Amir, I am a Cisco Engineer from the Small Business department.
Based on the admin guide the maximum access points per cluster are 8 APs. If you are exceeding this and is working what can be happening is that when an endpoint is disconnected it is giving that space to the other cluster.
I do not recommend you to continue working with this topology because at some point you can be facing disconnection issues.
Why should I rate content?
You'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
