05-28-2017 10:13 PM
Hi All,
Currently we have a setup without VPC that two F5 LTM NLBs are connected to sw 1 and sw 2 with two different physical ports (NOT as a port channels, two links has two diff functions). We would like to utilise VPC feature and we would like to implement below mentioned scenario(refer the attachment). WIll it be supported in VPC ? . I believe STP will eliminate one pair of ports but my doubt is without STP also we have two links where STP didnt block the ports. Please advise.
06-08-2017 08:07 AM
Any update pls
06-20-2017 08:14 AM
Hi Arjunselvi,
Yes your proposed design is fine, your 5Ks are logically one device so it is not an issue.
On the F5 side under network you will create your Trunk with multiple interface in it.
Amjad Hashim.
