int errdisabled by: evc-lite input mapping failure error detected on int.
omramirez
Hi community,
Could you help me with some guidance to resolve the following errdisabled state:
%PM-4-ERR_DISABLE: evc-lite input mapping failure error detected on Te1/1/2, putting Te1/1/2 in err-disable state
I don´t have EVCs configured in the switch.
I type a shut / no shut on the port and immediately after the no shut the same err-disable appears, with or without having anything connected on that port the behavior is the same.
I tried to enable the errdisabled recovery for that err_disable state but it won´t changed to enabled:
show errdisable recovery
ErrDisable Reason Timer Status
arp-inspection Enabled
bpduguard Enabled
channel-misconfig (STP) Enabled
dhcp-rate-limit Enabled
dtp-flap Enabled
gbic-invalid Enabled
inline-power Enabled
l2ptguard Enabled
link-flap Enabled
mac-limit Enabled
loopback Enabled
pagp-flap Enabled
port-mode-failure Enabled
pppoe-ia-rate-limit Enabled
psecure-violation Enabled
security-violation Enabled
sfp-config-mismatch Enabled
storm-control Enabled
udld Enabled
vmps Enabled
psp Enabled
dual-active-recovery Disabled
evc-lite input mapping fa Disabled
Recovery command: "clear Disabled
Timer interval: 30 seconds
Interfaces that will be enabled at the next timeout:
Also, that particular errdisabled state does not appear on the errdisable recovery cause command:
errdisable recovery cause ?
all Enable timer to recover from all error causes
arp-inspection Enable timer to recover from arp inspection error disable state
bpduguard Enable timer to recover from BPDU Guard error
channel-misconfig Enable timer to recover from channel misconfig error (STP)
dhcp-rate-limit Enable timer to recover from dhcp-rate-limit error
dtp-flap Enable timer to recover from dtp-flap error
gbic-invalid Enable timer to recover from invalid GBIC error
inline-power Enable timer to recover from inline-power error
l2ptguard Enable timer to recover from l2protocol-tunnel error
link-flap Enable timer to recover from link-flap error
loopback Enable timer to recover from loopback error
mac-limit Enable timer to recover from mac limit disable state
pagp-flap Enable timer to recover from pagp-flap error
port-mode-failure Enable timer to recover from port mode change failure
pppoe-ia-rate-limit Enable timer to recover from PPPoE IA rate-limit error
psecure-violation Enable timer to recover from psecure violation error
psp Enable timer to recover from psp
security-violation Enable timer to recover from 802.1x violation error
sfp-config-mismatch Enable timer to recover from SFP config mismatch error
storm-control Enable timer to recover from storm-control error
udld Enable timer to recover from udld error
vmps Enable timer to recover from vmps shutdown error
Current port config:
interface TenGigabitEthernet1/1/2
switchport trunk allowed vlan XXXX,XXXXSH INT ,XXXX
switchport mode trunk
end
#do sh int te1/1/2 status
Port Name Status Vlan Duplex Speed Type
Te1/1/2 err-disabled 1 auto auto unknown
I´m  using a:
C3850-NM-4-10G switch
IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.01E RELEASE SOFTWARE (fc3)
Thanks in advance for your help
0 Replies 0
