05-30-2017 01:58 AM - edited 03-08-2019 10:46 AM
I'm looking for a solution to implement a CBWFQ QoS on, and I need to implement it on an egress 4Gbps bundled Giga-Ethernet in one port-channel
But I can't find a suitable platform or router that support such feature, any advise to choose a one ??
I had my research, and I had found a good platform for us, and it's Cisco ISR 3945 with an enhanced either-switch module (SM-D-ES3G-48-P), but I'm not sure that the SM-D Etherswitch would support such a feature,
does anyone have the answer if it can support such a scenario?
the policy will be as the following:
class-map match-any MATCH_DSCP_512XK
match
class-map match-any MATCH_DSCP_1XM
match
class-map match-any MATCH_DSCP_2XM
match
class-map match-any MATCH_DSCP_4XM
match
class-map match-any MATCH_DSCP_8XM
match
class-map match-any MATCH_DSCP_1SM
match
class-map match-any MATCH_DSCP_2SM
match
class-map match-any MATCH_DSCP_4SM
match
class-map match-any MATCH_DSCP_8SM
match
policy-map CBWFQ_ADSL
class MATCH_DSCP_512XK
bandwidth percent 10
class MATCH_DSCP_1XM
class MATCH_DSCP_2XM
bandwidth percent 12
class MATCH_DSCP_4XM
bandwidth percent 15
class MATCH_DSCP_8XM
class MATCH_DSCP_1SM
bandwidth percent 4
class MATCH_DSCP_2SM
bandwidth percent 6
class MATCH_DSCP_4SM
bandwidth percent 8
class MATCH_DSCP_8SM
bandwidth percent 7
05-30-2017 04:02 AM
They support qos but I don't see support for ether channels in the data sheet for that module
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data_sheet_c78-553980.html
05-30-2017 08:17 AM
Thank you for your answer :),
Yes, there's no ether-channel QoS support mentioned in the datasheet,
however the same for Cisco 3900 datasheet,
and I had tried to implement CBWFQ on a Port-channel in the built-in interfaces in Cisco 3945 router and it worked fine.
so, in the end, I need to make sure that if SM-D enhanced either switch support such a feature so we would buy one.
