05-23-2017 06:56 AM - edited 03-18-2019 01:08 PM
According to the cluster creation documentation you should use the same weight and priorities for all peers in a cluster except "Only use different priorities if you have different clusters allowing failover from one primary cluster to another (secondary) cluster. In that case the primary cluster’s peers should have one value and the other (secondary) cluster’s peers a (larger) value".
So my question is, are they referring to two separate VCS clusters with a cluster FQDN that resolves to 2 separate cluster names or can you have once cluster with peers in two geographically different locations and weight the entries to prefer one location of peer over the other ?
Solved! Go to Solution.
05-24-2017 05:12 PM
In a single cluster scenario with same weight and priority you achieve load balancing, however if you do not want that then you can add the different weight and priority for FQDN's.
Rgds,
Alok
05-24-2017 05:12 PM
Rgds,
Alok
05-26-2017 07:17 AM
I thought that would work for what I am trying to achieve, just wanted to do a "sanity" check to see if anyone else concurred with my thought process. However, I'm wondering if I'll see any problems with older devices that don't support the use of SRV records and only check the A records.
