05-25-2017 04:43 AM - edited 03-17-2019 10:25 AM
Hi folks,
Have deployed CUCM 11.5 in cluster. Am experiencing a problem of dropped call between CIPC 8.6.6 and 7841 IP Phone.
This is 1st time am facing problem. Can someone please suggest me a solution.
Thanks & regards,
Ritesh Desai
05-25-2017 04:48 AM
Refer URL: https://supportforums.cisco.com/discussion/12753526/cisco-7821-preservation-mode-error-message-and-call-drop
It also says about the bug. This is fixed in CUCM 11.5.
Known Fixed Releases: (5)
11.5(1.10000.6)11.5(0.98000.163)11.5(0.98000.126)11.5(0.98000.113)11.5(0.98000.108)
Also, am facing this issue on LAN network. Both phones are on same access switch but on different VLAN.
thanks & regards,
Ritesh Desai.
05-26-2017 07:46 AM
Hi All,
the cause of the issue in my scenario was due to a CIPC was registered under 2 active directory profiles of different users from same system. This was causing the randomly call disconnection between CIPC's and Hardphones.
Thanks & Regards,
Ritesh Desai.
