I recently acquired 3 licenses (full TAMC) for a 5500-x device. ProtectControl/URLFilter/Malware
I generated the licenses for the License key displayed in ASDM ---> License key 77:xx:xx:xx:xx:xx.
I installed the Firepower module. I installed the licenses through ASDM. It works this way.
After, I deployed FMC on a KVM host. Once I registered the FMC to my firepower module, I lost the Firepower tabs in ASDM (which could be normal).
After, I went in the FMC licensing menu, I got an Unlicensed status and I noticed the License key on the VM is : 66:xx:xx:xx:xx:xx:xx.
I couldn't install the licenses on the VM since they were generated only for the firepower module in the first place and not the Firesight Management Center.
Is there a way to migrate the licenses?
Is there a way to use both Firepower through ASDM and FMC? If not - I would rather use FMC. What do I do next?
Thank you,
