SSH failed on 3750 switch
When i'm trying to SSH to my 3750 switch i get the following error:
Unable to negotiate with 192.168.1.250 port 22: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1
I tried to use the command ip ssh dh min size 4096, but my switch doesn't know it.
Here is the config on the cisco switch:
Current configuration : 2325 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
username admin privilege 15 secret 5 xxxxx
no aaa new-model
switch 4 provision ws-c3750-24p
system mtu routing 1500
ip domain-name zorf.local
crypto pki trustpoint TP-self-signed-483538176
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-483538176
 revocation-check none
 rsakeypair TP-self-signed-483538176
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface FastEthernet4/0/1
interface FastEthernet4/0/2
 switchport access vlan 10
 switchport mode access
 spanning-tree portfast
interface FastEthernet4/0/3
interface FastEthernet4/0/4
interface FastEthernet4/0/5
interface FastEthernet4/0/6
interface FastEthernet4/0/7
interface FastEthernet4/0/8
interface FastEthernet4/0/9
interface FastEthernet4/0/10
interface FastEthernet4/0/11
interface FastEthernet4/0/12
interface FastEthernet4/0/13
interface FastEthernet4/0/14
interface FastEthernet4/0/15
interface FastEthernet4/0/16
interface FastEthernet4/0/17
interface FastEthernet4/0/18
interface FastEthernet4/0/19
 switchport voice vlan 10
interface FastEthernet4/0/20
interface FastEthernet4/0/21
interface FastEthernet4/0/22
interface FastEthernet4/0/23
interface FastEthernet4/0/24
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
interface Vlan1
 no ip address
interface Vlan10
 ip address 192.168.1.250 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
 logging synchronous
line vty 0 4
 password xxxxxxx
 logging synchronous
 login local
 transport input all
line vty 5 15
 login
end
try to zeroize and recreate the crypto key:
crypto key zeroize rsa
crypto key generate rsa modulus 2048
1024 is the default, so changing it to 2048 might help...
As you can see in the output below, the modulus command is not available.
Switch(config)#crypto key zer
Switch(config)#crypto key zeroize ?
  rsa  Remove RSA keys
  <cr>
Switch(config)#crypto key zeroize rsa
% All RSA keys will be removed.
% All router certs issued using these keys will also be removed.
Do you really want to remove these keys? [yes/no]: yes
Switch(config)#crypto key gener
Switch(config)#crypto key generate rsa modu
Switch(config)#crypto key generate rsa modu?
% Unrecognized command
Switch(config)#crypto key generate rsa ?
  general-keys  Generate a general purpose RSA key pair for signing and
                encryption
  storage       Provide a storage location
  usage-keys    Generate separate RSA key pairs for signing and encryption
  <cr>
So i used:
crypto key generate rsa general-keys modulus 2048
But the error is the same:
The solution i have come across so far is putting some additional parameters to the ssh client.
$ ssh -l <USERNAME> -oHostKeyAlgorithms=+ssh-dss -oKexAlgorithms=+diffie-hellman-group1-sha1 <HOST>
Could some of the experts here what is the solution to bring up the cisco switch to the modern KEX instead of using a workaround?
Thanks!
