GVRP in SF 300 switch problem
swaalefcom
i did setup for gvrp in my two sf 300 switch:
I enabled GVRP on the TRUNK ports  for all switches
 I allowed all vlans on the TRUNK ports
 I  enabled the GVRP globally
i follow the instruction and applied in first and second switch,  but still i cant see the  vlans in second switch
please i need help
ktonev
My name is Kristian and I am one of the engineers from the Small Business team.
Please consult with this guide to ensure you have configured GVRP properly.
I can also suggest to check if you are running the latest firmware and boot code for these 2 switches and upgrade if necessary.
You can also provide the logs from the switches in case there is any relevant output so we can give more suggestions.
If this doesn't solve your issue I suggest giving us a call so we can assist further.
Hope that helps!
Kris
If you found this content useful please rate it so other users can benefit as well.
