Warning message
After static NAT and ACL ping not successful towards customer router
Jun 6th, 2017
Hi I workk for an ISP and have just implemented NAT and ACL and when i try to ping customer router I'm not able to reach it from my edge router which is connected to customer.
Customer Configuration below:
ip nat pool ICTD 10.10.10.1 10.10.10.2 netmask 255.255.255.252
ip nat inside source list 23 pool ICTD overload
ip nat inside source static 192.168.0.5 10.10.10.1
10.10.10.1 10.10.10.2 is public-ip range 1st ip is same as in static nat public-ip
ACL configurations
access-list 110 permit tcp any host 10.10.10.1 eq smtp
access-list 110 permit tcp any any
access-list 110 permit ip any any
Overall Rating: 5 (1 ratings)
Julio Moisa Tue, 06/06/2017 - 03:51
  • Red, 2250 points or more
  • Community Spotlight Award,
    Spanish Member's Choice, June 2017
What about if the following line is included:
access-list 110 permit icmp any any
or
access-list 110 permit icmp any any echo
access-list 110 permit icmp any any echo-reply
Are you making ping to the interface directly connected from your router? is the ACL configured on your side, right?
thukuthed Tue, 06/06/2017 - 04:46
Yes i'm making ping from my router directly connected to customer.ACLis configured on client my router there is no ACL.Okay let try the above configs you gave.
Julio Moisa Wed, 06/07/2017 - 04:43
are you using VRF under the interface facing to the client?
Julio Moisa Wed, 06/07/2017 - 06:37
do you see the mac address of the neighbor interface with ARP from your router? I think you already remove the ACL and the same history, right?
are you trying to ping the ip 10.10.10.1? or what is the destination? , what is the IP under the client interface?
Is possible to know the configuration of your interface and interface on the client side?
thukuthed Fri, 06/09/2017 - 07:43
ip nat inside source static tcp 192.168.0.5 25 10.10.10.1 25 worked. after reloading the router.
Thanks guys
Julio Moisa Fri, 06/09/2017 - 07:48
Thank you for the update.
Jon Marshall Fri, 06/09/2017 - 08:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You should not have needed a reload just a clearing of the translation but glad to hear it is working.
Jon
thukuthed Sun, 06/11/2017 - 23:59
Yeah, i tried clearing translation returned an error. so ended up reloading
thukuthed Wed, 06/07/2017 - 06:16
i have control on the remote router i manage it. ACL which is there is
Thanks for your reply. Can you create an access list with NATed address as the source and remote router's wan address, and then debug the access list on remote router? you can try this on both sides to confirm if icmp packets are even reaching to the end point. You may have already tried this.
thukuthed Wed, 06/07/2017 - 06:40
ok will get back let me ceate ACL as you suggests
Julio Moisa Wed, 06/07/2017 - 08:22
you can include an any, it can be a standard ACL.
thukuthed Tue, 06/06/2017 - 04:49
even with the commands you gave me when i apply still no ping.it replies with timeout
Jon Marshall Tue, 06/06/2017 - 07:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
It's not clear what the problem is.
Are you saying you have applied acl 110 inbound to the interface on the customer router that connects to you ?
Perhaps if you could explain in a bit more detail.
Jon
thukuthed Tue, 06/06/2017 - 23:40
ISP Router>>>>>>>>>>>>>>>>>>Customer Router>>>>>>>Customer LAN
ACL 110 is applied inbound on the WAN interface for customer.
I have a static NAT for Mail Server. and NAT Overload for internet access with two ip addresses. from the two ip addresses used to access internet i also use the other ip address for mail. i guess you get it now.
Jon Marshall Wed, 06/07/2017 - 01:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Is the customer WAN interface using either of the public IPs used in the NAT configuration ?
Jon
thukuthed Wed, 06/07/2017 - 02:29
Yes i have two NAT one with overload and another one with static one to one mapping. Yes the WAN interface IP address is mapped to a private IP using static NAT. The same public IP is used to NAT again is part of range used for internet access .
Thank you in advance
Jon Marshall Wed, 06/07/2017 - 02:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If the IP on the WAN interface is 10.10.10.1 then this -
"ip nat inside source static 192.168.0.5 10.10.10.1"
could stop the ping working.
If that is for mail use a port translation instead ie. -
"ip nat inside source static tcp 192.168.0.5 25 10.10.10.1 25"
Jon
thukuthed Wed, 06/07/2017 - 03:24
changed static nat as you suggested still not able to ping thru
Jon Marshall Wed, 06/07/2017 - 03:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
When you say ping through you do mean you are pinging the WAN interface IP ?
Did you check the translation table to make sure the old translation was cleared ?
If you are trying to ping the WAN IP then the acl is allowing IP so it really must be the NAT unless of course you have a basic connectivity problem which I am assuming you have checked.
Jon
thukuthed Wed, 06/07/2017 - 06:10
Yes Sir, basic connectivity has been checked, im pinging WAN IP here. after the change you suggested i cleared NAT translations.I also feel its NAT now since IP is allowed on ACL
