I have had nothing but problems with this device. I configured it and installed it with out any issues. Then after a few days, nobody could connect to it. I removed it, reset it, reconfigured it and it worked for a while. This had happened 3 or 4 times now. I'm not using the power adapter as we have a POE switch and the power adapter isn't an option. Now I'm unable to access the WAP371 at all. I have reset it to the factory default and have tried the default ip address with no luck. I then checked the DHCP server to see the IP address it gave to it and tried that. Still unable to access it.
Try to keep pressing the reset button during 1 minute and try to log in again.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
