05-28-2017 06:44 PM - edited 03-08-2019 10:45 AM
Hello All,
Trying to work out this simple network topology with DHCP on two VLANs
Not sure what I missed?
Password to router: Cisco
Secret : Class
Solved! Go to Solution.
05-28-2017 07:11 PM
No worries :-)
The wrong interface, also the interface fa0/1 from the switch connected to the router should be configured as Trunk instead access mode.
Also you need to create a trunk interface between both switches.
Attached you will find my config to be compared with yours, each computer obtained IP automatically.
Switch (connected to Router)
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
Switch 2
05-28-2017 07:04 PM
The reason is because the network 40.0.0.0/8 is configured under the wrong interface. It should be under the FastEthernet 0/1. Also the interface connected to the Router on the switch should be as Trunk because you are creating a dot1q connection (Router in a stick scheme). I have created the trunk between the switches as well, attached you will find the fixed Packet Tracer file. The 4 PCs are already obtaining IP address automatically.
Fixed config:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
ip address 40.0.0.1 255.0.0.0
duplex auto
speed auto
The trunk interfaces allow the communication between multiples Vlans.
05-28-2017 07:05 PM
Ah, stupid mistake.
Change over the interface, still having the same issue though.
Can you see anything else?
05-28-2017 07:11 PM
No worries :-)
Switch 2
05-28-2017 07:12 PM
Thank you very much Julio!
Just needed to trunk between the two switches also.
05-28-2017 07:14 PM
It was a pleasure my friend.
Have a great day
