05-21-2017 07:29 PM - edited 03-12-2019 02:23 AM
I cannot ssh to the inside of the asa via vpn when the inside ip is a BVI. I enabled management access inside and i received tcp intercept drops my connection. If I enable management access via a specific interface like inside_1->inside_7 i get cannot locate egress interface. How do you enable management access inside when using a BVI inside interface using 9.8.1 code?
05-24-2017 12:50 AM
It would seem that others are experiencing the same behavior.
https://supportforums.cisco.com/discussion/13266856/version-971-bvi-not-available-permit-mgmnt-access
05-26-2017 05:33 AM
Thanks Dennisperto,
I hope cisco can come back and state is it behavior or is it not possible? I see nothing in the documentation that says it isn't and if it isn't why can we execute the command? The error I get while watching asdm log is tcp intercept. I don't even have that enabled. In order to get access to the asdm I used the outside interface and created a pat for the firepower module so I could reach that as well.
08-27-2017 03:02 AM - edited 08-27-2017 04:35 AM
del
