05-22-2017 05:37 AM - edited 03-08-2019 10:40 AM
Hello Everyone,
I am having some servers need to be on live IP's.
My ISP gave me one subnet of /28 for my servers. My connectivity is P2P and is on a different subnet. As of now, my public interface is also doing NAT for my office users to access the internet.
What configuration do I need to make my servers on live IP's so that respected personal could access them?
Thanks in advance!
Solved! Go to Solution.
05-22-2017 05:54 AM
Create a DMZ. Put the /28 on that DMZ. Move the server(s) into that DMZ so they can have the public IP addresses on them directly.
05-22-2017 05:52 AM
If you can create a static NAT (1 to 1) with /28 you have 14 valid IP addresses (if it is a additional segment) so you can create 14 static NATs . How many servers are you going to implement?
I usually dont recommend this solution unless you have a great security environment or it is isolated from your internal network, I prefer to provide SSL VPN + Cisco Anyconnect to the users.
Hope it is useful
05-22-2017 05:54 AM
05-25-2017 01:40 AM
Dear Philip,
Thank you for the suggestion. Could you pl suggest me the configuration on my Router, so that people could access the servers.
for my server the public IP pool is (xx.xx.xx.xx 255.255.255.248)
as of now the configuration is like
interface
description Internet interface
interface fa 0/1.100
Description Office vlan
ip add 192.168.20.1 255.255.255.0
interface
Description Guest
