DMVPN with certificates
abenavides11
Hello
I have a DMVPN topology using certificates for authentication. The validation of the certificate works very well, but only occurs when the tunnel is starting and I need that, although the tunnel is working, each time the revocation of the certificate is reviewed.
Philip D'Ath
Could you try explaining what the problem is a different way.  Specifically what is the solution not doing that you need - or what is it doing that you don't want it to do?
