06-01-2017 09:25 PM - edited 02-21-2020 09:18 PM
06-02-2017 05:32 PM
Hi oj.jordan,
Which version of iOS are you running on the Iphone?
Is this only happening to this phone?
Do you have a .xml profile on the ASA?
This link explains how the profile works for iphones:
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/user/guide/iphone-ugac-ios.html#pgfId-179705
Hope this info helps!!
Rate if helps you!!
-JP-
06-06-2017 12:31 PM
JP,
In response to your query, the responses are as follows:
(1) Version of IOS:
-- 10.3.2 (14F89) for iPhone 5S
(2) It is only happening to my iPhone 5S. It works fine on my wife's iPhone 7+, and it works fine on my iPad Air, which is running version 10.2 (14C92).
(3) There is an XML profile on the ASA, which is why the ASA works with my wife's iPhone 7+ and my iPad Air.
Thanks for sending the link. I'll pour over it to see if I can leverage any other tips that I have not come across. Thanks.
--OJ
