06-12-2017 02:26 AM - edited 03-03-2019 08:35 AM
How can be divide firewall in range?
Ex. firewall for data centers, firewall for wan, firewall for branches etc
Which components should be consider? ( throughput , interface capacity etc )
Solved! Go to Solution.
06-12-2017 03:22 AM
You can break up physical firewalls using vdoms in fortinet or contexts in ASAs so you can have multiple smaller firewalls segregated in one physical unit
that depends on what you need in terms of interfaces but yes throughput is very important or you'll bottleneck the network if it cant process the volume of traffic your putting through
06-12-2017 03:22 AM
