ASA static nat
shiran.wang
ASA version 9.6(3)1
both nat have same configuration except 172.16.100.2 use interface, anyone have same question?
this object work fine
object network 172.16.100.3_25_xx2
 nat (DMZ,xyz) static 202.175.xx.203 service tcp smtp smtp
this object not work
 object network 172.16.100.2_25_xx1
 nat (DMZ,xyz) static interface service tcp smtp smtp
 Cisco Adaptive Security Appliance Software Version 9.6(3)1
Device Manager Version 7.2(2)1
Compiled on Thu 30-Mar-17 21:40 PDT by builders
System image file is "disk0:/asa963-1-smp-k8.bin"
Config file at boot was "startup-config"
packet-tracer input xyz tcp 8.8.8.8  1024 202.175.xx.202 25
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 202.175.xx.202 using egress ifc  identity
Phase: 2
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: xyz
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
# packet-tracer input xyz tcp 8.8.8.8  1024 202.175.xx.203 25
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
object network 172.16.100.3_25_xyz
NAT divert to egress interface DMZ
Untranslate 202.175.xx.203/25 to 172.16.100.3/25
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group xyz in interface xyz
access-list xyz extended permit tcp any host 172.16.100.3 eq smtp
Phase: 3
Type: NAT
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: inspect-smtp
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect esmtp _default_esmtp_map
service-policy global_policy global
Phase: 6
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
nat (DMZ,xyz) source dynamic any interface
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 538894, packet dispatched to next module
Result:
input-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: allow
Jon Marshall
Can you post a "sh nat"
Jon
 service tcp destination eq smtp
nat (ServerFarm,xyz2) source static object_10.10.120.0 object_10.10.120.0 destination static object_10.10.10.10.0 object_10.10.10.10.0
nat (ServerFarm,xyz1) source static object_10.10.120.0 object_10.10.120.0 destination static object_10.10.10.10.0 object_10.10.10.10.0
nat (Inside,xyz2) source dynamic any interface
nat (DMZ,xyz1) source dynamic any interface
nat (DMZ,xyz2) source dynamic any interface
nat (Inside,Informac) source dynamic any interface
nat (ServerFarm,Informac) source dynamic any interface
nat (WIFI_AP,xyz2) source dynamic any interface
nat (WIFI_AP,xyz1) source dynamic any interface
nat (ServerFarm,xyz1) source dynamic any interface
nat (ServerFarm,xyz2) source dynamic any interface
nat (WIFI_Staff,xyz2) source dynamic any interface
nat (WIFI_Staff,xyz1) source dynamic any interface
nat (WIFI_Guest,xyz2) source dynamic any interface
nat (WIFI_Guest,xyz1) source dynamic any interface
nat (WIFI_Media,xyz2) source dynamic any interface
nat (WIFI_Media,xyz1) source dynamic any interface
nat (CCenter,xyz2) source dynamic any interface
nat (CCenter,xyz1) source dynamic any interface
nat (Inside,xyz1) source dynamic any interface
 nat (DMZ,xyz1) static 202.175.xx.203 service tcp smtp smtp
 nat (ServerFarm,xyz1) static 202.175.xx.203 service tcp https https
 nat (ServerFarm,xyz1) static 202.175.xx.203 service tcp www www
 nat (ServerFarm,xyz1) static 202.175.xx.204
 nat (ServerFarm,xyz1) static 202.175.xx.205 service tcp https https
 nat (ServerFarm,xyz1) static 202.175.xx.205 service tcp www www
 nat (DMZ,xyz2) static 182.93.x1.27 service tcp smtp smtp
 nat (DMZ,xyz2) static 182.93.x1.28 service tcp smtp smtp
 nat (ServerFarm,xyz2) static 182.93.x1.27 service tcp https https
 nat (ServerFarm,xyz2) static 182.93.x1.27 service tcp www www
 nat (ServerFarm,xyz2) static 182.93.x1.29
 nat (DMZ,xyz1) static 202.175.xx.202 service tcp smtp smtp
I'm not sure that is the output of "sh nat" ie. it should show the hits etc.
I think the problem is with the order of your NAT rules but I need to see the proper output first.
Jon
