Calling Number displaying wrong
May 19th, 2017
Hello Team, one of my client is facing the problem
Whenever a call is made from Cisco Phone to Mobile Phone it displays number which ends with 222, whereas external mask I have given as 164
Problem is only happening only for Ext 164, other extension displays proper number, can anyone tell me where to check what
I don't see any translation pattern and I have not checked anything on GW yet
Suresh Hudda Fri, 05/19/2017 - 01:42
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
What you have set on route pattern under option "Use Calling Party's External Phone Number Mask" is this option checked ?
And, what do you see as calling number at gateway when u enable logs for a call ?
Suresh
Anthony Vinod Fri, 05/19/2017 - 03:04
Hi Suresh, I checked route pattern , "Use Calling Party's External Phone Number Mask"  unchecked
I could not check in Router because I by mistakenly turned on "debug mgcp all" and router went down, after struggling for half n hour the router came up
although I checked Dialed number analysis of another extension which displays correct calling number and could not find a single difference in both the output
Its quiet weird
Jitender Bhandari Fri, 05/19/2017 - 03:10
  • Cisco Employee,
Hi Anthony,
You cannot do any digit manipulations on MGCP gateway, can you attach below for a test call.
1) Call manager detail traces
2) Debug ISDN q931
3) Calling \ called number
JB
Anthony Vinod Fri, 05/19/2017 - 04:37
Hi JB, thanks for reply
Actually now I am not allowed to further work on this because of the escalation.
I had taken the DNA output of one working extension and not working extension which I am attaching and sorry I had to end this because I could not work because of restrictions
Initially Line CSS and device CSS was different and I changed later, which is not reflecting on the logs because I took logs before changes
Jitender Bhandari Fri, 05/19/2017 - 04:57
  • Cisco Employee,
DNA shows no issue, you will have to provide above information moving further.
JB
Suresh Hudda Fri, 05/19/2017 - 05:09
    2017 IP Telephony
Hi Anthony,
As this option (Use Calling Party's External Phone Number Mask) at route pattern is unchecked so whatever you have set on phone line's page (as u attached snap shot earlier) will not make any sense, as route patter's settings will overwrite it.
Is number which ends with 222 is pilot number ? might be service provider not converting it because your customer has not purchased number which ends with 164. So, best way to check at router end (debug isdn q931), if it shows ..164 there then you can check with service provider.
Moreover, below is the process to enable multiple debugs at a time, it will help preventing the router crash. Keep an eye on 'show processor cpu history' when enabling debugs one-at-a-time to ensure there is minimal impact.
term no mon
Conf t
no service sequence-numbers
no logging console
no logging monitor
logging buffered 10000000 7
end
Clear logging
enable logs now..!
After the call, stop the debug and save in a new text file by using below command.
show log
Suresh
