05-25-2017 05:19 PM - edited 03-08-2019 10:44 AM
I am using this but it lets one computer use all the speed:
policy-map main-in
class http
police cir 1000000
conform-action transmit
exceed-action drop
violate-action drop
policy-map out
class http
shape average 1000000
police cir 1000000 conform-action transmit exceed-action drop violate-action drop
05-25-2017 08:21 PM
Have you tried to match an ACL into the class-map?
For example (outbound):
access-list 100 permit 192.168.1.0 0.0.0.255 any eq 80
access-list 100 permit 192.168.2.0 0.0.0.255 any eq 80
class-map HTTP
match access-group 100
or just
match protocol http
05-26-2017 12:09 AM
what platform is this configured on ? Some platforms do not support egress policing.
Either way, in addition to Julio's post, here is what you could try:
access-list 101 permit tcp 192.168.1.1 any eq www
class-map match-all http
match protocol http
match access-group 101
policy-map main-in
class http
police cir 1000000 187500 conform-action transmit exceed-action drop
class class-default
05-26-2017 06:16 AM
Why are you shaping and policing in your "out" policy, especially at the same rate?
Yes, what you have would allow one or any combination of hosts to use the 1 Mbps you've limited HTTP to. Could you further explain what you're trying to accomplish?
05-26-2017 04:54 PM
Sorry for confusing everyone. I wrote the post in a hurry and didn't explain what I'm trying to do.
I already have the http class-map set up and it's capturing http traffic. The police is also working fine.
As I said, with the current method it lets a single PC use all the bandwidth. Is there any way to limit it so once PC can't use all the bandwidth but is able to use a certain amount?
05-26-2017 05:26 PM
Have you tried use 'host' on the ACL and then apply the ACL into a class-map using the same scheme?
access-list 100 permit tcp host 192.168.1.10 any eq 80
class-map PC-HTTP
policy-map POLICY
class PC-HTTP
Then apply the policy-map under the interface for outbound way.
if you execute: sh policy-map interface <interface>, you will see the default-class where the rest of the traffic is passing with no restrictions.
05-26-2017 05:26 PM
Outbound is not a problem since I can shape it. The problem is the inbound traffic. I can't shape it so if one PC uses all the traffic other PCs have their packets dropped because of the police. And it's not a particular PC. It can be any PC.
05-26-2017 05:44 PM
Have you tried similar but modifying the ACL?
access-list 101 permit tcp any eq 80 host 192.168.1.10
class-map PC-HTTP
policy-map POLICY-IN
class PC-HTTP
An then apply it for inbound direction? it should just be applied for the host 192.168.1.10, the rest of the traffic should be impacted.
