05-23-2017 10:52 AM - edited 02-21-2020 09:17 PM
There is something wrong with my configuration and I can't seem to figure out. Below is the output of the cisco8201 router if I try to send a ping from a host behind the asa firewall. Thanks.
router#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
72.179.x.x 72.179.x.x QM_IDLE 1280 ACTIVE
IPv6 Crypto ISAKMP SA
router#show crypto ipsec sa
interface: FastEthernet0/0
Crypto map tag: vpnSite, local addr 72.179.x.x
protected vrf: (none)
local ident (addr/mask/prot/port): (192.168.4.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
current_peer 72.179.x.x port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 72.179.191.71, remote crypto endpt.: 72.179.175.78
path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/0
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
Solved! Go to Solution.
05-24-2017 08:22 AM
You have a mismatched ACL for the VPN "interesting traffic" on the ASA (it needs to be a mirror of the peer's ACL).
So, the following line:
access-list vpnAcl extended permit ip 192.168.1.0 255.255.255.0 any
it should be replaced with the following line:
access-list vpnAcl extended permit ip 192.168.1.0 255.255.255.0 192.168.4.0 255.255.255.0
Hope that has helped.
Kind regards
Rob
05-24-2017 08:22 AM
Kind regards
Rob
05-25-2017 02:33 PM
it worked!!!! wow. Thanks. Just a simple acl breaks the whole network..lol
