05-29-2017 11:22 PM - edited 03-17-2019 10:27 AM
We are receiving Alert on RTMT ..as this is the Trust certificate can we directly delete this certificate & not need to regenerate can any one suggest on this
" At Tue May 30 05:30:38 IST 2017 on node 10.9.64.180, the following SyslogSeverityMatchFound events generated:
SeverityMatch : Critical
MatchedEvent : May 30 05:30:06 CUCM1local7 2 : 4: CUCM1: May 30 2017 00:00:06.799 UTC : %UC_CERT-2-CertValidfor7days: %[Message=Certificate expiration Notification. Certificate name:inHydGblksub0201-1.der Unit:CallManager-trust Type:own-cert Expiration:Fri ][AppID=Cisco Certificate Monitor][ClusterID=][NodeID=CUCM1]: Alarm to indicate that Certificate has Expired or Expires in less than seven days
AppID : Cisco Syslog Agent
ClusterID :
NodeID : CUCM1
TimeStamp : Tue May 30 05:30:06 IST 2017
This message (including any attachments) contains "
05-29-2017 11:34 PM
check the link below for help
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200199-CUCM-Certificate-Regeneration-Renewal-Pr.html
(Rate if it helps)
JB
05-29-2017 11:35 PM
This is very useful doc
05-29-2017 11:43 PM
Certificates should be regenerated before they expire. When the certificates are about to expire you will receive warnings in RTMT (Syslog Viewer) and an email with notification will be sent if configured.
Follow the below procedure.
1- Regenerate the certificate on all the nodes
2- Download these certs on the system
3- Upload the same downloaded certs as Trust
Also find the below link helpful
Abhay
Kindly rate all helpful posts !!!
