255
ALL_179_PRIORITY=4179
ALL_180_FROMIP=218.104.0.0
ALL_180_TOIP=218.104.127.255
ALL_180_PRIORITY=4180
ALL_181_FROMIP=218.104.128.0
ALL_181_TOIP=218.104.159.255
ALL_181_PRIORITY=4181
ALL_182_FROMIP=218.104.160.0
ALL_182_TOIP=218.104.191.255
ALL_182_PRIORITY=4182
ALL_183_FROMIP=218.104.192.0
ALL_183_TOIP=218.104.199.255
ALL_183_PRIORITY=4183
ALL_184_FROMIP=218.104.200.0
ALL_184_TOIP=218.104.207.255
ALL_184_PRIORITY=4184
ALL_185_FROMIP=218.104.208.0
ALL_185_TOIP=218.104.223.255
ALL_185_PRIORITY=4185
ALL_186_FROMIP=218.104.224.0
ALL_186_TOIP=218.104.255.255
ALL_186_PRIORITY=4186
ALL_187_FROMIP=218.105.0.0
ALL_187_TOIP=218.105.255.255
ALL_187_PRIORITY=4187
ALL_188_FROMIP=218.106.0.0
ALL_188_TOIP=218.107.255.255
ALL_188_PRIORITY=4188
ALL_189_FROMIP=219.154.0.0
ALL_189_TOIP=219.155.255.255
ALL_189_PRIORITY=4189
ALL_190_FROMIP=219.156.0.0
ALL_190_TOIP=219.157.255.255
ALL_190_PRIORITY=4190
ALL_191_FROMIP=219.158.0.0
ALL_191_TOIP=219.158.127.255
ALL_191_PRIORITY=4191
ALL_192_FROMIP=219.158.128.0
ALL_192_TOIP=219.158.255.255
ALL_192_PRIORITY=4192
ALL_193_FROMIP=219.159.0.0
ALL_193_TOIP=219.159.63.255
ALL_193_PRIORITY=4193
ALL_194_FROMIP=220.248.0.0
ALL_194_TOIP=220.251.255.255
ALL_194_PRIORITY=4194
ALL_195_FROMIP=220.252.0.0
ALL_195_TOIP=220.252.255.255
ALL_195_PRIORITY=4195
ALL_196_FROMIP=220.112.0.0
ALL_196_TOIP=220.115.255.255
ALL_196_PRIORITY=4196
ALL_197_FROMIP=221.0.0.0
ALL_197_TOIP=221.1.255.255
ALL_197_PRIORITY=4197
ALL_198_FROMIP=221.2.0.0
ALL_198_TOIP=221.2.255.255
ALL_198_PRIORITY=4198
ALL_199_FROMIP=221.3.0.0
ALL_199_TOIP=221.3.127.255
ALL_199_PRIORITY=4199
ALL_200_FROMIP=221.3.128.0
ALL_200_TOIP=221.3.255.255
ALL_200_PRIORITY=4200
ALL_201_FROMIP=221.4.0.0
ALL_201_TOIP=221.4.255.255
ALL_201_PRIORITY=4201
ALL_202_FROMIP=221.5.0.0
ALL_202_TOIP=221.5.127.255
ALL_202_PRIORITY=4202
ALL_203_FROMIP=221.5.128.0
ALL_203_TOIP=221.5.255.255
ALL_203_PRIORITY=4203
ALL_204_FROMIP=221.6.0.0
ALL_204_TOIP=221.6.255.255
ALL_204_PRIORITY=4204
ALL_205_FROMIP=221.7.0.0
ALL_205_TOIP=221.7.31.255
ALL_205_PRIORITY=4205
ALL_206_FROMIP=221.7.32.0
ALL_206_TOIP=221.7.63.255
ALL_206_PRIORITY=4206
ALL_207_FROMIP=221.7.64.0
ALL_207_TOIP=221.7.95.255
ALL_207_PRIORITY=4207
ALL_208_FROMIP=221.7.96.0
ALL_208_TOIP=221.7.127.255
ALL_208_PRIORITY=4208
ALL_209_FROMIP=221.7.128.0
ALL_209_TOIP=221.7.255.255
ALL_209_PRIORITY=4209
ALL_210_FROMIP=221.8.0.0
ALL_210_TOIP=221.9.255.255
ALL_210_PRIORITY=4210
ALL_211_FROMIP=221.10.0.0
ALL_211_TOIP=221.10.255.255
ALL_211_PRIORITY=4211
ALL_212_FROMIP=221.11.0.0
ALL_212_TOIP=221.11.127.255
ALL_212_PRIORITY=4212
ALL_213_FROMIP=221.11.128.0
ALL_213_TOIP=221.11.191.255
ALL_213_PRIORITY=4213
ALL_214_FROMIP=221.11.192.0
ALL_214_TOIP=221.11.223.255
ALL_214_PRIORITY=4214
ALL_215_FROMIP=221.11.224.0
ALL_215_TOIP=221.11.255.255
ALL_215_PRIORITY=4215
ALL_216_FROMIP=221.12.0.0
ALL_216_TOIP=221.12.127.255
ALL_216_PRIORITY=4216
ALL_217_FROMIP=221.12.128.0
ALL_217_TOIP=221.12.191.255
ALL_217_PRIORITY=4217
ALL_218_FROMIP=221.13.0.0
ALL_218_TOIP=221.13.63.255
ALL_218_PRIORITY=4218
ALL_219_FROMIP=221.13.64.0
ALL_219_TOIP=221.13.95.255
ALL_219_PRIORITY=4219
ALL_220_FROMIP=221.13.96.0
ALL_220_TOIP=221.13.127.255
ALL_220_PRIORITY=4220
ALL_221_FROMIP=221.13.128.0
ALL_221_TOIP=221.13.255.255
ALL_221_PRIORITY=4221
ALL_222_FROMIP=221.14.0.0
ALL_222_TOIP=221.15.255.255
ALL_222_PRIORITY=4222
ALL_223_FROMIP=221.192.0.0
ALL_223_TOIP=221.193.255.255
ALL_223_PRIORITY=4223
ALL_224_FROMIP=221.194.0.0
ALL_224_TOIP=221.194.255.255
ALL_224_PRIORITY=4224
ALL_225_FROMIP=221.195.0.0
ALL_225_TOIP=221.195.255.255
ALL_225_PRIORITY=4225
ALL_226_FROMIP=221.196.0.0
ALL_226_TOIP=221.197.255.255
ALL_226_PRIORITY=4226
ALL_227_FROMIP=221.198.0.0
ALL_227_TOIP=221.198.255.255
ALL_227_PRIORITY=4227
ALL_228_FROMIP=221.199.0.0
ALL_228_TOIP=221.199.31.255
ALL_228_PRIORITY=4228
ALL_229_FROMIP=221.199.32.0
ALL_229_TOIP=221.199.47.255
ALL_229_PRIORITY=4229
ALL_230_FROMIP=221.199.48.0
ALL_230_TOIP=221.199.63.255
ALL_230_PRIORITY=4230
ALL_231_FROMIP=221.199.64.0
ALL_231_TOIP=221.199.127.255
ALL_231_PRIORITY=4231
ALL_232_FROMIP=221.199.128.0
ALL_232_TOIP=221.199.191.255
ALL_232_PRIORITY=4232
ALL_233_FROMIP=221.199.192.0
ALL_233_TOIP=221.199.207.255
ALL_233_PRIORITY=4233
ALL_234_FROMIP=221.199.224.0
ALL_234_TOIP=221.199.255.255
ALL_234_PRIORITY=4234
ALL_235_FROMIP=221.200.0.0
ALL_235_TOIP=221.203.255.255
ALL_235_PRIORITY=4235
ALL_236_FROMIP=221.204.0.0
ALL_236_TOIP=221.205.255.255
ALL_236_PRIORITY=4236
ALL_237_FROMIP=221.206.0.0
ALL_237_TOIP=221.206.255.255
ALL_237_PRIORITY=4237
ALL_238_FROMIP=221.207.0.0
ALL_238_TOIP=221.207.63.255
ALL_238_PRIORITY=4238
ALL_239_FROMIP=221.207.64.0
ALL_239_TOIP=221.207.127.255
ALL_239_PRIORITY=4239
ALL_240_FROMIP=221.207.128.0
ALL_240_TOIP=221.207.255.255
ALL_240_PRIORITY=4240
ALL_241_FROMIP=221.208.0.0
ALL_241_TOIP=221.211.255.255
ALL_241_PRIORITY=4241
ALL_242_FROMIP=221.212.0.0
ALL_242_TOIP=221.212.255.255
ALL_242_PRIORITY=4242
ALL_243_FROMIP=221.213.0.0
ALL_243_TOIP=221.213.255.255
ALL_243_PRIORITY=4243
ALL_244_FROMIP=221.214.0.0
ALL_244_TOIP=221.215.255.255
ALL_244_PRIORITY=4244
ALL_245_FROMIP=221.216.0.0
ALL_245_TOIP=221.223.255.255
ALL_245_PRIORITY=4245
ALL_246_FROMIP=222.128.0.0
ALL_246_TOIP=222.131.255.255
ALL_246_PRIORITY=4246
ALL_247_FROMIP=222.132.0.0
ALL_247_TOIP=222.135.255.255
ALL_247_PRIORITY=4247
ALL_248_FROMIP=222.136.0.0
ALL_248_TOIP=222.143.255.255
ALL_248_PRIORITY=4248
ALL_249_FROMIP=222.160.0.0
ALL_249_TOIP=222.161.255.255
ALL_249_PRIORITY=4249
ALL_250_FROMIP=222.162.0.0
ALL_250_TOIP=222.162.255.255
ALL_250_PRIORITY=4250
ALL_251_FROMIP=222.163.0.0
ALL_251_TOIP=222.163.31.255
ALL_251_PRIORITY=4251
ALL_252_FROMIP=222.163.32.0
ALL_252_TOIP=222.163.63.255
ALL_252_PRIORITY=4252
ALL_253_FROMIP=222.163.64.0
ALL_253_TOIP=222.163.127.255
ALL_253_PRIORITY=4253
ALL_254_FROMIP=222.163.128.0
ALL_254_TOIP=222.163.255.255
ALL_254_PRIORITY=4254
[UPNP]
UPNPENABLE=NO
UPNPSTARTED=0
UPNPADPERIOD=1800
UPNPPORT=5431
[DDNS1]
ID="STATUS=NO&SERVICE=dyndns&USERNAME=&PASSWORD=&HOSTNAME=&RESULT=&REDIALPERIOD=360"
ID="STATUS=NO&SERVICE=3322&USERNAME=&PASSWORD=&HOSTNAME=&RESULT=&REDIALPERIOD=360"
ID="STATUS=NO&SERVICE=NOIP&USERNAME=&PASSWORD=&HOSTNAME=&RESULT="
NUMBER=3
[DDNS2]
NUMBER=3
[DDNS3]
NUMBER=3
[DDNS4]
NUMBER=3
[DDNS5]
NUMBER=3
[DDNS6]
NUMBER=3
[DDNS7]
NUMBER=3
[DDNS8]
NUMBER=3
[DDNS20]
NUMBER=3
[DDNS21]
NUMBER=3
[NSD1]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[NSD2]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=0
[NSD3]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=0
[NSD4]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=0
[NSD5]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[NSD6]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[NSD7]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[NSD8]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[NSD20]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[NSD21]
STATUS=YES
ENABLED=YES
RETRYCOUNT=3
RETRYPERIOD=10
ACTION=1
EN_HEAVYLOAD=NO
CONDITION=0
HEAVY_LOAD=1
EN_DEFAULT=YES
EN_ISPHOST=NO
ISPHOST=
EN_REMOTEHOST=NO
REMOTEHOST=
EN_DNSRESOLV=NO
DNSHOST=
NSDOK=1
[LOAD_BALANCE]
MODE=1
[AUTOBALANCE_RULE]
NUMBER=0
[AUTOBALANCE]
NUMBER=0
[IPGROUP_RULE]
NUMBER=0
[IPGROUP]
NUMBER=0
[STROUTE_RULE]
NUMBER=0
[STROUTE]
NUMBER=0
[SROUTE_SDS0]
ENABLED=0
INTERFACE=0
TABLE=100
ID="ID=1&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=58.16.0.0&TDIP=58.23.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=1"
ID="ID=2&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=58.144.0.0&TDIP=58.144.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=2"
ID="ID=3&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=58.154.0.0&TDIP=58.155.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=3"
ID="ID=4&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=58.240.0.0&TDIP=58.255.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=4"
ID="ID=5&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=60.0.0.0&TDIP=60.31.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=5"
ID="ID=6&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=60.208.0.0&TDIP=60.223.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=6"
ID="ID=7&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.48.0.0&TDIP=61.55.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=7"
ID="ID=8&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.133.0.0&TDIP=61.133.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=8"
ID="ID=9&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.134.96.0&TDIP=61.138.191.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=9"
ID="ID=10&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.139.128.0&TDIP=61.139.191.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=10"
ID="ID=11&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.148.0.0&TDIP=61.149.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=11"
ID="ID=12&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.156.0.0&TDIP=61.156.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=12"
ID="ID=13&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.158.0.0&TDIP=61.159.63.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=13"
ID="ID=14&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.161.0.0&TDIP=61.161.63.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=14"
ID="ID=15&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.161.128.0&TDIP=61.163.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=15"
ID="ID=16&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.167.0.0&TDIP=61.168.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=16"
ID="ID=17&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.176.0.0&TDIP=61.176.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=17"
ID="ID=18&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.179.0.0&TDIP=61.179.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=18"
ID="ID=19&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.180.128.0&TDIP=61.182.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=19"
ID="ID=20&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.189.0.0&TDIP=61.189.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=20"
ID="ID=21&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=61.240.0.0&TDIP=61.243.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=21"
ID="ID=22&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=110.6.0.0&TDIP=110.7.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=22"
ID="ID=23&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=110.16.0.0&TDIP=110.19.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=23"
ID="ID=24&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=110.52.0.0&TDIP=110.53.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=24"
ID="ID=25&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=110.72.0.0&TDIP=110.73.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=25"
ID="ID=26&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=110.228.0.0&TDIP=110.231.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=26"
ID="ID=27&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=110.240.0.0&TDIP=110.255.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=27"
ID="ID=28&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=111.85.0.0&TDIP=111.85.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=28"
ID="ID=29&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=111.160.0.0&TDIP=111.167.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=29"
ID="ID=20&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=111.192.0.0&TDIP=111.207.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=30"
ID="ID=31&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.64.0.0&TDIP=112.65.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=31"
ID="ID=32&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.80.0.0&TDIP=112.97.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=32"
ID="ID=33&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.109.128.0&TDIP=112.109.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=33"
ID="ID=34&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.111.0.0&TDIP=112.111.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=34"
ID="ID=35&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.122.0.0&TDIP=112.123.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=35"
ID="ID=36&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.132.0.0&TDIP=112.132.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=36"
ID="ID=37&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.192.0.0&TDIP=112.195.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=37"
ID="ID=38&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=112.224.0.0&TDIP=113.9.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=38"
ID="ID=39&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=113.56.0.0&TDIP=113.59.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=39"
ID="ID=40&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=113.194.0.0&TDIP=113.195.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=40"
ID="ID=41&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=113.200.0.0&TDIP=113.201.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=41"
ID="ID=42&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=113.204.0.0&TDIP=113.207.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=42"
ID="ID=43&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=113.224.0.0&TDIP=114.255.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=43"
ID="ID=44&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=115.46.0.0&TDIP=115.46.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=44"
ID="ID=45&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=115.48.0.0&TDIP=115.63.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=45"
ID="ID=46&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=115.85.192.0&TDIP=115.85.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=46"
ID="ID=47&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=116.2.0.0&TDIP=116.3.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=47"
ID="ID=48&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=116.69.0.0&TDIP=116.70.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=48"
ID="ID=49&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=116.95.0.0&TDIP=116.95.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=49"
ID="ID=50&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=116.112.0.0&TDIP=116.117.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=50"
ID="ID=51&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=117.8.0.0&TDIP=117.15.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=51"
ID="ID=52&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=118.72.0.0&TDIP=118.81.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=52"
ID="ID=53&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=118.212.0.0&TDIP=118.212.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=53"
ID="ID=54&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.4.0.0&TDIP=119.7.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=54"
ID="ID=55&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.36.0.0&TDIP=119.36.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=55"
ID="ID=56&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.39.0.0&TDIP=119.39.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=56"
ID="ID=57&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.48.0.0&TDIP=119.55.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=57"
ID="ID=58&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.62.0.0&TDIP=119.62.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=58"
ID="ID=59&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.108.0.0&TDIP=119.109.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=59"
ID="ID=60&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.112.0.0&TDIP=119.119.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=60"
ID="ID=61&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.162.0.0&TDIP=119.167.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=61"
ID="ID=62&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.176.0.0&TDIP=119.191.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=62"
ID="ID=63&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=119.248.0.0&TDIP=119.251.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=63"
ID="ID=64&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=120.0.0.0&TDIP=120.15.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=64"
ID="ID=65&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=120.80.0.0&TDIP=120.87.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=65"
ID="ID=66&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=121.16.0.0&TDIP=121.31.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=66"
ID="ID=67&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=122.8.0.0&TDIP=122.15.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=67"
ID="ID=68&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=122.96.0.0&TDIP=122.97.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=68"
ID="ID=69&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=122.136.0.0&TDIP=122.143.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=69"
ID="ID=70&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=122.144.128.0&TDIP=122.144.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=70"
ID="ID=71&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=122.156.0.0&TDIP=122.159.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=71"
ID="ID=72&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=122.192.0.0&TDIP=122.195.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=72"
ID="ID=73&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.4.0.0&TDIP=123.15.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=73"
ID="ID=74&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.49.128.0&TDIP=123.49.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=74"
ID="ID=75&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.56.0.0&TDIP=123.63.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=75"
ID="ID=76&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.99.128.0&TDIP=123.99.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=76"
ID="ID=77&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.112.0.0&TDIP=123.135.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=77"
ID="ID=78&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.138.0.0&TDIP=123.139.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=78"
ID="ID=79&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.144.0.0&TDIP=123.148.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=79"
ID="ID=80&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.152.0.0&TDIP=123.159.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=80"
ID="ID=81&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.188.0.0&TDIP=123.191.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=81"
ID="ID=82&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.206.0.0&TDIP=123.207.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=82"
ID="ID=83&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=123.232.0.0&TDIP=123.235.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=83"
ID="ID=84&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=124.64.0.0&TDIP=124.66.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=84"
ID="ID=85&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=124.67.0.0&TDIP=124.67.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=85"
ID="ID=86&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=124.88.0.0&TDIP=124.95.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=86"
ID="ID=87&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=124.128.0.0&TDIP=124.135.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=87"
ID="ID=88&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=124.160.0.0&TDIP=124.167.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=88"
ID="ID=89&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=125.32.0.0&TDIP=125.47.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=89"
ID="ID=90&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=125.211.0.0&TDIP=125.211.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=90"
ID="ID=91&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=125.215.0.0&TDIP=125.215.63.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=91"
ID="ID=92&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=125.222.0.0&TDIP=125.223.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=92"
ID="ID=93&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=175.16.0.0&TDIP=175.23.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=93"
ID="ID=94&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=175.42.0.0&TDIP=175.44.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=94"
ID="ID=95&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=180.129.128.0&TDIP=180.130.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=95"
ID="ID=96&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=183.92.0.0&TDIP=183.95.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=96"
ID="ID=97&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=183.184.0.0&TDIP=183.191.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=97"
ID="ID=98&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.38.143.0&TDIP=202.38.143.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=98"
ID="ID=99&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.96.0.0&TDIP=202.96.95.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=99"
ID="ID=100&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.97.128.0&TDIP=202.98.15.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=100"
ID="ID=101&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.99.0.0&TDIP=202.99.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=101"
ID="ID=102&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.102.128.0&TDIP=202.102.191.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=102"
ID="ID=103&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.102.224.0&TDIP=202.102.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=103"
ID="ID=104&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.106.0.0&TDIP=202.107.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=104"
ID="ID=105&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.108.0.0&TDIP=202.108.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=105"
ID="ID=106&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.110.0.0&TDIP=202.110.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=106"
ID="ID=107&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.110.192.0&TDIP=202.110.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=107"
ID="ID=108&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.111.128.0&TDIP=202.112.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=108"
ID="ID=109&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.127.194.0&TDIP=202.127.195.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=109"
ID="ID=110&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.130.224.0&TDIP=202.130.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=110"
ID="ID=111&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=202.192.0.0&TDIP=202.199.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=111"
ID="ID=112&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=203.92.160.0&TDIP=203.92.191.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=112"
ID="ID=113&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=203.93.8.0&TDIP=203.93.8.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=113"
ID="ID=114&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=203.93.64.0&TDIP=203.93.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=114"
ID="ID=115&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=203.93.160.0&TDIP=203.93.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=115"
ID="ID=116&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=203.95.0.0&TDIP=203.95.7.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=116");
ID="ID=117&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=203.135.160.0&TDIP=203.135.175.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=117"
ID="ID=118&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.13.0.0&TDIP=210.13.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=118"
ID="ID=119&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.14.64.0&TDIP=210.14.95.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=119"
ID="ID=120&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.14.160.0&TDIP=210.14.223.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=120"
ID="ID=121&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.15.32.0&TDIP=210.15.63.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=121"
ID="ID=122&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.15.96.0&TDIP=210.15.191.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=122"
ID="ID=123&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.21.0.0&TDIP=210.22.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=123"
ID="ID=124&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.40.0.0&TDIP=210.47.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=124"
ID="ID=125&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.51.0.0&TDIP=210.53.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=125"
ID="ID=126&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.56.192.0&TDIP=210.56.223.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=126"
ID="ID=127&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.72.0.0&TDIP=210.72.127.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=127"
ID="ID=128&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.74.96.0&TDIP=210.78.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=128"
ID="ID=129&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=210.82.0.0&TDIP=210.83.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=129"
ID="ID=130&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=211.64.0.0&TDIP=211.67.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=130"
ID="ID=131&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=211.90.0.0&TDIP=211.97.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=131"
ID="ID=132&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=211.100.0.0&TDIP=211.100.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=132"
ID="ID=133&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=211.144.0.0&TDIP=211.145.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=133"
ID="ID=134&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=211.156.0.0&TDIP=211.159.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=134"
ID="ID=135&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.7.0.0&TDIP=218.12.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=135"
ID="ID=136&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.21.128.0&TDIP=218.21.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=136"
ID="ID=137&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.24.0.0&TDIP=218.29.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=137"
ID="ID=138&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.56.0.0&TDIP=218.61.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=138"
ID="ID=139&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.67.128.0&TDIP=218.69.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=139"
ID="ID=140&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.104.0.0&TDIP=218.107.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=140"
ID="ID=141&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.109.0.0&TDIP=218.109.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=141"
ID="ID=142&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.200.0.0&TDIP=218.203.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=142"
ID="ID=143&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=218.240.0.0&TDIP=218.247.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=143"
ID="ID=144&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=219.154.0.0&TDIP=219.159.63.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=144"
ID="ID=145&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=219.232.0.0&TDIP=219.235.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=145"
ID="ID=146&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=220.112.0.0&TDIP=220.112.63.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=146"
ID="ID=147&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=220.192.0.0&TDIP=220.207.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=147"
ID="ID=148&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=220.248.0.0&TDIP=220.252.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=148"
ID="ID=149&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=221.0.0.0&TDIP=221.12.191.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=149"
ID="ID=150&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=221.13.0.0&TDIP=221.15.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=150"
ID="ID=151&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=221.192.0.0&TDIP=221.199.207.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=151"
ID="ID=152&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=221.199.224.0&TDIP=221.223.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=152"
ID="ID=153&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=222.128.0.0&TDIP=222.143.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=153"
ID="ID=154&FSIP=0.0.0.0&TSIP=255.255.255.254&FDIP=222.160.0.0&TDIP=222.163.255.255&PTYPE=ALL&SSPORT=1&ESPORT=65535&SDPORT=1&EDPORT=65535&PY=154"
NUMBER=154
[SROUTE_SDS1]
ENABLED=0
INTERFACE=0
TABLE=100
NUMBER=0
[SROUTE_SDS2]
ENABLED=0
INTERFACE=0
TABLE=100
NUMBER=0
[LOG]
SORT=1
STATUS=NO
HOSTNAME=
STATUS1=NO
HOSTNAME1=
MAILLOG=NO
SMTP=
SMTP_AUTH=off
SMTP_PORT=25
SMTP_NAME=
SMTP_PASSWD=
EMAILSENDER=
EMAILADDR=
EMAILADDR1=
QUEUE=50
PERIOD=10
MAILNOW=
FILTER_EAMIL_ALERT=NO
HACK_EMAIL_ALERT=NO
STYPE=0
SIP=0.0.0.0
SPORT=0
STATISTICTYPE=0
ALLOWPOLICY=NO
DENYPOLICY=NO
PINGOFDEATH=NO
SYNFLOODING=NO
IPSPOOFING=NO
WINNUKE=NO
SMS_ENABLE=NO
DIAL1_CHECK=NO
DIAL2_CHECK=NO
LINK_UP=NO
LINK_DOWN=NO
AUTHENTICATION_FAIL=NO
COLD_START=NO
WARM_START=NO
DIAL_NUM1=
DIAL_NUM2=
USB1_LAST_SMS=
USB2_LAST_SMS=
USB1_LAST_SMS_TIME=0
USB2_LAST_SMS_TIME=0
USB1_CHECK=YES
USB2_CHECK=NO
ALARMSTATUS=0
ALARMHOST=
[PORT_101]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_102]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_103]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_104]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_105]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_106]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_107]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_108]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_109]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_110]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_111]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_112]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_113]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_114]
ENABLED=1
PRIORITY=1
TRUST_MODE=0
DEFAULT_COS=0
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
VLANGROUP=1
8021Q_MODE=1
PRIVATE_VID=1
PVID=4001
OUTPUT_TAGGING=0
8021X_ADMIN_STATE=0
8021X_STATE=1
[PORT_201]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4081
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_202]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4082
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_203]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4083
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_204]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4084
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_205]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4085
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_206]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4086
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_207]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4087
VLANGROUP=1
OUTPUT_TAGGING=0
[PORT_208]
ENABLED=1
SPEED=1
DUPLEX=1
AUTO=1
EEE=0
PRIORITY=1
PVID=4088
VLANGROUP=1
OUTPUT_TAGGING=0
[VLAN_DEFAULT]
ID="VID=4001&ENABLED=YES&DIR=0&CPU=1&DHCP1_ENABLED=YES&DHCP1_INDEX=1&DHCP2_ENABLED=YES&DHCP2_INDEX=2&DHCP3_ENABLED=YES&DHCP3_INDEX=3&DHCP4_ENABLED=YES&DHCP4_INDEX=4&MEMBER=255"
ID="VID=4051&ENABLED=YES&DIR=0&CPU=1&DHCP1_ENABLED=YES&DHCP1_INDEX=1&DHCP2_ENABLED=YES&DHCP2_INDEX=2&DHCP3_ENABLED=YES&DHCP3_INDEX=3&DHCP4_ENABLED=YES&DHCP4_INDEX=4&MEMBER=255"
ID="VID=4052&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4053&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4054&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4055&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4056&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4057&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4058&ENABLED=NO&DIR=0&CPU=1&DHCP1_ENABLED=NO&DHCP1_INDEX=0&DHCP2_ENABLED=NO&DHCP2_INDEX=0&DHCP3_ENABLED=NO&DHCP3_INDEX=0&DHCP4_ENABLED=NO&DHCP4_INDEX=0&&MEMBER=0"
ID="VID=4081&ENABLED=YES&DIR=1&CPU=1&MEMBER=32768"
ID="VID=4082&ENABLED=YES&DIR=1&CPU=1&MEMBER=16384"
ID="VID=4083&ENABLED=YES&DIR=1&CPU=1&MEMBER=8192"
ID="VID=4084&ENABLED=YES&DIR=1&CPU=1&MEMBER=4096"
ID="VID=4085&ENABLED=YES&DIR=1&CPU=1&MEMBER=2048"
ID="VID=4086&ENABLED=YES&DIR=1&CPU=1&MEMBER=1024"
ID="VID=4087&ENABLED=YES&DIR=1&CPU=1&MEMBER=512"
ID="VID=4088&ENABLED=YES&DIR=1&CPU=1&MEMBER=256"
NUMBER=17
ENABLED_NUMBER=10
[VLAN_TAG]
ENABLED=NO
NUMBER=9
ENABLED_NUMBER=9
[VLAN_TAG_LAN]
ID="VID=4001&ENABLED=YES&DIR=0&CPU=1&MEMBER=255"
NUMBER=1
[VLAN_TAG_WAN]
NUMBER=8
[VLAN_SUBNET]
ID="ENABLED=YES&SUBNET_INDEX=0&DHCP_ENABLED=YES&DHCP_INDEX=1&VID=4001"
NUMBER=1
ENABLED_NUMBER=1
[8021Q]
NUMBER=1
ENABLED=0
ID="NAME=Default&VLANID=1&PORT1=1&PORT2=1&PORT3=1&PORT4=1"
OUTPUT_TAGGING=0
[8021P]
ENABLED=0
IP_VLAN_PRIORITY_TYPE=0
PRIORITY_0_QUEUE=1
PRIORITY_1_QUEUE=0
PRIORITY_2_QUEUE=0
PRIORITY_3_QUEUE=1
PRIORITY_4_QUEUE=2
PRIORITY_5_QUEUE=2
PRIORITY_6_QUEUE=3
PRIORITY_7_QUEUE=3
DSCP_PRIORITY_0_MAPPING=00000000
DSCP_PRIORITY_1_MAPPING=00000000
DSCP_PRIORITY_2_MAPPING=11111111
DSCP_PRIORITY_3_MAPPING=22222222
DSCP_PRIORITY_4_MAPPING=22222222
DSCP_PRIORITY_5_MAPPING=33333333
DSCP_PRIORITY_6_MAPPING=22222222
DSCP_PRIORITY_7_MAPPING=22222222
QUEUE_0_WEIGHT=1
QUEUE_1_WEIGHT=2
QUEUE_2_WEIGHT=4
QUEUE_3_WEIGHT=8
QUEUE_0_RADIO_SP_WRR=0
QUEUE_1_RADIO_SP_WRR=0
QUEUE_2_RADIO_SP_WRR=0
QUEUE_3_RADIO_SP_WRR=0
[8021X]
ENABLED=0
RADIUS_IP=0.0.0.0
RADIUS_UDP_PORT=1812
RADIUS_SECRET=
PORT_LINK=22
[LLDP_SYSTEM]
MSG_TX_INTERVAL=30
MSG_TX_HOLDMULTIPLIER=4
REINITDELAY=2
TXDELAY=2
NOTIFICATION_INTERVAL=0
[LLDP_LOCAL_PORT_101]
ADMIN_STATUS=3
LOCAL_PORT_NOTIFY_ENABLE=2
TLV_TX_ENABLE=31
LOCAL_PORT_ENABLE=1
[LLDP_LOCAL_PORT_102]
ADMIN_STATUS=3
TLV_TX_ENABLE=31
LOCAL_PORT_ENABLE=1
[LLDP_LOCAL_PORT_103]
ADMIN_STATUS=3
TLV_TX_ENABLE=31
LOCAL_PORT_ENABLE=1
[LLDP_LOCAL_PORT_104]
ADMIN_STATUS=3
TLV_TX_ENABLE=31
LOCAL_PORT_ENABLE=1
[LLDP_LOCAL_PORT_201]
ADMIN_STATUS=3
TLV_TX_ENABLE=31
LOCAL_PORT_ENABLE=1
[SLV]
ENABLED=NO
ACCOUNT=
PASSWORD=
AUTOTRY_ENABLE=NO
AUTOTRY_TIMER=5
BACKUP=NO
REMOTE_SERVER0=
REMOTE_SERVER1=
REMOTE_SERVER2=
REMOTE_SERVER3=
[SLV_SERVER]
NUMBER=0
MAXNUM=100
ENABLE=0
[USB_GROUP]
USBREQ=0
NUMBER=0
LIMIT=400
REQPAGE=0
LINEPERPAGE=5
USBKEYNUMBER=0
WZAFTERSUBMIT=0
EDITNO=0
[IPSEC_SLV]
IPS="TNAME=slvips0&ENABLED=0"
slvips0_PSK=
slvips0_DPD=""
NUMBER=1
[IPSEC_G2G]
IPS="NAME=g2gips0&WEBNAME=Option&ENABLED=1&PkStrength=0&KEY_EXG_T=1&LG_T=1&LG_IF=1&LIKE_ID_T=0&LIKE_ID_NAME=&LocalCA=&LNET_T=1&LSUBNET=192.168.0.0&LMASK=255.255.255.0&RG_N=1&RG_T=0&RIKE_ID_T=0&RG_IP=Hidden&RNET_T=1&RSUBNET=10.1.1.0&RMASK=255.255.255.0&RemoteCA=&KEYM=2&PH1_DH=5&PH1_ENC=5&PH1_AUTH=2&PH1_TIME=28800&PH2_DH=2&PH2_ENC=3&PH2_AUTH=2&PH2_TIME=3600&PH2_HASH=0&ADV=1&POLICY=20&PSK=PshtOptM!j74jToM-3rGp0079g&DPD_PERIOD=10&DPD_ACT=1&DPD_RETRY=3&UPDN=&XAUTH=&XAUTH_TYPE=0&XAUTH_SERVER_INDEX=&USERNAME=&PASSWORD=&HB_Enable=0&HB_RemoteHost=0.0.0.0&HB_Interval=10&HB_RetryCount=3&TBK=1&RG_DNSBK=&LG_IFBK=1&TBKT=30&LG_BKmode=2&SDS1=&SDS2=&SDN1=&SDN2=&SDN3=&SDN4="
NUMBER=1
LINEPERPAGE=5
MAXNUM=50
PERPAGENUM=5
[IPSEC_GRP]
IPS="NAME=grpips0&WEBNAME=Easy VPN&ENABLED=1&PkStrength=1&KEY_EXG_T=1&LG_T=2&LG_IF=1&LIKE_ID_T=0&LIKE_ID_NAME=&LNET_T=1&LSUBNET=192.168.0.0&LMASK=255.255.255.0&RG_N=7&RG_T=6&RIKE_ID_T=10&RIKE_ID_NAME=Ipad&RG_IP=0&RNET_T=0&RSUBNET=0&RMASK=0&KEYM=2&PH1_DH=2&PH1_ENC=5&PH1_AUTH=2&PH1_TIME=86400&PH2_DH=2&PH2_ENC=5&PH2_AUTH=1&PH2_TIME=86400&PH2_HASH=0&ADV=1&POLICY=7381315&PSK=Hidden&DPD_PERIOD=10&DPD_ACT=1&DPD_RETRY=3&UPDN=&XAUTH=1&XAUTH_TYPE=1&XAUTH_SERVER_INDEX=0&USERNAME=&PASSWORD=&MODECFG=1&MODECFGID=4&TUNNELMODE=0"
NUMBER=1
LINEPERPAGE=5
MAXNUM=2
[IPSEC_GRE]
NUMBER=0
LINEPERPAGE=5
MAXNUM=1
[EASYACCESS]
PPPSTART=192.168.1.200
PPPEND=192.168.1.205
[SNMP]
ENABLED=NO
SNAME=router02af00router02af00.com
SCONTACT=
SLOCATION=
GCNAME=public
SCNAME=private
TCNAME=
SSTRAP=
WARM_START=0
SSTRAP_V6=
LAST_REBOOT=0
LAST_CHANGE=Sat May 13 10:32:57 2017, cisco changed
[SNMPV3]
ENABLED=NO
SSTRAP=
TRAP_USER=
NUMBER=0
[SNMP_GROUP]
NUMBER=0
[SSL]
NUMBER=5
PERPAGENUM_MYCA=5
PERPAGENUM_SSLCA=5
PERPAGENUM_IPSECCA=5
PERPAGENUM_STATUS=5
PERPAGENUM_GROUP=5
PERPAGENUM_RESOURCE=5
SSLDOMAINPERPAGE=5
SSLUSERPERPAGE=5
[SSL_GROUP]
NUMBER=0
GROUP_TYPE=1
GROUP_PASSWD=
GROUP_IP=
GROUP_DOMAIN=
[SSL_GROUP_RESOURCE]
RS="NAME=AllUsers&r1=1&r2=1&r3=1&r4=1&r5=1&r6=1&r7=1&r8=1"
RS="NAME=Supervisor&r1=1&r2=1&r3=1&r4=1&r5=1&r6=&r7=&r8=1"
RS="NAME=MobileUser&r1=1&r2=1&r3=1&r4=1&r5=1&r6=&r7=&r8=1"
RS="NAME=BranchStaff&r8=1"
NUMBER=4
[SSL_TSC]
RS="ID=r1&NAME=Word&ENABLE=0"
RS="ID=r2&NAME=Excel&ENABLE=0"
RS="ID=r3&NAME=PowerPoint&ENABLE=0"
RS="ID=r4&NAME=Access&ENABLE=0"
RS="ID=r5&NAME=Outlook&ENABLE=0"
RS="ID=r6&NAME=Internet Explorer&ENABLE=0"
RS="ID=r7&NAME=FrontPage&ENABLE=0"
RS="ID=r8&NAME=ERP&ENABLE=0"
NUMBER=8
[DYNAMIC_ROUTE]
WMODE=4
RIP=0
RVER=2
TVER=2
RIP_V6=0
[MULTI_WAN]
NUMBER=0
COUNTER=0
[MULTIPLE_SUBNET]
ENABLED=YES
ID="VID=1&IP=192.168.0.1&NETMASK=255.255.255.0&IS_ROUTE=1&DHCP_MODE=1&RELAY=0.0.0.0&TIME=1440&RANGES=192.168.0.50&RANGEE=192.168.0.149&DNS1=0.0.0.0&DNS2=0.0.0.0&WINS=0.0.0.0&TFTPN=&TFTPP=0.0.0.0&TFTPF=&CID=Null&DNSSERVER=1"
ID="VID=25&IP=192.168.2.1&NETMASK=255.255.255.0&IS_ROUTE=1&DHCP_MODE=1&RELAY=0.0.0.0&TIME=1440&RANGES=192.168.2.100&RANGEE=192.168.2.149&DNS1=0.0.0.0&DNS2=0.0.0.0&WINS=0.0.0.0&TFTPN=&TFTPP=0.0.0.0&TFTPF=&CID=Null&DNSSERVER=1"
ID="VID=100&IP=192.168.3.1&NETMASK=255.255.255.0&IS_ROUTE=1&DHCP_MODE=1&RELAY=0.0.0.0&TIME=1440&RANGES=192.168.3.100&RANGEE=192.168.3.149&DNS1=0.0.0.0&DNS2=0.0.0.0&WINS=0.0.0.0&TFTPN=&TFTPP=0.0.0.0&TFTPF=&CID=Null&DNSSERVER=1"
NUMBER=3
[LINE_DROPPED]
ACTIVE=0
INACTIVE=0
STATUS=00000
[WAN1_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN2_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN3_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN4_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN5_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN6_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN7_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[WAN8_LINE_DROPPED_SCHEDULE]
ENABLED=NO
TIME=0:0~1:0
RESTART=5
BACKUP=
[PPTP_SERVER]
ID="username=Tom&password=hidden&assigned_ip=0.0.0.0"
NUMBER=1
LIMIT=10
ENABLED=NO
TYPE=0
START_IP=192.168.0.150
END_IP=192.168.0.159
[ADV_DOS]
TCP_SYN=YES
UDP=YES
ICMP=YES
TCP_TOTAL_WAN=15000
TCP_TOTAL_LAN=50000
TCP_PERIP_WAN=1000
TCP_PERIP_LAN=5000
TCP_BLOCKTIME_WAN=50
TCP_BLOCKTIME_LAN=1
UDP_TOTAL_WAN=15000
UDP_TOTAL_LAN=50000
UDP_PERIP_WAN=1000
UDP_PERIP_LAN=5000
UDP_BLOCKTIME_WAN=50
UDP_BLOCKTIME_LAN=1
ICMP_TOTAL_WAN=200
ICMP_TOTAL_LAN=200
ICMP_PERIP_WAN=50
ICMP_PERIP_LAN=50
ICMP_BLOCKTIME_WAN=5
ICMP_BLOCKTIME_LAN=1
TCP_PERDESIP_LAN=5000
UDP_PERDESIP_LAN=5000
ICMP_PERDESIP_LAN=200
EXCEPTSRCIP=0
EXCEPTSRCIP_0_IPGROUP=0
EXCEPTSRCIP_0_IPSTART=0.0.0.0
EXCEPTSRCIP_0_IPEND=0.0.0.0
EXCEPTSRCIP_0_IPGROUP_ID=
EXCEPTSRCIP_1_IPGROUP=0
EXCEPTSRCIP_1_IPSTART=0.0.0.0
EXCEPTSRCIP_1_IPEND=0.0.0.0
EXCEPTSRCIP_1_IPGROUP_ID=
EXCEPTDESIP=0
EXCEPTDESIP_0=0.0.0.0
EXCEPTDESIP_1=0.0.0.0
EXCEPTDESIP_2=0.0.0.0
EXCEPTDESIP_3=0.0.0.0
EXCEPTDESIP_4=0.0.0.0
[SMART_QOS]
ENABLED=0
PENALTY=0
UP_BW_THR=500
DOWN_BW_THR=1000
UPRATIO=
DOWNRATIO=
UPSTREAM1=200
UPSTREAM2=200
UPSTREAM3=200
UPSTREAM4=200
UPSTREAM5=200
UPSTREAM6=200
UPSTREAM7=200
UPSTREAM8=200
UPSTREAMUSB1=200
UPSTREAMUSB2=200
UPSTREAMUSB3=200
UPSTREAMUSB4=200
UPSTREAMUSB5=200
UPSTREAMUSB6=200
UPSTREAMUSB7=200
UPSTREAMUSB8=200
DOWNSTREAM1=400
DOWNSTREAM2=400
DOWNSTREAM3=400
DOWNSTREAM4=400
DOWNSTREAM5=400
DOWNSTREAM6=400
DOWNSTREAM7=400
DOWNSTREAM8=400
DOWNSTREAMUSB1=400
DOWNSTREAMUSB2=400
DOWNSTREAMUSB3=400
DOWNSTREAMUSB4=400
DOWNSTREAMUSB5=400
DOWNSTREAMUSB6=400
DOWNSTREAMUSB7=400
DOWNSTREAMUSB8=400
START_CONDITION=60
TIMEON=0
DAYS=
START_HOUR=
START_MIN=
END_HOUR=
END_MIN=
DAYALL=NO
WAN_CHECK_RATE=50
SESSION_ENABLE=0
SESSION_THR=200
ADD_PERIOD=300
PENALTY_RATIO=50
DELETE_CONDITION=50
DEL_PERIOD=180
SQ_CHECK_UP_ENABLE=1
SQ_CHECK_DOWN_ENABLE=1
ACTIVE_PC_ENABLE=0
ACTIVE_PC_NUMBER=0
ACTIVE_PC_MIN_UPSTREAM1=0
ACTIVE_PC_MIN_UPSTREAM2=0
ACTIVE_PC_MIN_UPSTREAM3=0
ACTIVE_PC_MIN_UPSTREAM4=0
ACTIVE_PC_MIN_UPSTREAM5=0
ACTIVE_PC_MIN_UPSTREAM6=0
ACTIVE_PC_MIN_UPSTREAM7=0
ACTIVE_PC_MIN_UPSTREAM8=0
ACTIVE_PC_MIN_DOWNSTREAM1=0
ACTIVE_PC_MIN_DOWNSTREAM2=0
ACTIVE_PC_MIN_DOWNSTREAM3=0
ACTIVE_PC_MIN_DOWNSTREAM4=0
ACTIVE_PC_MIN_DOWNSTREAM5=0
ACTIVE_PC_MIN_DOWNSTREAM6=0
ACTIVE_PC_MIN_DOWNSTREAM7=0
ACTIVE_PC_MIN_DOWNSTREAM8=0
ACTIVE_PC_MAX_UPSTREAM1=1000
ACTIVE_PC_MAX_UPSTREAM2=1000
ACTIVE_PC_MAX_UPSTREAM3=1000
ACTIVE_PC_MAX_UPSTREAM4=1000
ACTIVE_PC_MAX_UPSTREAM5=1000
ACTIVE_PC_MAX_UPSTREAM6=1000
ACTIVE_PC_MAX_UPSTREAM7=1000
ACTIVE_PC_MAX_UPSTREAM8=1000
ACTIVE_PC_MAX_DOWNSTREAM1=1000
ACTIVE_PC_MAX_DOWNSTREAM2=1000
ACTIVE_PC_MAX_DOWNSTREAM3=1000
ACTIVE_PC_MAX_DOWNSTREAM4=1000
ACTIVE_PC_MAX_DOWNSTREAM5=1000
ACTIVE_PC_MAX_DOWNSTREAM6=1000
ACTIVE_PC_MAX_DOWNSTREAM7=1000
ACTIVE_PC_MAX_DOWNSTREAM8=1000
[PENALTY_IP]
NUMBER=0
[ADV_LOG]
SYNFLOOD=NO
SPOOFED=NO
WINNUKE=NO
BADFLAG=NO
LOGIN_FAIL=NO
SYSTEM_ERRS=NO
CONN_BLOCKED=NO
CONN_ACCEPTED=NO
CONF_CHANGE=NO
LOGIN_SUCCESS=NO
KERNEL_INFO=NO
SSL_INFO=NO
VPN_INFO=YES
NETWORK_INFO=NO
USB_INFO=NO
LIMIT=14
[SESSION_LIMIT]
STATUS=0
MAX1=200
MAX2=200
TCP=100
UDP=100
BLOCK_MIN1=5
BLOCK_MIN2=5
TIMEON=0
TIMESTART=00:00
TIMESTOP=23:59
DAYS=sun,mon,tue,web,thu,fri,sat
DAYALL=YES
[MIRRORP]
ENABLED=NO
[IPGROUP_LIST]
NUMBER=0
[VOICE]
ENABLED=0
TIME=2
WAN_UP_CHECK=1
WAN_UP_TIME=2
WAN_DOWN_CHECK=1
WAN_DOWN_TIME=2
UPSRTEAM_JAM_CHECK=1
UPSRTEAM_JAM_TIME=2
UPSRTEAM_JAM_PERIOD=5
UPSRTEAM_JAM_LOAD=80
DOWNSRTEAM_JAM_CHECK=1
DOWNSRTEAM_JAM_TIME=2
DOWNSRTEAM_JAM_PERIOD=5
DOWNSRTEAM_JAM_LOAD=80
WAN_DOS_CHECK=1
WAN_DOS_TIME=2
WAN_DOS_PERIOD=5
LAN_DOS_CHECK=1
LAN_DOS_TIME=2
LAN_DOS_PERIOD=6
BLOCK_WRONG_IP_CHECK=0
BLOCK_WRONG_IP_TIME=2
BLOCK_WRONG_IP_PERIOD=2
BLOCK_WRONG_IP_MAC=0
BLOCK_NOT_ON_LIST_CHECK=0
BLOCK_NOT_ON_LIST_TIME=2
BLOCK_NOT_ON_LIST_PERIOD=2
WAN_CHANGE_IP_CHECK=1
WAN_CHANGE_IP_TIME=2
WAN_CHANGE_IP_PERIOD=2
LOGIN_CHECK=1
LOGIN_TIME=2
LOGIN_PERIOD=2
SESSION_LIMIT_CHECK=0
SESSION_LIMIT_TIME=2
SESSION_LIMIT_PERIOD=5
ARP_CHECK=0
ARP_TIME=2
ARP_PERIOD=5
SHOCKWAVE_CHECK=0
SHOCKWAVE_TIME=2
SHOCKWAVE_PERIOD=5
BLOCK_WRONG_IP_IP=1
BLOCK_WRONG_IP_ADD_MAC=0
BLOCK_WRONG_IP_ADD_IP=1
HIDDEN=1
[QOS_SCHEDULE]
ENABLED=0
SUN=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
MON=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
TUES=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
WEDNES=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
THURS=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
FRI=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
SATUR=time_1=0&All_time=0&00:00~00:00&model_0=0&time_2=0&00:00~00:00&model_1=0&time_3=0&00:00~00:00&model_2=0&other=0
[EXCEPTION_QQ_NUMBER]
NUMBER=0
[SESSION_BASE_LOCK_LIST]
ID="PROTOCOL=6&SPORT=1863&EPORT=1863"
ID="PROTOCOL=6&SPORT=5050&EPORT=5050"
ID="PROTOCOL=17&SPORT=8000&EPORT=8005"
NUMBER=3
[SESSION_BASE_LIST]
ID="SIP=0.0.0.0&EIP=255.255.255.255&SPORT=443&EPORT=443"
NUMBER=1
[SESSION_BASE_DISPLAY_LIST]
ID="SIP=0.0.0.0&EIP=0.0.0.0&SPORT=443&EPORT=443&PTYPE=TCP&SNAME=HTTPS&GNAME=&SERVICE=6&ENABLE=1&IPMODE=1"
NUMBER=1
[L7_EXCEPTION]
NUMBER=0
ENABLED=0
[L7_FILE_EXCEPTION]
NUMBER=0
ENABLED=0
[IDS]
ENABLED=NO
USE_RISK=YES
LAN=YES
DMZ=YES
WAN1=YES
WAN2=YES
WAN3=YES
WAN4=YES
WAN5=YES
WAN6=YES
WAN7=YES
WAN8=YES
ON_LINE=0
[ANTI_SPAM]
ENABLED=0
SMTP_ENABLED=1
SMTP_PORT=25
POP3_ENABLED=1
POP3_PORT=110
SUBJECT_ADDTAG_ENABLED=1
BLACK_SUBJECT_ADDTAG_ENABLED=1
BLACK_SUBJECT=_BLACK_
THRESHOLD=0.5
VIRUS_SUBJECT=_VIRUS_
SPAM_SUBJECT=_SPAM_
GREYLIST_ENABLED=0
VERIFT_SENDER_ENABLED=0
CHECK_RBL_ENABLED=0
SUBJECT_ADDTAG_SCORE_ENABLED=0
BLACK_ENABLED=1
WHITE_ENABLED=1
WHITE_PRIORITY=1
HAM_CUTOFF=0.1
SPAM_CUTOFF=0.5
SPAM_COUNTER=0
HAM_COUNTER=0
TRAIN_SPAM_DATE=0
CHECK_VIRUS=0
CHECK_VIRUS_RESET=0
CHECK_VIRUS_DESTORY=0
CHECK_SPAM_RESET=0
TRAIN_SPAM_POP_SERVER=
TRAIN_SPAM_POP_USERNAME=
TRAIN_SPAM_POP_PASSWORD=
TRAIN_HAM_POP_SERVER=
TRAIN_HAM_POP_USERNAME=
TRAIN_HAM_POP_PASSWORD=
CHART=0
[BLACKLIST]
NUMBER=0
LIST_LIMIT=10
[WHITELIST]
NUMBER=0
LIST_LIMIT=10
[ANTI_IPS]
ENABLED=0
QUERY_TIME=0
UPDATE_NOW=NO
UPDATE_PERIOD=120
UPDATE_SERVER=
LAST_CHECKED=0
WAN_ENABLED=0
LAN_ENABLED=0
DMZ_ENABLED=0
SIGNATURE_MODE=0
RULES_NUMBER=4406
GROUPS_NUMBER=47
ACTION=0
LOG=0
ALARM=0
HIGH_ACTION=1
MEDIUM_ACTION=1
LOW_ACTION=1
HIGH_LOG=0
MEDIUM_LOG=0
LOW_LOG=0
HIGH_ALARM=0
MEDIUM_ALARM=0
LOW_ALARM=0
EXCLUSION_ENABLED=0
CHART=0
[AI_EXCLUSION_LIST]
NUMBER=0
[AI_EXCLUSION_DISPLAY_LIST]
NUMBER=0
[ANTI_VIRUS]
ENABLED=NO
CURRENT_MAIN_VER=
CURRENT_DAILY_VER=
CURRENT_SIGN=
ON_LINE=0
UPDATE_NOW=YES
LAST_CHECKED=0
LAN_ENABLED=NO
WAN_ENABLED=NO
DMZ_ENABLED=NO
APPEND_MESSAGE=
SMTP_ACTION=1
SMTP_ENABLED=NO
SMTP_LOG_ENABLED=NO
SMTP_MARCO_ENABLED=NO
SMTP_ENZIP_ENABLED=NO
SMTP_MESS_ENABLED=NO
POP3_ACTION=1
POP3_ENABLED=NO
POP3_LOG_ENABLED=NO
POP3_MARCO_ENABLED=NO
POP3_ENZIP_ENABLED=NO
POP3_MESS_ENABLED=NO
HTTP_ACTION=1
HTTP_ENABLED=NO
HTTP_LOG_ENABLED=NO
HTTP_MARCO_ENABLED=NO
HTTP_ENZIP_ENABLED=NO
FTP_ACTION=1
FTP_ENABLED=NO
FTP_LOG_ENABLED=NO
FTP_MARCO_ENABLED=NO
FTP_ENZIP_ENABLED=NO
FTP_SERVER_CHANGEPORT_ENABLED=YES
EXCLUSION_LIST_ENABLED=NO
CHART=0
[AV_EXCLUSION_LIST]
NUMBER=0
[AV_EXCLUSION_DISPLAY_LIST]
NUMBER=0
[HA]
ENABLE=0
MODE=1
BUPWAN=12
BUPLAN=192.168.0.5
[ACL_HIDDEN_RULE]
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=0&ACTION_TYPE=changedscp&ACTION_VALUE=0&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=1&ACTION_TYPE=changedscp&ACTION_VALUE=8&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=2&ACTION_TYPE=changedscp&ACTION_VALUE=16&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=3&ACTION_TYPE=changedscp&ACTION_VALUE=26&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=4&ACTION_TYPE=changedscp&ACTION_VALUE=34&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=5&ACTION_TYPE=changedscp&ACTION_VALUE=46&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=6&ACTION_TYPE=changedscp&ACTION_VALUE=48&ENABLE=1"
ID="FILTER_TYPE=0&MAC_TYPE=none&MAC_VALUE=&IP_TYPE=none&IP_VALUE=&PROTOCOL_TYPE=none&SRCPORT_TYPE=none&SRCPORT_VALUE=&DSTPORT_TYPE=none&DSTPORT_VALUE=1&COS=7&ACTION_TYPE=changedscp&ACTION_VALUE=56&ENABLE=1"
NUMBER=8
[ACL_DISPLAY_RULE]
NUMBER=0
[ACL_RULE]
NUMBER=8
[SOFT_KEY]
MAXTUNNEL=5
[USB_KEY_USER_LIST0501]
NUMBER=0
[AGING_TIME]
TCP_DEFAULT=1800
UDP_DEFAULT=30
NUMBER=0
[USB1_POWER_SAVING]
LOG=YES
AUTO_TEST=NO
TEST_TIME=00:00
MODE=1
IDLE_TIME_ENABLED=NO
IDLE_TIME=0
WAN1_NSD_ENABLED=YES
WAN2_NSD_ENABLED=YES
WAN1_THRESHOLD_ENABLED=NO
WAN2_THRESHOLD_ENABLED=NO
WAN1_OVER=10000
WAN2_OVER=10000
WAN1_UNDER_ENABLED=NO
WAN2_UNDER_ENABLED=NO
WAN1_UNDER=10
WAN2_UNDER=10
[USB2_POWER_SAVING]
LOG=YES
AUTO_TEST=NO
TEST_TIME=00:00
MODE=1
IDLE_TIME=0
WAN1_OVER=10000
WAN2_OVER=10000
WAN1_UNDER=10
WAN2_UNDER=10
[USB1_POWER_SAVING_SCHEDULE]
Sun=000000000000000000000000
Mon=000000000000000000000000
Tue=000000000000000000000000
Wed=000000000000000000000000
Thu=000000000000000000000000
Fri=000000000000000000000000
Sat=000000000000000000000000
[USB2_POWER_SAVING_SCHEDULE]
[INBOUND_LB]
USERNAME_UI=@
[spf1]
NUMBER=0
PERPAGENUM=5
[spf2]
NUMBER=0
[DB_BACK]
EVERY=YES
PERIOD=1
TIME_UNIT=3600
DB1PERIOD=24
DB2PERIOD=1
REBOOT=YES
MERGE=0
[NAT_ACC]
ENABLED=YES
[StockSoftware]
ID="ID=1&APP_NAME=ThsSzx&TYPE=1&PROTOCOL=TCP&SDPORT=8601&EDPORT=8601&SDEST=&EDEST="
ID="ID=6&APP_NAME=Djh6&TYPE=1&PROTOCOL=TCP&SDPORT=7708&EDPORT=7709&SDEST=&EDEST="
ID="ID=2&APP_NAME=SzxSwtdCltdGsjc&TYPE=0&PROTOCOL=TCP&EDPORT=&EDPROT=&SDEST=202.102.92.138&EDEST=202.102.92.140"
ID="ID=3&APP_NAME=Hcy&TYPE=1&PROTOCOL=TCP&SDPORT=9000&EDPORT=9000&SDEST=&EDEST="
ID="ID=7&APP_NAME=djhi&TYPE=1&PROTOCOL=TCP&SDPORT=9999&EDPORT=9999&SDEST=&EDEST="
ID="ID=4&APP_NAME=Cl&TYPE=1&PROTOCOL=TCP&SDPORT=6188&EDPORT=5188&SDEST=&EDEST="
ID="ID=5&APP_NAME=Hstz&TYPE=1&PROTOCOL=TCP&SDPORT=22223&EDPORT=22223&SDEST=&EDEST="
ID="ID=8&APP_NAME=Pobo&TYPE=1&PROTOCOL=TCP&SDPORT=13152&EDPORT=13152&SDEST=&EDEST="
NUMBER=8
UIITEM=0
[Stock_G_Split]
NUMBER=0
CHECKED=0
[OnlineVedio]
ID="ID=1&APP_NAME=Tudou&DST=www.tudou.com"
ID="ID=2&APP_NAME=baidu&DST=video.baidu.com"
ID="ID=3&APP_NAME=Qq&DST=bb.news.qq.com&DST=video.qq.com&DST=v.qq.com"
ID="ID=4&APP_NAME=Kuaiche&DST=video.kuaiche.com&DST=v.myrice.com"
ID="ID=5&APP_NAME=ifeng&DST=v.ifeng.com"
ID="ID=6&APP_NAME=56&DST=www.56.com"
ID="ID=7&APP_NAME=Ku6&DST=ku6.com"
ID="ID=8&APP_NAME=Pomoho&DST=pomoho.com"
ID="ID=9&APP_NAME=Dashi&DST=www.dashi.com"
ID="ID=10&APP_NAME=Youtube&DST=www.youtube.com"
ID="ID=11&APP_NAME=Uuuso&DST=uuuso.com"
ID="ID=12&APP_NAME=516&DST=www.516.com"
ID="ID=13&APP_NAME=6&DST=6.cn"
ID="ID=14&APP_NAME=Waga&DST=www.waga.com"
ID="ID=15&APP_NAME=Aeeboo&DST=aabbz.com"
ID="ID=16&APP_NAME=Sohu&DST=v.sohu.com&DST=tv.sohu.com"
ID="ID=17&APP_NAME=Hupo&DST=www.hupo.tv"
ID="ID=18&APP_NAME=Xinnong&DST=tv.xinnong.com"
ID="ID=19&APP_NAME=Openv&DST=www.openv.com"
ID="ID=20&APP_NAME=Blinkx&DST=tv.blinkx.com"
ID="ID=21&APP_NAME=Vzone&DST=vzone.xunlei.com"
ID="ID=22&APP_NAME=Uusee&DST=uusee.com"
ID="ID=23&APP_NAME=Grouper&DST=crackle.com"
ID="ID=24&APP_NAME=Jumpcut&DST=www.jumpcut.com"
ID="ID=25&APP_NAME=Sina&DST=bn.news.sina.com.cn&DST=video.sina.com.cn&DST=v.sina.com.cn"
ID="ID=26&APP_NAME=Metacafe&DST=www.metacafe.com"
ID="ID=27&APP_NAME=Videobomb&DST=www.videobomb.co&DST=www.getmiro.com&DST=www.videobomb.pl"
ID="ID=28&APP_NAME=Gou&DST=video.gougou.com"
ID="ID=29&APP_NAME=Zol&DST=v.zol.com.cn"
ID="ID=33&APP_NAME=Xinhun&DST=media.xinhuanet.com"
ID="ID=30&APP_NAME=Google&DST=video.google.com"
ID="ID=31&APP_NAME=Youku&DST=youku.com"
ID="ID=32&APP_NAME=Joy&DST=joy.cn"
NUMBER=33
VEDIOITEM=0
[Vedio_G_Split]
NUMBER=0
CHECKED=0
[SSLVPN_PORTAL_LAYOUT]
BACKGROUND_ENABLE=0
BACKGROUND=
LOGO_ENABLE=0
LOGO=
[EBOARD]
ID="NAME=Default&TITLE=&CONTENT=&SCHEDULE_ENABLE=0&INTERVAL=24&EBOARD_ACCESS_SETUP_ENABLED=0"
NUMBER=1
ENABLED=NO
[REDIRECT_URL]
ENABLED=NO
URL=http://
[ARP_BINDING]
ENABLED=NO
ENABLED_BID_ARP=NO
REFRESH_TIME=5
SEARCH_TYPE=0
IP=0.0.0.0
MAC=00:00:00:00:00:00
ORDER_BY_IP=1
ORDER_BY_TYPE=0
WAITTING_LIST=0
[TUNNEL]
6TO4_STATUS=1
6TO4_INTERFACE=1
[RADVD]
STATUS=YES
MODE=0
INTERVAL=30
FLAG_M=YES
FLAG_O=YES
PREFERENCE=2
MTU=1500
LIFETIME=3600
NUMBER=0
PERPAGENUM=5
[ACCESS_USER]
NUMBER=0
UNBINDING_EBOARD=1
[ACCESS_USER_LIST]
NUMBER=0
[LOGIN_CLIENT]
NUMBER=0
PER_PAGE=5
ORDER_BY_IP=1
ORDER_BY_TIME=0
[DNS_LOCAL_DATABASE]
NUMBER=0
PERPAGENUM=5
[DNS_LOCAL_DATABASE_V6]
NUMBER=0
PERPAGENUM=5
[TR069_CONFIGURATION]
TR069_ENABLE=NO
ACS_URL=
ACS_USER_NAME=
ACS_PASSWORD=
ACS_INFORM_ENABLE=NO
ACS_INFORM_INTERVAL=
CONNECT_USER_NAME=
CONNECT_PASSWORD=
CONNECT_WAN=
CONNECT_IP=
ACS_DOMAINNAME=
ACS_IP=
PRIORITY="PRI1=1&PRI2=1&PRI3=1"
CURRENT_PRIORITY=
OLDACS_IP=
OLDCONNECT_WAN=
OLDCONNECT_WAN_GATEWAY=
EVEN=
URL_TYPE=
PROVISIONINGCODE=
ACS_INFORM_TIME=
UPGRADESMANAGED=
URL_END=
[LLDP]
ENABLE=1
INTERFACE=eth0,eth1,eth2,eth3,eth4,eth5,eth6,eth7,eth8
PERPAGENUM=5
[MODECFG_VIRTUAL_IP]
START_IP=172.150.160.20
END_IP=172.150.160.50
DNS1=192.168.0.1
DNS2=0.0.0.0
WINS1=0.0.0.0
WINS2=0.0.0.0
DOMAINNAME1=
DOMAINNAME2=
DOMAINNAME3=
DOMAINNAME4=
NUMBER=0
[PPPOE_SERVER_SETTING]
Enabled=0
Server_IP=10.10.10.1
StartIP=10.10.10.2
EndIP=10.10.10.254
MainDNS=0.0.0.0
SecondDNS=0.0.0.0
AuthMode=0
LCPinterval=10
LCPtimes=5
TotalNum=253
setNum=300
OnlineNum=0
FORBIDLAN=1
MTU=1492
[PPPOE_USER_SETTING]
NUMBER=0
[WAN_IP_ALIAS]
NUMBER=0
[ONLINE_UPDATE]
LAST_CHECK_TIME=
VERSION_PRE=V0.0.0.0
VERSION_CUR=V1.0.0.0
VERSION_NEXT=V1.0.0.0
VERSION_STATUS=V1.0.0.0
PORT=443
SERVER=www.slvOnlineUpdate.com
SERVER_TYPE=0
SERVER_IP_DOMAIN=
SERVER_PORT=443
CHECK_TYPE=1
CHECK_HOURS=24
UPGRADE_TYPE=0
UPGRADE_TIME=23
REFRESH_NOW=0
REFRESH_COUNT=0
CLICK_DOWNLOAD=0
ERROR_NO=0
UPGRADE_DAYS=1111111
FILE_SIZE=0
DOWN_SIZE=0
[IPGRE]
NUMBER=0
LINEPERPAGE=5
MAXNUM=10
[RESTRICT_LIST]
NUMBER=0
[RESTRICT_LIST_PORT]
ID="RID=ipp2p_103&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_105&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_251&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_252&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_253&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_254&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_16&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_176&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_17&BAW=1&TNUM=1&T1=80&UNUM=0"
ID="RID=ipp2p_151&BAW=1&TNUM=1&T1=443&UNUM=0"
ID="RID=ipp2p_152&BAW=1&TNUM=2&T1=8000&T2=80&UNUM=0"
ID="RID=ipp2p_351&BAW=1&TNUM=1&T1=80&UNUM=2&U1=53&U2=1024:65535"
ID="RID=ipp2p_352&BAW=1&TNUM=1&T1=80&UNUM=1&U1=53"
ID="RID=ipp2p_355&BAW=1&TNUM=1&T1=80&UNUM=2&U1=53&U2=1024:65535"
ID="RID=ipp2p_356&BAW=1&TNUM=1&T1=80&UNUM=2&U1=53&U2=1024:65535"
ID="RID=ipp2p_353&BAW=1&TNUM=1&T1=80&UNUM=2&U1=53&U2=1024:65535"
ID="RID=ipp2p_354&BAW=1&TNUM=1&T1=80&UNUM=2&U1=53&U2=1024:65535"
NUMBER=0
[L7_APP_USER_DEFINE]
NUMBER=0
[RESTRICT_RULE_LIST]
NUMBER=0
EXCEPT_QQ=NO
PERPAGE=1
IF_RULEEDITNO=0
IF_RULECOUNT=0
IF_LINEPERPAGE=5
IF_TPAGE=1
IF_CURRPAGE=1
DELETEIF_RULE=0
[RESTRICT_EXCEPT_QQ]
NUMBER=0
[RESTRICT_EXCEPT_IP]
NUMBER=0
[L7_VIP_RULE_LIST]
NUMBER=0
PERPAGE=1
L7VIP_RULEEDITNO=0
L7VIP_RULECOUNT=0
L7VIP_LINEPERPAGE=5
L7VIP_TPAGE=1
L7VIP_CURRPAGE=1
DELETEL7VIP_RULE=0
[L7_VIP_LIST]
NUMBER=0
[L7_QOS_RULE_LIST]
NUMBER=0
PERPAGE=1
L7QOS_RULEEDITNO=0
L7QOS_RULECOUNT=0
L7QOS_LINEPERPAGE=5
L7QOS_TPAGE=1
L7QOS_CURRPAGE=1
DELETEL7QOS_RULE=0
[L7_QOS_LIST]
NUMBER=0
[L7_BIND_RULE_LIST]
NUMBER=0
PERPAGE=1
L7BIND_RULEEDITNO=0
L7BIND_RULECOUNT=0
L7BIND_LINEPERPAGE=5
L7BIND_TPAGE=1
L7BIND_CURRPAGE=1
DELETEL7Bind_RULE=0
[L7_BIND_LIST]
NUMBER=0
[APP_STATUS]
NUMBER=0
PERPAGE=1
AS_RULEEDITNO=0
AS_LINEPERPAGE=10
AS_TPAGE=1
AS_CURRPAGE=1
[ALLOW_RESTRICT_RULE_LIST]
NUMBER=0
EXCEPT_QQ=NO
PERPAGE=1
IF_RULEEDITNO=0
IF_RULECOUNT=0
IF_LINEPERPAGE=5
IF_TPAGE=1
IF_CURRPAGE=1
DELETEIF_RULE=0
STYLE=0
[ALLOW_RESTRICT_EXCEPT_QQ]
NUMBER=0
[ALLOW_RESTRICT_EXCEPT_IP]
NUMBER=0
[WHITE_PORT_LIST]
ID="AP=new_qq&NUM=1&P1=17:8000:8000"
ID="AP=new_msn&NUM=2&P1=6:1863:1863&P2=6:443:443"
ID="AP=new_yahoo&NUM=2&P1=6:5050:5050&P2=6:443:443"
ID="AP=new_googletalk&NUM=2&P1=6:5222:5222&P2=6:443:443"
ID="AP=new_skype&NUM=1&P1=6:443:443"
ID="AP=vpn_ipsec&NUM=2&P1=17:500:500&P2=50:50:50"
ID="AP=vpn_pptp&NUM=2&P1=6:1723:1723&P2=47:47:47"
ID="AP=vpn_ssl&NUM=1&P1=6:992:992"
ID="AP=vpn_l2tp&NUM=1&P1=17:1701:1701"
ID="AP=vpn_gre&NUM=1&P1=47:47:47"
ID="AP=email_smtp&NUM=1&P1=6:25:25"
ID="AP=email_pop3&NUM=1&P1=6:110:110"
ID="AP=email_webmail&NUM=2&P1=6:80:80&P2=6:443:443"
ID="AP=email_pop3s&NUM=1&P1=6:995:995"
ID="AP=email_smtps&NUM=1&P1=6:465:465"
ID="AP=email_imap&NUM=1&P1=6:143:143"
ID="AP=network_telnet&NUM=2&P1=6:23:23&P2=6:4611:4611"
ID="AP=network_ssh&NUM=1&P1=6:22:22"
ID="AP=network_ftp&NUM=1&P1=6:21:21"
ID="AP=network_tftp&NUM=1&P1=17:69:69"
ID="AP=network_snmp&NUM=1&P1=17:161:161"
ID="AP=other_webpage&NUM=2&P1=6:80:80&P2=6:8080:8080"
ID="AP=network_syslog&NUM=1&P1=17:514:514"
ID="AP=other_rdp&NUM=1&P1=6:3389:3389"
ID="AP=other_teamviever&NUM=1&P1=6:80:80"
ID="AP=other_VNC&NUM=1&P1=6:5900:5906"
ID="AP=other_pc&NUM=2&P1=6:5631:5631&P2=17:5632:5632"
ID="AP=network_icmp&NUM=1&P1=1:1:1"
NUMBER=28
[INBOUND_RESTRICT_RULE_LIST]
NUMBER=0
ENABLEL7INBOUND=NO
PERPAGE=1
L7INBOUND_RULEEDITNO=0
L7INBOUND_RULECOUNT=0
L7INBOUND_LINEPERPAGE=5
L7INBOUND_TPAGE=1
L7INBOUND_CURRPAGE=1
DELETEL7INBOUND_RULE=0
[INBOUND_RESTRICT_EXCEPT_IP]
NUMBER=0
[L7_INBOUND_INTERNAL_SERVER]
NUMBER=0
[L7_APP_USER_DEFINE_INBOUND]
NUMBER=0
[EXCEPT_IP_INBOUND]
NUMBER=0
[VPN_SERVICE_PORT]
NUMBER=0
[VPN_DEFAULT_SERVICE]
ID="SPORT=6112&EPORT=6112&PROTO=tcp"
ID="SPORT=6112&EPORT=6112&PROTO=udp"
ID="SPORT=27000&EPORT=27025&PROTO=udp"
ID="SPORT=3840&EPORT=3840&PROTO=tcp"
ID="SPORT=3840&EPORT=3840&PROTO=udp"
ID="SPORT=4711&EPORT=4711&PROTO=tcp"
ID="SPORT=16567&EPORT=16567&PROTO=udp"
ID="SPORT=27015&EPORT=27015&PROTO=tcp"
ID="SPORT=27030&EPORT=27039&PROTO=tcp"
ID="SPORT=6003&EPORT=6003&PROTO=tcp"
ID="SPORT=7001&EPORT=7002&PROTO=tcp"
ID="SPORT=6003&EPORT=6003&PROTO=udp"
ID="SPORT=28960&EPORT=28960&PROTO=tcp"
ID="SPORT=28960&EPORT=28960&PROTO=udp"
ID="SPORT=3783&EPORT=3783&PROTO=tcp"
ID="SPORT=6515&EPORT=6515&PROTO=udp"
ID="SPORT=8086&EPORT=8086&PROTO=udp"
ID="SPORT=3366&EPORT=3366&PROTO=udp"
ID="SPORT=3658&EPORT=3658&PROTO=udp"
ID="SPORT=4000&EPORT=4000&PROTO=udp"
ID="SPORT=9999&EPORT=9999&PROTO=udp"
ID="SPORT=443&EPORT=443&PROTO=tcp"
ID="SPORT=9570&EPORT=9570&PROTO=udp"
ID="SPORT=13505&EPORT=13505&PROTO=tcp"
ID="SPORT=28004&EPORT=28004&PROTO=udp"
ID="SPORT=27960&EPORT=27960&PROTO=udp"
ID="SPORT=25600&EPORT=25600&PROTO=tcp"
ID="SPORT=25600&EPORT=25600&PROTO=udp"
ID="SPORT=4000&EPORT=4000&PROTO=tcp"
ID="SPORT=18000&EPORT=18000&PROTO=tcp"
ID="SPORT=18000&EPORT=18000&PROTO=udp"
NUMBER=31
[WIRELESS]
SSID1=RT2860AP
SSID2=
SSID3=
SSID4=
BROCAST_SSID1=YES
BROCAST_SSID2=NO
BROCAST_SSID3=NO
BROCAST_SSID4=NO
WIRELESS_EN=YES
WIRELESS_MODE=9
WIRELESS_FREQ=0
SECURITY_SSID=1
SECURITY_MODE=0
SECURITY_ALLOW=
SECURITY_AUTH_TYPE=
SECURITY_WPA=0
SECURITY_KEY_REN=30
SECURITY_SHARE_SECRET=
SECURITY_RADIUS_IP=
SECURITY_RADIUS_PORT=1812
SECURITY_DEF_TRAN_KEY=1
SECURITY_WEP=0
SECURITY_PASSPHRASE=
SECURITY_KEY1=
SECURITY_KEY2=
SECURITY_KEY3=
SECURITY_KEY4=
SECURITY_MODE_1=0
SECURITY_ALLOW_1=
SECURITY_AUTH_TYPE_1=
SECURITY_WPA_1=0
SECURITY_KEY_REN_1=30
SECURITY_SHARE_SECRET_1=
SECURITY_RADIUS_IP_1=
SECURITY_RADIUS_PORT_1=1812
SECURITY_DEF_TRAN_KEY_1=1
SECURITY_WEP_1=0
SECURITY_PASSPHRASE_1=
SECURITY_KEY1_1=
SECURITY_KEY2_1=
SECURITY_KEY3_1=
SECURITY_KEY4_1=
SECURITY_MODE_2=0
SECURITY_ALLOW_2=
SECURITY_AUTH_TYPE_2=
SECURITY_WPA_2=0
SECURITY_KEY_REN_2=30
SECURITY_SHARE_SECRET_2=
SECURITY_RADIUS_IP_2=
SECURITY_RADIUS_PORT_2=1812
SECURITY_DEF_TRAN_KEY_2=1
SECURITY_WEP_2=0
SECURITY_PASSPHRASE_2=
SECURITY_KEY1_2=
SECURITY_KEY2_2=
SECURITY_KEY3_2=
SECURITY_KEY4_2=
SECURITY_MODE_3=0
SECURITY_ALLOW_3=
SECURITY_AUTH_TYPE_3=
SECURITY_WPA_3=0
SECURITY_KEY_REN_3=30
SECURITY_SHARE_SECRET_3=
SECURITY_RADIUS_IP_3=
SECURITY_RADIUS_PORT_3=1812
SECURITY_DEF_TRAN_KEY_3=1
SECURITY_WEP_3=0
SECURITY_PASSPHRASE_3=
SECURITY_KEY1_3=
SECURITY_KEY2_3=
SECURITY_KEY3_3=
SECURITY_KEY4_3=
BASIC_RATE=15
TRAN_RATE=33
CTS_MODE=
FRAME_BURST=1
BEACON_INTERVAL=100
DTIM_INTERVAL=1
FRAG_THRES=2346
RTS_THRES=2347
WDS_EN=NO
WDS_ENCRY_EN=NO
WDS_MAC_1=
WDS_MAC_2=
WDS_MAC_3=
WDS_MAC_4=
WMM_EN=NO
[MIIICASA]
ENABLED=YES
[VLAN]
ENABLE=NO
ID="VID=1&DESC=Default&P1=0&P2=0&P3=0&P4=0&P5=0&P6=0&P7=0&P8=0&P9=0&P10=0&P11=0&P12=0&P13=0&P14=0&P15=0&P16=0&bonjour=1&VLAN_ROUTE=0&DEVICE_M=1"
ID="VID=25&DESC=Guest&P1=1&P2=1&P3=1&P4=1&P5=1&P6=1&P7=1&P8=1&P9=1&P10=1&P11=1&P12=1&P13=1&P14=1&P15=1&P16=1&bonjour=1&VLAN_ROUTE=0&DEVICE_M=0"
ID="VID=100&DESC=Voice&P1=1&P2=1&P3=1&P4=1&P5=1&P6=1&P7=1&P8=1&P9=1&P10=1&P11=1&P12=1&P13=1&P14=1&P15=1&P16=1&bonjour=1&VLAN_ROUTE=0&DEVICE_M=0"
NUMBER=3
PERPAGENUM_B=5
PERPAGENUM_M=5
[VLAN_MEMBERSHIP]
ENABLE=NO
NUMBER=0
LINEPERPAGE=5
[MULTIPLE_VLAN_SUBNET]
NUMBER=0
[LANGUAGE]
ID="NAME=ENGLISH"
ID="NAME=Deutsch"
ID="NAME=Espanol"
ID="NAME=Francais"
ID="NAME=Italiano"
NUMBER=5
MD5=930f351a95ff5de063bc4a41b2b5e1a3
[HW_QOS]
ENABLE=YES
COS_PRI_2_TC=0x0000
DSCP_PRI_2_TC_0=0x00000000
DSCP_PRI_2_TC_1=0xAAAA5555
DSCP_PRI_2_TC_2=0xFFFFAAAA
DSCP_PRI_2_TC_3=0xAAAAAAAA
[OPTION82]
NUMBER=0
PERPAGENUM=5
[USB_COM]
DRV_RELEASE_VERSION=v1.2.01
DRV_RELEASE_DATE=
DRV_UPDATE_VERSION=
DRV_UPDATE_DATE=Fri Sep 23 13:26:11 2016
[WR_CATEGORY]
Enable=0
REPUTATION=0
C_Type=2
C_H=000000001011000100010000000100001100100000011011110011111111001010010011110010000000
C_M=000000000011000100000000000100001000000000011010010000101111001000010011110000000000
C_L=000000000001000100000000000000000000000000000000000000001111000000010011110000000000
C_C=000000000000000000000000000000000000000000000000000000000000000000000000000000000000
HTTPS=0
LICENSE=0
[WR_SCHEDULE]
PERPAGENUM=5
NUMBER=0
[WR_WHITELIST]
PERPAGENUM=5
NUMBER=0
[WR_BLACKLIST]
PERPAGENUM=5
NUMBER=0
[WR_EXCLUSIONLIST]
PERPAGENUM=5
NUMBER=0
[OPENVPN_SERVER]
ENABLED=0
PROTO=tcp
PORT=1194
SERVER_IP=172.31.0.0
CIPHER=AES-128-CBC
AUTH=SHA1
TLS_AUTH=0
TUNNEL_MODE=0
SECURITY_IP=192.168.0.0
SECURITY_NETMASK=255.255.255.0
DOMAIN_NAME=
DNS_SERVER1=
DNS_SERVER2=
WIN_SERVER=
AUTH_TYPE=0
KEYLENGTH=1024
CA=2
SERVERCERT=0
MAX_CLIENT=5
MAX_CLIENT_LIMIT=50
[OPENVPN_ACCOUNT]
ID="INDEX=02&ENABLE=1&AUTHTYPE=0&REMOTE=81.82.215.225&USERNAME=Tom&PASSWORD=hidden&CLIENTCERT="
ID="INDEX=04&ENABLE=1&AUTHTYPE=0&REMOTE=81.82.215.225&USERNAME=Tomv&PASSWORD=hidden&CLIENTCERT="
NUMBER=2
FILEINDEX=5
LINEPERPAGE=5
MAXNUM=5
[DEBUG_SCRIPT]
VERSION=v1.0.01
[BONJOUR]
ENABLE=YES
ID1=NAME=router02af00&SERVICE_N=csco-sb&SERVICE_T=tcp&DOMAIN=local&PORT=443&TXT='model=RV320' 'deviceType=Router' 'deviceDescr=Gigabit Dual WAN VPN Router' 'fmVersion=v1.3.2.02' 'PIDVID=RV320-K9 V03' 'MACAddress=2C331102AF00' 'serialNo=NKS210100CA' 'hostname=router02af00' 'slaves=0' 'MDFID=284005929' 'SWTID=282465789:fw:282465789:driver' 'accesstype=http,https'&ENABLE=1&TYPE=1
ID2=NAME=router02af00&SERVICE_N=http&SERVICE_T=tcp&DOMAIN=local&PORT=80&TXT='path=/cgi-bin/welcome.cgi'&ENABLE=1&TYPE=1
ID3=NAME=router02af00&SERVICE_N=https&SERVICE_T=tcp&DOMAIN=local&PORT=443&TXT='path=/cgi-bin/welcome.cgi'&ENABLE=1&TYPE=1
ID4=NAME=router02af00&SERVICE_N=csco-api&SERVICE_T=tcp&DOMAIN=local&PORT=443&TXT='version=csco 1.0' 'accesstype=http,https' 'path=http://test.test'&ENABLE=1&TYPE=1
NUMBER=4
[ISP1_STATIC_ARP]
GATEWAY_OLD=81.82.192.1
GATEWAY_NEW=81.82.192.1
GATEWAY_MAC=00:17:10:88:bc:11
[ISP2_STATIC_ARP]
GATEWAY_OLD=0.0.0.0
GATEWAY_NEW=0.0.0.0
GATEWAY_MAC=
[CHECKSUM]
SUM=8114967
####end####
####firebase.conf####
wan-interface eth0
save-options true
dns-conf
exit
wins-conf
exit
ppp-client
start-addr 192.168.0.200
end-addr 192.168.0.210
subnet-mask 3ffe:ffff:0:f101::f00
tunnel-mode 0
ipv6-start-addr 3ffe:ffff:0:f101::f00
ipv6-end-addr 3ffe:ffff:0:f101::ff00
forceIpv6 0
exit
end
####end####
####smm.conf####
system
FullSet_Number 10
VP_Number 20
exit
hostname SSL VPN Server
time-out 10
save-options true
portal CommonPortal
services-page-flag true
desktop-page-flag true
tscapplications-page-flag true
cifs-page-flag true
virtualpassage-page-flag true
virtualpassage-tunnel-mode false
virtualpassage-block-tunnel false
virtualtransport-page-flag true
themes-page-flag true
online-help-flag false
change-password-flag true
home1-flag true
home2-flag true
home3-flag true
https-flag true
http-flag true
ftp-flag true
telnet-flag true
ssh-flag true
services-bookmark-flag true
tsc5-flag true
vnc-flag true
desktop-bookmark-flag true
theme-name stylewhitebluegrey
banner-flag false
portal-title SSL VPN
banner-title
banner-message
hp-title
hp-table-title SSL VPN Bookmarks
cache-control-flag false
webcache-cleaner-flag true
comments
exit
portal All Users
cifs-page-flag true
home1-flag true
home2-flag false
home3-flag false
https-flag true
http-flag true
ftp-flag true
telnet-flag true
ssh-flag true
tsc5-flag true
vnc-flag true
banner-flag false
banner-title
banner-message
hp-title
hp-table-title
comments
exit
portal Supervisor
cifs-page-flag true
virtualtransport-page-flag false
home1-flag true
home2-flag false
home3-flag false
https-flag true
http-flag true
ftp-flag true
telnet-flag false
ssh-flag false
tsc5-flag true
vnc-flag false
banner-flag false
banner-title
banner-message
hp-title
hp-table-title
comments
exit
portal Mobile User
cifs-page-flag false
virtualpassage-page-flag false
home1-flag true
home2-flag false
home3-flag false
https-flag true
http-flag true
ftp-flag true
telnet-flag false
ssh-flag false
tsc5-flag true
vnc-flag false
banner-flag false
banner-title
banner-message
hp-title
hp-table-title
comments
exit
portal Branch Staff
home1-flag true
home2-flag false
home3-flag false
https-flag true
http-flag true
ftp-flag true
telnet-flag false
ssh-flag false
tsc5-flag false
vnc-flag false
desktop-bookmark-flag false
banner-flag false
banner-title
banner-message
hp-title
hp-table-title
comments
exit
tsc-app Word
portal-name CommonPortal
icon-file /images/wordicon.gif
path c:\program files\microsoft office\office\winword.exe
tsc-host
dir c:\program files\
exit
tsc-app Excel
icon-file /images/excelicon.gif
path c:\program files\microsoft office\office\excel.exe
tsc-host
exit
tsc-app PowerPoint
icon-file /images/powerpointicon.gif
path c:\program files\microsoft office\office\powerpnt.exe
tsc-host
exit
tsc-app Access
icon-file /images/accessicon.gif
path c:\program files\microsoft office\office\access.exe
tsc-host
exit
tsc-app Outlook
icon-file /images/outlookicon.gif
path c:\program files\microsoft office\office\outlook.exe
tsc-host
exit
tsc-app Internet Explorer
icon-file /images/internetexplorericon.gif
path c:\program files\internet explorer\iexplore.exe
tsc-host
exit
tsc-app FrontPage
icon-file /images/frontpageicon.gif
path c:\program files\microsoft office\office\frontpage.exe
tsc-host
exit
tsc-app ERP
icon-file /images/s_icon_erp.gif
path c:\program files\microsoft office\office\erp.exe
tsc-host
exit
default-portal CommonPortal
domain home
auth-type local
cert-verify false
comments home
exit
group home
domain-name home
comments Welcome home
enable-flag false
default-flag false
group-type FullSet
exit
group Default
domain-name Default
comments Welcome Default
enable-flag false
default-flag false
group-type FullSet
exit
group All Users
domain-name Default
enable-flag true
default-flag false
group-type FullSet
exit
group Supervisor
domain-name Default
enable-flag false
default-flag false
group-type FullSet
exit
group Mobile User
domain-name Default
enable-flag false
default-flag false
group-type FullSet
exit
group Branch Staff
domain-name Default
enable-flag false
default-flag false
group-type FullSet
exit
user Tom
password $1$mldcsfp$z65BzW07e9wRYcs85KUzM0
user-group All Users
timeout 30
user-type normal
expiry-date
ui-theme default
block-login false
block-wan-login false
admit-using-clientcert false
admit-address false
admit-useragent false
exit
user cisco
password $1$mldcsfp$NNh1FR3A/uFnPI..btn0o1
user-group Default
timeout 10
user-type admin
expiry-date
ui-theme default
block-login false
admit-address false
exit
end
####end####
####cipher.conf####
hello RC4-MD5:ALL
####end####
