WS-C3850-24XS-E comes with 24 fiber port or do I need to order network module seperately
is041h001
I have requirement of 24 port fiber tengig switch and I opted WS-C3850-24XS-E switch now I am confused do I need to order 3 C3850-NM-8-10G=  network modules or the device comes with 24 fiber port and only I need to order 24 GLC-LH-SMD SFPs.
Inshort  do I need to order network module or not?
Irfan
8 Replies 8
Mark Malone
No you don't there 10GB switches , as per doc there SFP+ which is 10gb ports , 24 x 10gb
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
Models
Total 10/100/1000 or SFP or SFP+ Ports
Default AC Power Supply
Available PoE Power
StackWise-480
StackPower
WS-C3850-24T
24
350WAC
Yes
Yes
WS-C3850-48T
48
WS-C3850-24P
24 PoE+
715WAC
435W
WS-C3850-48P
48 PoE+
WS-C3850-48F
48 PoE+
1100WAC
800W
WS-C3850-24U
24 UPOE
1100WAC
800W
WS-C3850-48U
48 UPOE
1100WAC
800W
WS-C3850-24XU
24 UPOE (100Mbps/1/2.5/5/10 Gbps)
1100WAC
580W
WS-C3850-12X48U
48 UPOE (with 12 100Mbps/1/2.5/5/10 Gbps Ports)
1100WAC
630W
WS-C3850-12S
12 SFP
350WAC
WS-C3850-24S
24 SFP
WS-C3850-12XS
12 1/10G SFP+
350WAC
WS-C3850-24XS
24 1/10G SFP+
715 WAC
WS-C3850-48XS
48 1/10G SFP+
750WAC (front to back)
No
WS-C3850-24XS-E
Stackable 24 SFP+ Ethernet ports, with 715WAC power supply
1 RU, IP Services feature set
Guys,
My question is very simple is the switch WS-C3850-24XS-E comes with 24 port sfp+ slot or do I need to order three C3850-NM-8-10G= so that I can get 24 tengig port.
so to get 24 tengig port do I need to order which one from the below two options
qty    part
1       WS-C3850-24XS-E
24     GLC-LH-SMD
             OR
qty    part
1       WS-C3850-24XS-E
3       C3850-NM-8-10G=
24     GLC-LH-SMD
irfan
in the post above ive shown you don't need the module 24 x 10gb ports
these are standard 10gb per port switches the X series
WS-C3850-24XS
24 1/10G SFP+
Thannks Mark,
so I need to order only below parts, I mentioned tengig single mode sfp as the device support both 1g and 10g .
qty    part
1       WS-C3850-24XS-E
24     GLC-LH-SMD
please let me know if its ok...
There 1 GB SFPs yes going into 10GB ports with the SMD  , that SFP is supported so your ok if that's what your using, there 10KM SFPS are your other devices that far away ?  , either way here's exactly what's supported on that platform in sfp
supports at 10gb
WS-C3850-12XS
WS-C3850-16XS
WS-C3850-24XS
WS-C3850-32XS
(C3850-NM-8-10G uplink modules)
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-10G-ER
SFP-10G-ZR
SFP-10G-SR-S
SFP-10G-LR-S
SFP-10G-ER-S
SFP-10G-ZR-S
DWDM SFP+
CWDM SFP+
SFP-H10GB-CU1M
SFP-H10GB-CU1-5M
SFP-H10GB-CU2M
SFP-H10GB-CU2-5M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
SFP-10G-AOC1M
SFP-10G-AOC2M
SFP-10G-AOC3M
SFP-10G-AOC5M
SFP-10G-AOC7M
SFP-10G-AOC10M
SFP-10G-BXD-I
SFP-10G-BXU-I
SFP-10G-BX40D-I
SFP-10G-BX40U-I
XE 3.7.1E
XE 3.7.1E
This is what it supports at 1GB SFP
WS-C3850-12XS
WS-C3850-16XS
WS-C3850-24XS
WS-C3850-32XS
(with C3850-NM-8-10G NM)
GLC-T (10/100/1000)
GLC-LH-SM
GLC-LH-SMD
GLC-SX-MM
GLC-SX-MMD
GLC-EX-SMD1
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
SFP-GE-S
SFP-GE-L
SFP-GE-T
SFP-GE-Z
DWDM SFP
DWDM SFP (add.)
GLC-BX40-D-I
GLC-BX40-DA-I
GLC-BX40-U-I
GLC-BX80-D-I
GLC-BX80-U-I
XE 3.7.1
XE 3.7.1
GLC-TE
XE 16.6.1
Thannks Mark,
qty    part
1       WS-C3850-24XS-E
24     GLC-LH-SMD
If you are looking for 24 SFP ports, you can buy:
WS-C3850-24S-E
WS-C3850-12S-E
WS-C3850-24S-S
WS-C3850-12S-S
All of these models has SFP ports only and you can include a module of 4 SFP more.
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Below you will find a link with the SFP and modules supported by model
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
