Name Display order in CUCM Corporate Directory
opeyemityusuf
HI,
I have CUCM 10.5 on my network. In IP Phone corporate directory when user search output, the output shows "Last name, First Name".
Can it be changed to "First name, Last Name"? Also can the search options be modified to contain other search parameters like Alias, contains and not just Begin with.
2 Accepted Solutions
Jitender Bhandari
Not possible with existing architecture, see below
https://supportforums.cisco.com/discussion/11815911/corporate-directory-name-display-order
(Rate if it helps)
JB
Jaime Valencia
The corporate directory is provided as is, if you want to add fields to search, show more info, etc. You need to build your own directory, or buy a 3rd party option.
java
if this helps, please rate
6 Replies 6
Jitender Bhandari
(Rate if it helps)
JB
Thanks, very detailed discussion link.
Jaime Valencia
java
Thanks i appreciate your quick response. I will stick to the running Directory so i don't complicate my architecture.
Happy to help
Just a side note, It also requires Developer contact for troubleshooting as TAC would only support CUCM Corporate Director, if you switch to 3rd party XML directory solution it is not supported by TAC.
(Rate if it helps)
JB
Jitender Bhandari
Enhancement that were open for the same.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq30437/?reffering_site=dumpcr
(Rate if it helps)
JB
