interface output errors
nareh84
Level 3
Level 3
hi
on one end i have WS-C3850-48P and on the other end i have WS-C2960X-48FPD-L. Daily for sometime i receive alert for output error on particular interfaces which are part of portchannel of WS-C3850-48P. Daily i face this issue during business hours particularly on those ports. while on the other end (WS-C2960X-48FPD-L) there are no errors. what steps should i follow to troubleshoot this issue.
GigabitEthernet1/0/47 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 00a2.89d4.77af (bia 00a2.89d4.77af)
Description:  G1/0/47
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output never, output hang never
Last clearing of "show interface" counters 24w4d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 2114058
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5000 bits/sec, 7 packets/sec
5 minute output rate 24000 bits/sec, 25 packets/sec
1026930025 packets input, 112466646250 bytes, 0 no buffer
Received 24954970 broadcasts (12794372 multicasts)
0 watchdog, 12794372 multicast, 0 pause input
618833910 packets output, 93620061474 bytes, 0 underruns
2114058 output errors, 0 collisions, 0 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
On both end show int status show a-1000 and full duplex
#sh int status
Gi1/0/47  Switch  connected    trunk      a-full a-1000 10/100/1000BaseTX
#sh int gigabitEthernet 1/0/47 counters errors
Port      Align-Err FCS-Err   Xmit-Err     Rcv-Err  UnderSize OutDiscards
Gi1/0/47 0                 0        2114058         0          0               2114058
Port             Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts
Gi1/0/47           0                  0             0              0             0          0
20 Replies 20
Have you replaced the cabling? or try using other port?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
yes, we replaced the cabling but not ports.
Aparently the problem is with the switch with port 47, output errors but not input errors. Try to clear the counters and verify again if there is unidirectional problem.
clear counters g1/0/47
currently, output errors are not increasing. but i receive alert daily for 1~2 hours, only for output error.
I see, try to discard the port, changing that during a maintenance window.
You also can diagnose the performance of an interface, using diagnose interface, i recommend use it during a maintenance window as well.
http://www.cisco.com/c/en/us/td/docs/server_nw_virtual/2-7-0_release/command_reference/commref/diag.html
Could following be the issue?
I can see on WS-C3850-48P when i do sh int trunk. more vlans are  allowed
#sh int trunk | incl 13
Po13        on               802.1q         trunking      1
Po13        1-4094
Po13        1,100-101,103,200,212,221,259,310,322,340-342,347-348,361,410,920-925
But when i do sh int trunk on the other switch. few vlans are configured/allowed.
sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Port        Vlans allowed on trunk
Po13        1-4094
Port        Vlans allowed and active in management domain
Po13        1,200,212,322,340-342,347,361
Port        Vlans in spanning tree forwarding state and not pruned
Could you please share the port (physical and logical ports) configuration of both switches? is there any vlan filtering under the etherchannel?
on 3850 switch:
#sh run int gig 1/0/47
Building configuration...
Current configuration : 133 bytes
interface GigabitEthernet1/0/47
 description  @ G1/0/47
 switchport mode trunk
 channel-group 13 mode active
end
#sh run int gig 2/0/47
interface GigabitEthernet2/0/47
 description @ G1/0/48
end
#sh run int po 13
Current configuration : 86 bytes
interface Port-channel13
 description sw03
end
On 2960 Switch:
 power inline never
end
ntl-per-sw03#sh run int gig 1/0/48
Current configuration : 153 bytes
interface GigabitEthernet1/0/48
 description @ G2/0/47
 power inline never
end
ntl-per-sw03#sh run int po 13
 description sw02
end
Thank you, Your configuration look fine, keep monitoring the port or try testing with other port.
Leo Laohoo
I know what this is:  Incorrect QoS configuration.
Look at the value of the "output errors" and "Total Output Drops", the numerical values are exactly the same
Enter the command "sh  interface G 1/0/47 controller" and you'll find the same value to be reflected in "Excess Defer Frames" (left-hand column).
yes both the values are same in
#sh int gig 1/0/47
2206900 output errors
#sh int gig 1/0/47 controller
2206900 Excess Defer frames
currently qos is not configured for this interface. could you guide me regarding the qos configuration on this interface or should i start with change the ports first?
Sorry, I'm no QoS person.  Joseph Doherty is CSC's "in house" QoS person.  I've sent him a PM  to look at this thread.
Hi guys! i've the same behaivour....
can you give us any help?
Several variations to this problem in this thread.  Suggest you create a new posting describing your problem.
