05-25-2017 06:22 AM - edited 03-17-2019 10:25 AM
I am looking for an approach where two numbers can be shown on the physical display when browsing a user directory. Phones are 7821 and CUCM is version 9.1. which has LDAP integration with AD 2008. I know that corporate directory is a given and cannot be changed. So, the options are two: either a third party application or develop a custom directory. I want to stop on the second approach. The thing is that I do not want to work directly on the LDAP server. What I want to do is have a test Win2008R2 64 bit and run a Web Server there (IIS) which will proxy the requests to the LDAP server. Long story short I want to avoid the involvement of the CUCM in the whole process and thanks to XML it should be possible to display additional fields on the phones. This is just a draft. I want to know about your thoughts on that. Any advises are much appreciated. Thanks!
05-31-2017 02:48 PM
Hi! Yeah we have actually tried a custom directory with one customer and uploaded a custom directory xml file to their local Cisco router's flash then manually adding the path to the services tab inside the device configuration page of the phone.
06-01-2017 03:42 AM
Hey John, Thank you for your reply. Should I understand that this was a hardcoded directory and if so how do you synchronize it with AD? Also is there a chance I can have a look on the XML, (of course cleared from any customer related information). Thank you very much in advance!
